Go Back   RX7Club.com > Tech and Performance > Rotary Car Performance
Old 09-03-07, 09:04 PM   #1
Xcentric
e11 running nitrous question
My e11 won't activate the relay to run my nitrous. I have it in normal mode
acting as a ground. I fiddled with all the parameters so it would activate
under light throttle just to test the solenoids. When I reverse it to inverted
and 12 volts, it activates constantly- sending 12v constantly.
Worse case scenario, i'll run a window switch and wide open throttle
switch externally. Anyone seen this before? btw I'm using pmw #1
Xcentric is offline   Reply With Quote
Old 09-04-07, 02:47 AM   #2
crispeed
'Tuna'
crispeed's Avatar
Send a message via AIM to crispeed
Did you set up an AUX in to let the ecu know that the Nitrous system is armed?
You should post this in the ecu forums.
CRISPEED Rx-7 9.204@150.47
TRAVIESO RACING Rx-3 10.04@130.86mph ALL MOTOR
AWD MOTORSPORTS 8.75@163EVO8 GSR E85
AD TURBO 2JZ S2000 8.69@163 E85
CHARLES/RAW 2JZ S2000 8.7213@157
BIG DADDY PERFORMANCE SUPRA's MKIII 8.70@170/MKIV 7.95@180
crispeed is offline   Reply With Quote
Old 09-04-07, 05:51 PM   #3
Xcentric
ok, will try- thanks
anyone have exp running nitrous on a turbo rotary? sleeperfc Single Turbo RX-7's 21 04-03-07 01:45 PM
who has been successfully running nitrous for some time? thorin 1st Generation Specific (1979-1985) 12 12-16-02 12:18 PM
Is anybody Running NITROUS on their RX-7's bottlejockey 2nd Generation Specific (1986-1992) 25 10-21-02 12:01 AM
