Rebuilt Engine, finally starts, smokes and idles terribly
Old Aug 20, 2007 | 02:14 PM
matpdx2300's Avatar
I have a '79 rx-7 that I just rebuilt the motor in. I got it to start for the first time last night. My concern is that it smokes a lot. We ran it for about 45 mins. and it continued to smoke a lot. I know it's normal to smoke quite a bit after a fresh rebuild but is it normal to smoke for this long?
Also, I cannot seem to get the mixture right. Is this normal? Am I missing something obvious?
My timing is on, my spark plugs are nice and clean I just am not sure if everything is going the way it's supposed to.
Any help would be greatly appreciated.
Old Aug 20, 2007 | 02:29 PM
Kentetsu's Avatar
What does the smoke smell like? Oil, fuel, or coolant?
Old Aug 20, 2007 | 02:32 PM
Rogue_Wulff's Avatar
Too old to act my age
If the carb is running way too rich, or even trying to flood, you'll never get the engine to idle correctly. It will also cause it to smoke.
Old Aug 20, 2007 | 02:38 PM
matpdx2300's Avatar
I can't really tell what the smoke smells like, it smells like a mixture of things. I don't think it really smells like coolant, but it definitely smells some of oil and fuel...
I'll check the carb to see if it's running way to rich.
Old Aug 21, 2007 | 02:11 AM
RXnos1200's Avatar
1200 gone......but......
Losing any coolant?
Old Aug 21, 2007 | 03:22 AM
REVHED's Avatar
Hunting Skylines
Did you machine the end plates? New oil control o-rings?
Old Aug 21, 2007 | 07:12 AM
Latin270's Avatar
Yea, could be one of those pesty water,oil, o-rings. Damn things slip out of place sometimes when re-assembling. Is the smoke white?
Old Aug 22, 2007 | 09:27 AM
matpdx2300's Avatar
I don't appear to be losing much coolant but yeah the smoke is white.
My buddy is pretty sure it's the o-rings. Says that if he puts his hand behind the exhaust for a minute it speckles his hand in oil.
Sound like a tear down and re-assemble?
Old Aug 22, 2007 | 09:50 AM
Clearkut's Avatar
What could possibly go wr
does it just spit condensation or is it for sure oil/coolant, my new rebuild will spit condensation for a bit on thr first start of the day but once its warm it stops, i lose no oil(i premix) or coolant. if its white smoke that disapears right away it may be steam from exhaust condensation, if it stays thick it will likely be coolant, i had one previously that acted like that, it didnt last long or run good ever.
Kyo
Apr 13, 2019 09:24 AM
ncds_fc
Aug 15, 2015 10:06 AM
