smoke
Old Aug 30, 2002 | 02:20 PM
Eshaft's Avatar
smoke
my 1991 rex na smokes if i don't let it warm up before i go anywhere, don't know why?
Old Aug 30, 2002 | 02:44 PM
eViLRotor's Avatar
Brother of the Rotary
Without more details, I'm going to say its just smoke from running rich after startup. Very common.
Also, it could just be condensation in your exhaust.
So, unless you are burning a lot of oil, or loosing coolant, then I wouldn't worry about it.
Old Aug 30, 2002 | 07:52 PM
Eshaft's Avatar
I can blow smoke so bad that my neighbors came over to make suer i wasn't on fire, again it's blue smoke, and it never did this before, what can i do to fix this...
Old Aug 31, 2002 | 06:36 PM
Eshaft's Avatar
bump
Old Aug 31, 2002 | 06:39 PM
Aaron Cake's Avatar
Engine, Not Motor
Blue = oil. When did it start? Did it start gradually? How much oil do you use between changes?
Normally, excessive oil smoke means that either your side seals are bad, or your purge valve causing pressure to build in the sump (which forces oil past the side seals).
Old Aug 31, 2002 | 07:12 PM
WonkoTheSane's Avatar
Green Flameless
you're not just hitting the throttle hard immediatly after turning the car on, right? I believe that all sevens will smoke really bad if you nail the gas before the seals have a chance to expand? (Correct me if i'm wrong)
Old Aug 31, 2002 | 08:23 PM
Eshaft's Avatar
havent had a chance to calculate oil consumption, between oil changes or otherwise, and it's defineatley more than me nailing it when i start, but how do i fix this????
Old Aug 31, 2002 | 08:29 PM
Eshaft's Avatar
also this did not start gradualy, i went through a period of time where in i wasn;t driving my rex to often, fixing an overheating prob and then it started smoking, but now that you mention pressure, i noticed that my oil pressure kind of wont go all the way up even when pushing it, and keep in mind that if i let it warm up ni smoke...
Old Aug 31, 2002 | 09:12 PM
HuggyBear's Avatar
look like oil is seeping into your housing when the cars not running. and ofcourse being burnt off as the car is running.
as for how its gettin in there, ask the gurus
Old Oct 5, 2002 | 12:10 PM
Newbie
Question Smoking Engine
I have a very similar problem. My car is not a daily driver and I find when ever I start it up it smokes like a champ. More of a white smoke. putting my hand on exhust yeild nothings? Smell is not fuel but more carbon or typical exhust (heavier). This problem started for me right after I had a flooding problem. I put ATF in and it smoked then and ever since. My neighbors all look at me like I am buring the hood down. Oil is not down, water level stays fine. It has been suggested that the side seals are going. Just don't believe that! Still think it is fuel related on start up somehow. If I rev the car seady and hard it will start to smoke again then clears up. I have no problem when I drive it or restart same day. Help???
Old Oct 5, 2002 | 07:01 PM
USNALAX1's Avatar
rotary engines burn oil naturally. i've seen it documented that the burn aporoximetly 1 quart every 500 miles. so unless your burning alot more than that i wouldn't worry.
Old Oct 5, 2002 | 07:49 PM
patman's Avatar
Resident Know-it-All
what and where is a "purge valve"? i have this same prob try using some oil treatment **** it helps a little.
ls1swap
Jun 3, 2024 03:25 PM
mulcryant
Oct 4, 2015 12:18 AM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
