What's after ATF?
Old Aug 28, 2002 | 12:39 AM
khai seven's Avatar
What's after ATF?
If the "ATF" trick does not work then what else can I try to get my seven started again? Because my seven has been sitting unstarted since October 2001. There is fuel to the motor and no fuses are burnt. So does the ATF trick really work for my situation? The coils are puttin out spark and nothing seems out of place. Will using the ATF method help restore compression to get the motor started again?
Old Aug 28, 2002 | 05:06 AM
The Ace's Avatar
Greek Power
uummmmm, what compression do you have right now ? ATF can restore compression to an engine that has -relatively- good seals, but cannt do jack **** for zero compression....
Old Aug 28, 2002 | 07:12 AM
banzaitoyota's Avatar
What Subscription?
Proper, methodical troubleshooting techniques. Star with a compression test.
dradon03
Sep 18, 2015 05:57 AM
Sniper_X
32
Sep 26, 2001 11:59 AM
cpt_gloval
11
Sep 13, 2001 02:03 PM
