Tranny showing signs of death?
Old Aug 19, 2002 | 07:54 AM
silverrotor's Avatar
Regrettibly my s4 tranny Is showing signs of terminal death. I do plan on getting a rebuild. Was their a difference with trannies within the S4's (excluding Turbo)? I have a GXL.
I have been told to replace some syncros with those of the GSL -LE (83-85). It supposibly allows better acceleration as opposed to the S4 Tranny? Although I am not sure what gears they are, It does sound enticing though. What would you do?
Old Aug 19, 2002 | 08:03 AM
SureShot's Avatar
Seduced by the DARK SIDE
It sounds like you're getting some experienced advice, but before you pull it, what gear oil are you using?
Old Aug 19, 2002 | 08:44 AM
Redline MT 90. It did Improve my shifting which was In the early stages of my terminating tranny. Especially the Infamous notchy 2nd gear that we experience In colder weather but It seems that Redline could not revive my dying Tranny.
Old Aug 19, 2002 | 08:58 AM
SureShot's Avatar
If the bearings are quiet, a rebuild with syncros and rear seal should do it..
Old Aug 19, 2002 | 09:07 AM
SureShot's Avatar
I word about the lock nuts on the main and countershaft. When you stake the collar, use a round nose punch. My 91 locknuts were hit with a square edged punch that cracked the collar. That allowed the lock tab to break out, allowing the nut to back up and jam 5th.
Old Aug 19, 2002 | 05:05 PM
I had just learned that It Is the first 3 gears that should be swapped out In favour of the GSL LE ones. Can anybody confirm that?
I plan on doing that set up. So what? A little bit more money put towards a solid Tranny for my 7. It Is damn worth It
Old Aug 19, 2002 | 07:24 PM
Aaron Cake's Avatar
Engine, Not Motor
Sounds like you've never had a tranny apart before, in which case I would recommend you have someone else do it, or buy a used/rebuilt unit. Seriously, you'll open it up, look down and say "Oh ****". Lots of special tools required, and good luck getting the parts (Mazda will be NO help, and even if you know exactly what you want you'll get the wrong stuff). Also, it will probably cost as much to rebuild as it would be to buy a good used one.
Old Aug 19, 2002 | 08:29 PM
I wish I was driving!
That's what I said first time I rebuilt an auto tranny (it was a C4). In the end, I had messed up with a check ball placement in the valve body, causing no 2-3 shift, but I figured it all out.
Man, aaron, I'm surprised from that attitude from you. "If you've never done it before, don't do it yourself?" How is anybody supposed to ever learn about automotive work? I always do my own stuff, no matter how big or little it is, cheaper or more expensive, just to learn as much as I can.
Old Aug 20, 2002 | 12:17 AM
rx-7fc's Avatar
i took mine a part and cleaned it and put it back together and it ran and it was my frist time to and silverrotor do you want to buy the syncros and bearings and main bolt because i did not use them and they are all mazda parts and new
Old Aug 20, 2002 | 12:38 AM
Rotorific's Avatar
I dont know a damn thing
Trannys are no problem getting them apart it was trying to get the bloddy thing back together mainly getting the thing that shifts the synchros in its place it took me a while then i got it with ease no trannys are no problem for me... i still hate dropping them
Old Aug 20, 2002 | 07:33 AM
Well If you must know, I don't plan on doing It myself. This one of those seldom times I will have It sent away to have It worked on. Normally nobody touches my car, I work on It myself. Right now I don't have the time or resources to "do It myself". Also, If I were more familiar with the Internals than I would confidently approach this myself.
rx-7fc/// thanks for the offer. When I find out more I'll PM you, If anything.
Old Aug 20, 2002 | 10:52 AM
RyosukeTakahashi's Avatar
Could you please explain the symptoms of your dying tranny?. I think mine has a problem and nobody seemed to answer it.
thanks
Old Aug 21, 2002 | 08:06 AM
Reversing My car Is a bitch. I have trouble getting It Into gear due to really bad grinding and a real loud whinning sound coming directly from the Tranny In all gears.
ricardo.benin
Sep 23, 2015 10:08 AM
RedBaronII
Sep 20, 2015 11:29 AM
