Dyno my FD on thursday, any guess?
Old Aug 19, 2002 | 01:01 PM
ZeroBanger's Avatar
Hey everyone, lets play a guessing game. My mods are in sig. I will be dynoing on Thursday. I'm curious as an estimate of what you guys think I will dyno at...
Any ideas?
Old Aug 19, 2002 | 03:11 PM
Directfreak's Avatar
I am a Jeeper Now.
Pump Gas, Racing Fuel? Boost Levels?,etc..
Old Aug 19, 2002 | 03:12 PM
ZeroBanger's Avatar
oh..91 octain.. 10-11 psi on primary turbo, 12 on secondary turbo. 6 PM in evening, I expect it to be about 60 or 65 degrees
Old Aug 19, 2002 | 03:23 PM
the_glass_man's Avatar
Will u do me a kindness?
255-275 rwhp.
Old Aug 19, 2002 | 03:26 PM
ZeroBanger's Avatar
Originally posted by the_glass_man
245-265 rwhp.
5 grand gets me 20 extra HP? yuk
Old Aug 19, 2002 | 03:29 PM
You very well could see up to 300 rhwp, depending on intake temps, A/F ratio, etc...
I just don't want you to get your hopes up.
And the 5 Grand gets you 40-80 more horsepower to the wheels.
If you make 300 to the wheels, its more like 350-370 to the engine which is more then 100 hp more then stock.
Old Aug 19, 2002 | 03:30 PM
ZeroBanger's Avatar
I would jump up and down if I got 300 to wheels! 280 would be ok too.
They are going to do a wideband, does that tell me my a/f ratio?
what should I have my a/f to keep from running lean, yet give more HP?
Thanks so much!
Old Aug 19, 2002 | 03:32 PM
You could add a midpipe and that would give you a little more hp, less down low, more up top.
If you get some fuel mods you could up the boost to 14-16 psi and could easily get 330-350 rwhp.
Thats around 390-415 horspower to the engine, out of a small 1.3 L.
Of course it all depends, what kind of shape is your engine in?
Base Map or are you going to tune it?
Fresh plugs and wires?
Old Aug 19, 2002 | 03:34 PM
ZeroBanger's Avatar
I don't know much about the power FC, I set the boost ratio because I have to change it on cold days or I hit a fuel cutoff on my drag days.
Ricks rotary tuned my power fc when it was installed, I really don't know what they did.
Old Aug 19, 2002 | 03:35 PM
Yes the wideband well tell you the ratios. In the 11's ratio is good.
Do a search on the forum, they should contain all the answers you are looking for.
Old Aug 19, 2002 | 03:36 PM
You may want to see if you can find someone with a datalogit, where are you taking the car?
Old Aug 19, 2002 | 03:38 PM
ZeroBanger's Avatar
ATP in pleasanton. They have experience with turbo's. I guess it will be cool to see what I have. I keep blaming my 13.65 @ 105 on my crappy tires....
I guess the dyno will tell me.
Old Aug 19, 2002 | 04:43 PM
neofreak's Avatar
accept no imitations™
I did 276.3hp with the following: (less mods than you)
power fc
pettit downpipe
pettit intake
apex n1
stock ic
Old Aug 19, 2002 | 10:50 PM
12.65 @105 mph is in my humble opinion respectable for any daily driver real street car... much less a 79cubic inch engine.... Ummmmmmmmm Carter
Old Aug 20, 2002 | 03:27 AM
Stevil's Avatar
I dyno'd 276 rwhp w/ basically what you have at 15 psi. Ya, something was wrong and I think it was my HF cat. I took it off and can only see blackness. Can you say clogged. But I am interested in another dyno w/ MP and too quiet CB. Is this a group you are going w/? I am off wed and would like to go, if possible. Let me know.
Where is ATP at? I used dyno spot last time.
Steve
Old Aug 20, 2002 | 09:31 AM
ZeroBanger's Avatar
Steve
Steve,
I tried to get a group together in the west section, but like everything else with FD owners it never amounted to anything. I'm going with another member of the forum who lives by me. ATP is located in fremont. They have a dyno session available on WED still. We are going thursday at 6 PM. Call them and see if they have any time left on thursday we can all go. let me know.
David
Old Aug 22, 2002 | 10:21 PM
sunnyxwala's Avatar
"I used to have one"
From: dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS
any results?
Old Aug 22, 2002 | 11:03 PM
Yeah dude, what are the results. Mind posting the dyno sheet???
Old Aug 22, 2002 | 11:17 PM
ZeroBanger's Avatar
I will post a thread at some point detailing, but in a nutshell...Myself and rynberg went together. He has a catback and downpipe.
I had 5 runs, 2 were aborted.
First run I had 10 lbs of boost and it dynod at 250 HP and 226.4 torque. Realizing only 10 lbs of boost I upped the boost from the power fc (estimated it) The second run I saw my boost hit 13 so I asked him to abort. He said the a/f was perfect and that I should have continued..
He put a fan on my engine to cool it down, took 20 minutes.
Ran it again, this time my boost hit 15 and I told him to stop. He stopped , the dyno chart was really strong I regret now. The guy doing the dyno said I was between 280 and 300 on that run.
My car was so heatsoaked we ran it again and I dynoed at 266 HP and 247 lbs torque. My boost ran 12 after the transition hit 14 or so. Realize that the fan that was blowing in front of my car did nothing , my BLITZ SMIC was so hot you could not touch it.
I realize that this gives me a base to say I am around 280. When I'm actually moving and my IC is cool and I am getting air into my intake I am sure that my car has 300 to the wheels.
David
Rotate86
May 18, 2018 02:44 PM
Einheri
Oct 7, 2015 12:23 PM
NickNac113
13
Oct 1, 2015 09:25 PM
pfsantos
Sep 30, 2015 01:29 PM
