Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
My Budget Peripheral Port/80mm Turbo/60mm ITB/Intake Manifold/Fuel System Build
Old Jun 6, 2008 | 02:52 AM
  #176
Trjackson's Avatar
Originally Posted by ChrisRX8PR
If this is true then an apology is in order. I was not intending to cause any offenses, just trying to help.
I've run into so many people on forums that assume stuff and de-preciate other's work that I thought this was one of those instances.
My sincere apologies to NOPR.
DelSlow...Still impressed
Chris
No apology needed. Personally, I like it when forum members "stick up" for other members they have never met before. I also like that you didn't take/don't take other people work for granted.
In all seriousness, I wish we had more forum members who conduct themselves just as you do.
Jackson
Old Jun 6, 2008 | 08:38 AM
  #177
NOPR's Avatar
Rotary Apprentice
Chris
haha no worries. Its true sarcasm is hard to read on the internet. I (like crispeed) just get a kick out of all the people who seem to think that the tools Nate has access too are what make his **** so awesome, and anyone with similar access could whip out the same stuff. The truth is that his charming good looks are the key to his power.
Old Jun 6, 2008 | 08:39 AM
  #178
NOPR's Avatar
Rotary Apprentice
Originally Posted by crispeed
Oh!
I guess he got his hands on one of those replicator things that they have on board the Starship Enterprise!
i heard he bought it on ebay!
Old Jun 6, 2008 | 01:47 PM
  #179
marcus219's Avatar
FC Mobsta
Don't forget knowledge!
touche my good man, touchheee
(cartmen voice)
Old Jun 6, 2008 | 04:34 PM
  #180
Azcamel's Avatar
Put it in her butt
one question, why not make your custom manifold so your turbo turns the other way, easier piping and cleander engine bay look.
Old Jun 6, 2008 | 09:48 PM
  #181
DelSlow's Avatar
Hot Dicken's Cider
I'm a little worried about the intake manifold clearance too. When I made the exhaust manifold I didn't consider that I might be doing a PP. I have some 2.5" CLR bends, but if I can't make it work I might just make a long-tube exhaust mani and put the turbo further up. I am starting on the manifold tonight, so we shall see.
As for the machining stuff, it's really not that difficult at all. Having the right tools really does make a big difference. I would be willing to bet any technically minded person could learn enough to do this stuff in under a week. Most of the machining is done on manual machines; usually only get to use the CNC equipment for irregular interpolations and such.
^I'm not quite sure what you mean about the manifold design, I can just loosen one v-band clamp and clock the compressor in any orientation I want. That position was the easiest to route at the time.
Old Jun 9, 2008 | 05:44 PM
  #182
JDMpurest's Avatar
Newbie
^^^^^i think he means the compressor outlet is pointed down towards the frame rail, keeping the piping out of sight.
Old Jun 10, 2008 | 12:23 AM
  #183
peachykeenwight's Avatar
marky
.. yeah, and DelSlow was saying he can easily adjust it to point wherever he wants.
Old Jun 15, 2008 | 12:51 AM
  #184
rowtareh?'s Avatar
I Dislike Everything
I really really like that oil pan! You should make them for 13B-RE/REW's. You would make alot of people happy.
I am going to pick your brain a little bit in the next few weeks. I will PM you tomorrow about your build up, I need to read through some more.
Good job so far. Top notch work!
Old Jun 15, 2008 | 09:05 PM
  #185
DelSlow's Avatar
Hot Dicken's Cider
^ I'd be happy to answer any questions you have but remember that I'm not exactly sure what some of this will do. Hell, it might not even work at all.
Anyhoo, I got the intake manifold tacked up, still have a shitton of welding to do. The intake manifold does fit, but it is very close to the turbine so I will make a spacer for the turbo and make some heat shielding. I will be relocating the alternator to the side of the motor. I also have to machine the fuel rails and mounts; I should have those finished up this week along with the throttle bodies.
A few pics, thanks to Furloaf for being a welding fixture monkey:
Old Jun 15, 2008 | 09:29 PM
  #186
B6T's Avatar
B6T
ERTW
Amazing work! It's refreshing to see an engineering student who is just as capable with their hands as they are with their brains. Most of the Eng guys at my school are just nerdy geeks who happened to be good at math and science and who couldn't assemble a barbeque, let alone do what you have done!
What kind of people do you work for that let you use all their equipment?!?! I used to work at an aerospace manufacturing company with about 50 different CNC machines and if I even asked to use their equipment, they'd probably fire me! I have so many designs I want to machine out of actual metal! You're a lucky SOB, that's for sure!!!
Old Jun 15, 2008 | 09:37 PM
  #187
DelSlow's Avatar
Hot Dicken's Cider
Heh, well they don't actually KNOW that I'm using their equipment. My co-workers don't mind and I work on this stuff after my boss leaves.
Old Jun 15, 2008 | 10:23 PM
  #188
rowtareh?'s Avatar
Are you going to be running this on pump gas, or just going to go straight methanol? I did not read through if you were using an intercooler or not?
I guess I can pick your brain some once you get everything running correctly and you have gotten the car tuned. The though has crossed my mind to do a periphreal port turbo setup in a 76 Cosmo, but like you said there is not much information out there for P-port turbo setups.
Old Jun 15, 2008 | 10:56 PM
  #189
NOPR's Avatar
Rotary Apprentice
oh my god hurry up already.
Old Jun 23, 2008 | 09:04 PM
  #190
RotorRyan's Avatar
garage queen
this is 100% amazing. i bow down to you.
Old Jun 24, 2008 | 09:38 AM
  #191
Aaron Cake's Avatar
Engine, Not Motor
Once again, very nice work. That intake manifold sure worked out well...
Where are you planning on locating your fuel injectors?
Old Jun 24, 2008 | 04:22 PM
  #192
Viking War Hammer's Avatar
*** Bless The USA
dang
Old Jun 24, 2008 | 06:08 PM
  #193
red87tll's Avatar
needs a cheaper hobby
keep going, i need more pages of this **** to drool over....
Old Jun 24, 2008 | 10:29 PM
  #194
rotorholic's Avatar
DPG Burnout
WOW, best machine work that I seen on here......
Old Jun 24, 2008 | 11:39 PM
  #195
siguy2k's Avatar
SLEEPER
Yea everything looks awesome. Cant wait to see some videos!!!
Old Jul 4, 2008 | 05:21 AM
  #196
Chaotic_FC's Avatar
that is absolutly amazing
it inspires me to go down a very similar path...
Old Jul 5, 2008 | 03:53 AM
  #197
SVXT6's Avatar
Newbie
beautiful work. wish i had the skills 2 do work like that and that good too.
keep up the good work
Old Jul 6, 2008 | 10:29 AM
  #198
2-N-D-pink's Avatar
rx7parts
Old Jul 7, 2008 | 07:23 AM
  #199
DelSlow's Avatar
Hot Dicken's Cider
Intake manifold is 95% complete, I ran out of gas over the weekend so I wasn't able to finish welding on the injector bungs. I still have to weld on two vaccum bungs after the TBs as well. I don't like the way the fuel rail mounts look, so I will be doing some more machining on them and using different bolts. After that I just have to finish up the throttle body linkages and make a new intercooler pipe and the intake will be done.
Old Jul 7, 2008 | 07:42 AM
  #200
Havoc's Avatar
pics !!
