Haltech NO RPM/START while cranking HELP!!
Old Jul 27, 2002 | 03:54 PM
Lightbulb NO RPM/START while cranking HELP!!
I am still having problems with my darn Haltech E6k...
The car will not start, there is no spark, no rpm on the tack or on the engine data page, I have checked all the wiring for continuity and poor connections, it is all ok. What else should I look for? I can get into online mode so the ecu is ok......
HELP!
Old Jul 27, 2002 | 05:00 PM
HWO's Avatar
HWO
inteligent extratarestril
either your CAS is wire'd wrong or its dead. I had an intermittent problem with mine one of the wires coming was slowly coming out the back of the plug i was using, happened to be the +ve feed to the CAS so it wouldn't get spark or rpm readings
Old Jul 28, 2002 | 08:45 PM
Ok, I just put in a spare CAS that I know is in perfect shape. Still no RPMS. I did notice that when I turn the ignition to the on position that the tac hops and then falls back to 0rpms and continues to stay at 0rpms as I crank the engine over. How do I go about checking the Ignition switch? I AM SOOO STUMPED. ANY HELP OR SUGGESTIONS WOULD BE APPRECIATED!!!
Thanks,
Old Jul 28, 2002 | 09:46 PM
Ok NEW INFO....MABEY THIS WILL HELP>>>
When I turn the car to on, I get few readings on the Engine data page that pop up for a sec and then go away.
Here they are:
RPM: 60.0
Injection Time: 12.7ms
Duty Cycle: 4.0%
These readings just flash up for a second and then dissapear...... WHAT COULD THIS MEAN?????
Old Jul 29, 2002 | 08:19 PM
Thumbs down
Wow, thanks for all the help people.....
Not impressed with this forum....the pro's must be somewhere else.....looks like I'm out of luck.......
Old Jul 30, 2002 | 08:01 AM
tims's Avatar
you continue to have a wiring problem. I don't know what to tell but to make sure every wire is in the proper location and the connection is done correctly. if you are reading different info while cranking I would check the way you have the ecu wired. is this a street car install patched into the stock wiring? I would isolate the haltech and use some manual switchs to see if there is a problem with the stock wiring. again it is hard to diagnose wiring type issues over the internet.
Old Aug 4, 2002 | 10:51 PM
AJatx's Avatar
Does the 60 rpm blip on the engine data page AFTER you stop cranking the engine (key in START position)?
Fastrotories has the same issue.
I highly suggest you both check your 12V, switched 12V, ground, CAS connections, and ignition connections for a short or bad connection (GND).
It sounds like Fastrotories gets either a glitch or noise on inputs (Home and Gain??) showing 60rpm.
J
Old Aug 6, 2002 | 09:13 PM
AJatx's Avatar
FastRotories found the source of the problem: +12V switched connection.
He sourced from the wrong switched power (the RX-7 schematics will show you the different power sources).
Again, check your connections, especially power and ground.
Good luck!
J
Old Aug 10, 2002 | 11:37 PM
fastrotaries's Avatar
W. TX chirpin Monkey
Yes apparantly there are two switched connections on the TII. 1 is always on, and the other switches off during cranking. I used one of the stock main harness. It's a black with white stripe wire. Now it works fine.
Old Aug 11, 2002 | 08:46 AM
kabooski's Avatar
Laying Down Rotary Law
yea? can you take a Pic of this blk with white strip
hmm let me see if I can find it... brb
Old Aug 12, 2002 | 02:19 AM
GO look where your stock computer used to hook up to. No not the engine harness you removed. And off that line you should see a similar wire. Actually there should be several of them there. Also are the black with yellow, and those you can't use since they too turn off when the ignition is cranking.
Old Aug 23, 2002 | 12:44 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah sounds like you need to confirm that the 12V ign wire you are using is HOT WHILE CRANKING. A $19 DVM from Advance or Autozone will help you with that task ...
Aramir
Oct 18, 2015 02:39 AM
Robrods64
Oct 2, 2015 07:56 PM
93FD510
Oct 1, 2015 02:00 PM
Rotafuzz
Sep 30, 2015 09:55 AM
