Crank Angle Sensor (G signal)
Old Dec 11, 2006 | 06:47 AM
Go48's Avatar
Yet another pulsing cold idle and I'm trying to troubleshoot a couple of error codes. Cleared the error codes by disconnecting the neg battery cable overnight. Reconnected the battery cable and read the error codes before starting the engine. I get 03, "crank angle sensor (G signal), broken wire, short circuit". [Also get a 30, "split air solenoid valve", but I'll deal with that later.]
If someone can tell me how to troubleshoot the CAS/G signal error I would greatly appreciate it. Visual inspection of wiring, internal and external, did not reveal any obvious breaks or shorts. And would this "problem" affect cold idle?
TIA, Larry
Old Aug 31, 2012 | 11:33 PM
Julzilla's Avatar
I have the same error too, any help is highly appreciated.
Old Sep 1, 2012 | 01:41 AM
SirCygnus's Avatar
whats going on?
unplug the sensor, and clean the contacts. the cable that runs to the CAS via the pins on the ecu plug. do you have continuity? any resistance?
Old Sep 1, 2012 | 07:27 AM
Julzilla's Avatar
Unplugged the CAS and sprayed both sides heavily with RP7 ( the plug was gunked up with oil residue), reset the ECU by cutting power for 5mins then started the engine again. Idle didn't improve and the ECU was still spitting out an Error 3.
When you say check for continuity do you mean by creating a loop back at the CAS plug and check for continuity at the ECU plug?
Old Sep 1, 2012 | 07:50 AM
bumpstart's Avatar
talking head
there is a resistance check for the pickups
you also visually inspect the wires where they passes within the grommet on the cas body
,, issue is often a short here
continuity between the G+ or G - wires and or to earth will indicate this issue
( measured at the unplugged connector , CAS end )
Old Sep 1, 2012 | 08:28 AM
SirCygnus's Avatar
whats going on?
Also, try regapping the pickups for the sensor. take the top cover plate off the cas. inside you will see two teethed ( a two toothed wheel and a many toothed wheel) wheel and two sensors for each wheel. find the g sensor (i dont remember which wheel it goes to ) and unscrew is mounting screws. dont take the screws out all the way as this is un necessary. put a piece of paper between a tooth and the sensor and screw it down tight. then replace the top cover, and replace the cas properly stabbing it. its is now regapped.
Old Sep 1, 2012 | 05:42 PM
Julzilla's Avatar
Ill have a good look today, I hate to be a pain in the *** but would you know what resistance id be looking for?
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 15, 2015 04:45 PM
Monsterbox
Sep 11, 2015 03:29 PM
windom
Sep 11, 2015 04:48 AM
