Compression changes with altitude?
Old Apr 5, 2006 | 06:00 PM
shortfuse's Avatar
I was told that the compression of a motor changes varying on the altitude?
For Example if a car was compression tested in Denver where the elevation is extremely high, and it reads 6.5 all around both chambers, and then is tested in lets say Los Angeles where elevation is very close to sea level, that same compression number will rise to maybe 7.0 - 7.5 ???
Is this true?
Any feedback is appreciated
Thanks
Old Apr 5, 2006 | 06:06 PM
shortfuse's Avatar
bump
Old Apr 5, 2006 | 06:38 PM
shortfuse's Avatar
anyone got an answer to this???
Old Apr 5, 2006 | 06:43 PM
Maximum's Avatar
The compression ratio does not change because that's a volume ratio, but it is true that the maximum pressure reached in compression is lower at altitude. Denver is the "mile high city", so the altitude is about 5280 ft. At that elevation, the atmospheric pressure is about .8 atmospheres as given by http://www.personal.usyd.edu.au/~gerhard/pressure.html . So if your compression tester measures 7.5 bar at sea level, you will see about 6 bar in Denver. Feel free to tell me if I'm not considering something here.
Old Apr 5, 2006 | 07:14 PM
shortfuse's Avatar
okay, i understand, so the compression of the motor DOES change but not the actual compression ratio. So if the car was tested at about 6.5-6.7 I should see around 7.8-8.0 compression at sealevel, which i believe is very good.
Thank you
anymore feedback is appreciated.
Old Apr 5, 2006 | 07:33 PM
ehos's Avatar
Passion
When you do the compression test, you have to factor in RPM's, temp. and altitude.
For example, FD's have/show lower compression and are still 'fine' up here in Edmonton. Ie, I had a FD with 80PSI all around. That's 'good' up here, but it might be marginal at sea level.
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
93FD510
Oct 1, 2015 02:00 PM
