What do you guys think about the MSD box???
Old Aug 4, 2002 | 06:03 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Does anyone have any probs with the MSD ignition boxes? How well do they work? I know the best set up would be to use 3 but how would just running 1 for the leading be?
Does it also need to be ran with msd coils? Will it fry the stock coils or is it safe to run with stock coils?
Thanks guys,
STEPHEN
Old Aug 4, 2002 | 07:19 PM
ErnieT's Avatar
Living life 9 seconds at a time
Stephen,
You can run just the MSD digital 6 to leading coil for now. Thats what I'm doin till I can get the money for the DIS 2 and yes, you can used it on stock coils.
Old Aug 5, 2002 | 09:36 AM
SPOautos's Avatar
Ernie - Where did you mount your digital 6??? Were you able to find a place that looked half decent?
Thanks,
STEPHEN
Old Aug 5, 2002 | 01:52 PM
SPOautos's Avatar
Thanks Gordon, thats not a bad idea.
What do you think about this. I was thinking of getting the extremely small N'tech or similar battery but keeping it in the stock location then using the rest of the battery tray for the Digital 6 and I'm thinking of relocating my stock coils there as well. I'm thinking all the heat and lack of airflow in the stock location cant be good for them.
I can drill a hole in the bottom of the battery tray and runn all the wires thru it, with the top of the tray in place you wouldnt even be able to tell anything was in there!!!!
I'm going to need some measurment to see if everything will fit.
Anyone know the size of a MSD digital 6????
Thanks,
STEPHEN
Old Aug 5, 2002 | 03:02 PM
racer rx's Avatar
You guys running MSD's or Crane's are you using them for Multi-spark at the lower rpms?
Old Aug 5, 2002 | 03:30 PM
SPOautos's Avatar
They (and soon to be me) are using the MSD digital 6 ignition amp box. There are some guys running Crane but I cant think of who right now.
Most people run the amp boxes to be stronger spark. When you run a rich a/f ratio its hard on the ignition to burn it. Running a amp just helps with this task by giving the ignition more juice.
STEPHEN
Old Aug 5, 2002 | 05:27 PM
Goblin's Avatar
Gordon... 2 gauge?
Old Aug 5, 2002 | 05:46 PM
SPOautos's Avatar
Originally posted by Goblin
Gordon... 2 gauge?
Yea i was kinda wondering about that also....was is a misprint? I figured you meant maybe some 12gauge wire or something.
STEPHEN
Old Aug 5, 2002 | 06:22 PM
rotorbrain's Avatar
fart on a friends head!!!
in the instructions you are told to use a larger gauge wire if extending it. . . and to solder it. i have the wiring diagram for an fd using stock coils and a digital 6 (faxed from msd) if anybody wants it.
paul
Old Aug 5, 2002 | 09:32 PM
STEPHEN
I was just at kdr and saw gordo's fd. The wires looked pretty damn thick...
Tylerx7fb
39
May 27, 2019 12:45 PM
MoTeC
Sep 10, 2015 07:58 PM
Clacor
Aug 14, 2015 09:17 AM
