The FD Restoration - $$$$ Damnit
Old Jun 16, 2009 | 11:54 AM
  #1001
aoc007's Avatar
Cool, thanks. btw are you running the synapse FPR?
Old Jun 16, 2009 | 01:06 PM
  #1002
Nope, waiting for Peter to get around and finish R&D of the SC004 pressure regulator. Talked to him a few months ago and he said it will be awhile.
Old Jun 26, 2009 | 12:55 AM
  #1003
aoc007's Avatar
Yea I talked to them the other day and they said they dont know if it will even be out this year, I'm thinking about taking the OEM version and custom fitting it to my aftermarket setup.
Old Jun 26, 2009 | 02:48 PM
  #1004
Prometheus's Avatar
Still got it.
C'mon when are you gonna tell em...
Old Jun 26, 2009 | 03:33 PM
  #1005
Lol, when it's a rolling chassis. But you pulled the cat out of the hat, soo...
Hey everybody, Marc and I just bought an 1993 R1 chassis. I get the chassis to make into a race car and Marc get the interior, etc. and will be selling them shortly. Need to put a new front clip in, which comes with the purchase, just need to remove the heavily damage front end that on it now.
Peace
Old Jun 26, 2009 | 04:44 PM
  #1006
1MZFE's Avatar
1988 Mazda RX-7 SE
Peace
I heard how cheap you got it too, you bastard.
Old Jun 26, 2009 | 05:15 PM
  #1007
Yeah, that was all due to Jeese working on him before I event met the guy who was selling it. Jeese's finders fee made it worth his while.
Old Jul 1, 2009 | 06:48 PM
  #1008
bobbok's Avatar
Peace
Ooooh....
Old Jul 2, 2009 | 07:11 PM
  #1009
Josh18_2k's Avatar
wtf, you need an FD for each hand? you gonna drive them at the same time?
Old Jul 3, 2009 | 03:44 PM
  #1010
JordanRykon's Avatar
Kunta Kinte's RX7
^^^ RIGHT?? Who is this god of a man to have two raced out FDs lol
Old Jul 3, 2009 | 04:15 PM
  #1011
Prometheus's Avatar
Still got it.
Front clip is mostly stripped, I'll get back on it on Monday.
Old Jul 14, 2009 | 10:24 AM
  #1012
Update
Removed the 99 spec bumper and will be fitting up and installing the GTC bumper this week.
Sprung a leak on the driver side oil cooler, no visible signs of damage so will have to pressure test it to see where the leak is. Kinda of unusual, anyways I will see if it's repairable. In the mean time I line looped the system so I'm running with only one gigantic oil cooler.
Also, just recently installed the fast reacting Triumph AIT sensor, will see if they're is any noticeable change in the tune with the more accurate air temp readings. This will help great with sudden changes in air temps when I eventually put an AI system in the car.
This same week I will be removing the sound deadening off my R1 chassis to get it prepped for the new front clip. By the end of next week I should have a rolling chassis.
The clay modeler has completed one side of my front diffuser and is currently work on a mirror copy this month. If all goes to plan I should have my custom front splitter/diffuser done by mid August. Then the rear diffuser and the adapter piece that will allow my front splitter to be used on a 99 spec/stock front bumper.
Peace
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc07555.jpg   The FD Restoration - $$$$ Damnit-dsc07556.jpg   The FD Restoration - $$$$ Damnit-dsc07557.jpg
Old Jul 14, 2009 | 12:47 PM
  #1013
Also bought a JDM tranny from Japan2LA, this unit has the 0.806 fifth gear ratio. Now I need the 4.3 or 4.44(FE) rear diff gear and I will be set.
JDM tranny
First Gear: 3.483
Second Gear: 2.015
Third Gear: 1.391
Fourth Gear: 1.000
Fifth Gear: 0.806
OEM Tranny
1st: 3.483
2nd: 2.015
3rd: 1.391
4th: 1.00
5th: 0.719
Old Jul 14, 2009 | 12:59 PM
  #1014
islanders_rx7's Avatar
Hey Adam pm me what it cost shipped
JDM tranny
First Gear: 3.483
Second Gear: 2.015
Third Gear: 1.391
Fourth Gear: 1.000
Fifth Gear: 0.806
OEM Tranny
1st: 3.483
2nd: 2.015
3rd: 1.391
4th: 1.00
5th: 0.719
Old Jul 14, 2009 | 01:22 PM
  #1015
Japan2LA's Avatar
USDM 5th .796
JDM 5th .806
Closer 5th gear than USDM
Old Jul 14, 2009 | 02:28 PM
  #1016
Contact Japan2LA for shipping cost, I had it shipped to my work since it's a commercial address.
Originally Posted by Japan2LA
USDM 5th .796
JDM 5th .806
I checked multiple sources and they all say .719 is the fifth gear ratio for the USDM tranny.
Old Jul 14, 2009 | 05:59 PM
  #1017
Josh18_2k's Avatar
saw these and thought you may be interested.
http://www.v8rx7forum.com/parts-ever...0-shipped.html
Old Jul 14, 2009 | 07:47 PM
  #1018
CrispyRX7's Avatar
Polishing Fiend
Hey Adam, are those temp strips on top of the TB? If so what kind of peak surface temps have you seen on the outside of the TB?
Thanks,
Crispy
Old Jul 15, 2009 | 12:51 AM
  #1019
Damn that's a good price for those tires.
130F on thermal temp strips at the throttle body. Saw an 80 degree drop at the boost silinoid after applying the gold heat shield.
Old Jul 15, 2009 | 06:20 PM
  #1020
Brent Dalton's Avatar
Sua Sponte
Car is looking great as always Adam. Look forward to seeing the race car build as well.
Brent
Old Jul 18, 2009 | 08:45 PM
  #1021
Gorilla RE's Avatar
GorillaRaceEngineering.co
Adam,
A few questions: What is the engine oil type and viscosity your currently using? And what, if any oil modifications have you made to the engine "block"/pump? And lastly, what are your oil pressures at idle and through the rpm range? Thank you for your answers dawg!!!
-J
Old Jul 19, 2009 | 01:25 AM
  #1022
Seth W's Avatar
Manlaw hater
looking good still planning on more time attack events?
Old Jul 20, 2009 | 05:03 PM
  #1023
Originally Posted by internal comsucktion engi
Adam,
-J
Redline Full Synthetic 20W50
Ported and smoothed out all the oil ports on the block. Mainly eliminating flash from the casting process.
No pump mods done at this time - may go dry sump in the future.
Idle pressure ~ 30-40 psi
Cruise ~ 80-105 psi
WOT High rpms ~ 110-120 psi
Will be doing the AR track day at PIR next Thursday and will be doing the Aug 7th AutoX at Packwood with the PCA club.
Adam
Old Jul 20, 2009 | 11:55 PM
  #1024
Seth W's Avatar
Manlaw hater
cools, so the 30th? with any luck I'll have the car done so jason and me will check it out
Old Jul 21, 2009 | 02:50 PM
  #1025
Alright started mocking up the GTC bumper and everything doesn't quite fit. Will need to do some tweaking before sanding and paint. This week is going to suck....
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc07564.jpg   The FD Restoration - $$$$ Damnit-dsc07567.jpg   The FD Restoration - $$$$ Damnit-dsc07569.jpg   The FD Restoration - $$$$ Damnit-dsc07577.jpg   The FD Restoration - $$$$ Damnit-dsc07572.jpg
