Gulf oil
Old Aug 6, 2002 | 04:10 AM
Spain's Avatar
Gulf oil
Is a gulf 20W50 a good oil for rotarys?
Any recomendation in mineral oil?
Old Aug 6, 2002 | 07:31 AM
grampa's Avatar
Please use the search.
You will probably get more information than you want.
Old Aug 6, 2002 | 08:31 AM
Rated R1's Avatar
Oji San
Cut him some slack grampa. If you notice he is from spain and his english is not so great.
I would go with 10W-40 in the hot climate of spain. 20W-50 is a bit thick amigo.
Old Aug 6, 2002 | 09:03 AM
DomFD3S's Avatar
Mod Powers...gone!
Well, I have never heard of the "Gulf" brand of oil. I would say this though.
If your climate is hot, use a heavier weight oil such as 10W40, 15W40, 20W50, etc.
If your climate is cold, you may want to use a thinner oil, such as a 5W30 or 10W30.
The thinner oils are used in colder climates because they flow easier. While I have never been to Spain, I would believe that your climate can get pretty warm. I would recommend using at least the 10W40. You could always experiment to see if the 20W50 would be good in your car. If not, just drain it and don't use that oil.
Also, use a high quality oil such as Mobil 1, AGIP (brand of motor oil used in Ferraris), etc. The high quality oils tend to burn cleaner.
Old Aug 6, 2002 | 09:43 AM
Turbonut's Avatar
Yes, that would be fine. Check SAE rating on container, probably SH or above.
Looks like weather in the 90's, lows 60's. 20/50 great for that type of weather.
Old Aug 6, 2002 | 10:08 AM
maxpesce's Avatar
Ex fd *****
10w-30 is the Heaviest oil MAZDA recomends for the fd- I run Castrol GTX 10w-30, for a HIGH milage engine 20w-50 might be appropriate.
Even on the hottest days and driving hard 10w-30 gives me 60+ psi oil pressure at 3000 rpm and 120psi above 5000rpm .
10w-40 is NOT a good choice as it has a lot of additives to produce that 30pt viscocity range from a 10w Base oil, stick to 10w-30 or 20w-50 (or 15w-50 if you decide to run MOBIL-1 full synthetic)
Old Aug 6, 2002 | 11:04 AM
grampa's Avatar
So magically the responses in this thread will be clearer than the hundreds already done on this subject?
After reading some of the english typed by forum members that live in the US...
oh, never mind...
Old Aug 6, 2002 | 11:52 AM
Spain's Avatar
Thanks to all for the great help to me and excuse me, by my broken, broken english
Old Aug 6, 2002 | 12:42 PM
Rated R1's Avatar
Oji San
No problem. Your english is a lot better than some of the english speaking people on this forum.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
