Fuel Cut-off
Old Jul 29, 2002 | 05:41 PM
Solid_Mazda's Avatar
Fuel Cut-off
All i need to know is where to put the fuel cut-off switch. Any ideas?
Old Jul 29, 2002 | 05:44 PM
niner's Avatar
there is a fuel pump relay under the steering column w/ about 5 wires or so going to it
i forget which one to cut though, try searching for answer
Old Jul 29, 2002 | 05:48 PM
NZConvertible's Avatar
I'm a boost creep...
Look for a yellow plug. Put the switch in the middle wire.
Old Jul 29, 2002 | 05:52 PM
Turtle's TII's Avatar
Find the relay under the dash, it's above the steering column. Then find the blue/red wire on the relay.
Now get a 20+ amp switch, and splice it in.
Turtle
BoostedRotors's Avatar
I HATE sleepy eyes
I ran mine all the way from the fuel pump, it wasn't that much work really.
Old Jul 29, 2002 | 06:28 PM
Originally posted by BoostedRotors
I ran mine all the way from the fuel pump...
Our fuel pumps already suffer from problems with voltage drop, and you’ve just made that much worse by making the current take another trip from the rear of the car to the dash and back again before it gets to the pump! Bad idea. This is why a switch should be wired into the relay.
Old Jul 29, 2002 | 06:43 PM
ok...confused here...do i go for the yellow, blue, red? Which is the right one?
Old Jul 29, 2002 | 08:18 PM
J-Rat's Avatar
Alcohol Fueled!
I had done a big write up on the fuel cut off, I even posted some pics...Let me see if I can find it...
Old Jul 29, 2002 | 08:30 PM
J-Rat's Avatar
Alcohol Fueled!
FOund it. If you have more questions, let me know.
https://www.rx7club.com/forum/showth...cut+switcht...
Old Jul 29, 2002 | 08:59 PM
I HATE sleepy eyes
Hasn't given me any problems as of yet. Nor anyone I know with the same wiring jobs, but I do appreciate the input. Ill keep that in mind. Perhaps one day when I want to work on my car and have nothing to do, Ill rewire it.
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
