You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX7Club.com today!
No one knows the slack tolerance in the oil pump chain? Come on guys. I thought this forum was a little smarter than that.
I guess I'll have to wander over to Nopistons where they have some real rotorheads...
I couldn't find it either. I have searched everywhere and I have found two different answers. One said not more than 3/8in another said not more than 1/2in. I have 3 used chains lying around and all of them were exactly 1/2in slack. I just thought it was strange that all my used chains had a 1/2in of slack. One of the chains only had 80,000 on it. If these engines last 150,000 plus, why is my oil pump chain already out of spec after 80,000?
I wouldn't worry about seeing 1/2". As I said, I've never replaced one...I'm sure those experts that do $6000 engine rebuilds will now come in here and tell me how wrong I am though.
Ok I am going to reuse my chain. I think your right Aaron about it being in spec. Like I said, my engine only had 80,000 miles on it. How could it be bad if these engines can go for another 80,000? But if it does go bad I am expecting you to come over and help me change it!
I was always surprised that there was no tensioner assembly on the chain... its very possible that mazda tested one and decided that it wasn't needed. I've seen a few OP drive systems while working at Borg-Warner that have no tensioner, so it seems reasonable.
How about a $1200 rebuild? If you buy the Atkins rebuild kit they will send you a new one, do you have to replace it no, but some people are anal about their engines. Some aren't, I would personally replace it.
That's a good point. I think it boils down to whether you want the piece of mind knowing that you have a new chain. Is there a functional difference in this application if the chain is a little bit longer? No. But is there piece of mind in spending the little bit of money that a new chain costs? Absolutely.
Originally Posted by RX7Tuner.
Question. Has anyone had a chain break on them? Does it just wear so bad that the teeth begin to slip?
Thanks everyone
I've never seen it, nor have I ever heard of it. The only time I've heard of an oil chain failing was when an oil pump seized.
