Thinking: Single Turbo Oil Drainage
Old Mar 1, 2005 | 12:33 PM
atihun's Avatar
So I was thinking, "why not use both oil drains on the engine" for the single turbo, as used with the stock twins.
Just put a Y from the turbo out to a line for each of the iron plates.
Wouldn't this help with drainage and therefore less blowby (with properly installed catch can)?
Old Mar 1, 2005 | 12:56 PM
rotoboy661's Avatar
HUH?? WHY
if u are worried about oil blow by just use a oil restirctor
theres no need for 2 man, u just making more work for urself
or if u really want to just use a -10 an fitting and -10 ss line like i did
Old Mar 1, 2005 | 01:10 PM
atihun's Avatar
One because it is not recommended to use an oil restrictor on the turbo I am going to use (GT35R).
Two, it's an extra ss line that takes 10 minutes to put together.
Three, you have more flow out capacity.
I don't know for sure, that is WHY I was asking.
Originally Posted by rotoboy661
HUH?? WHY
Old Mar 1, 2005 | 01:50 PM
boostgasm's Avatar
formerly 93BlackFD
GT35R has built in oil restrictor, one return is sufficient
Old Mar 1, 2005 | 03:32 PM
power hungry's Avatar
3 rotor
My 2 cents is I would think the Y would be more restriction than a single -10 line.
Old Mar 8, 2005 | 08:30 PM
mark57's Avatar
Temple of Cornd0g
The I.D. of the factory oil return line is 5/8". You have to use -12 line and fittings to maintain the 5/8" I.D. of the -12 fittings.
Old Mar 8, 2005 | 10:44 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Yup! Good point.
Old Mar 9, 2005 | 09:08 AM
NewbernD's Avatar
Tequila? ..it's like beer
Just splitting hairs, but -10 has a ID of 5/8". -12 is 3/4" (12/16)
Old Mar 9, 2005 | 09:49 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Boy is my math off.. Oh well! I run -12 because it slipped over the stock return with the end flange cut-off.. I just figured it sounded right! Thanks for the clarification.
Old Mar 9, 2005 | 01:16 PM
atihun's Avatar
How would running a (1) -10 line from the bottom of a turbo to a -10 Y to split into (2) -10 lines be more restrictive? Using a correct type of Y connector such as:
I already have one of these for the fuel lines, and there is no way this is restrictive.
Old Mar 9, 2005 | 01:19 PM
dubulup's Avatar
development
how do you plan to route a drain to the rear drain?? my manifold is definitely in the way...
Old Mar 9, 2005 | 01:28 PM
jreynish's Avatar
New Project on the Way...
One oil drain line of -10 AN but -12 is preferable, would be more than sufficient.
Old Mar 9, 2005 | 03:02 PM
c00lduke's Avatar
I was thinking of doing this but my manifold would be in the way also and would worried about the path not being at enough of a decline. My -12 seems to be doing the job.
Old Mar 9, 2005 | 03:37 PM
dubulup's Avatar
development
agreed.
Old Mar 10, 2005 | 04:25 AM
highspeed101's Avatar
I've seen that -10/-12 arguement on here quite a few times...i want to clear it up. The -10 lines DO NOT fit over the stock oil return line. I bought both and just sold the -10 on ebay. It didn't fit...no way no how, not if you bench 500 lbs and force that sucker. Its a -12.
Old Mar 10, 2005 | 07:08 AM
mark57's Avatar
Temple of Cornd0g
The I.D. of -12 line is greater than 5/8", but the I.D. of -12 fittings is 5/8". -AN sizing refers to the O.D. in 1/16" increments.
I've posted photos of the -AN fittings and line I used to fab up lines for my car and several others. Remember, the turbo drain line is gravity return and must be w/o kinks, loops, fitting restrictions, etc. that would inhibit gravity flow. I use -3 for oil feed line. And, as someone mentioned, it's inadviseable to use a restrictor.
I know I've been vocal on this topic; I've seen several turbos ruined due to poor oil line fabrication and routing performed by "professional experts" that resulted a huge amount of out-of-pocket expense and down-time and aggravation for the customer.
Old Mar 10, 2005 | 10:12 AM
GQMRacerX7's Avatar
AN sizing and explanation
http://www.holley.com/HiOctn/ProdLin...S/ANsizes.html
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
