New turbo GT4094R
Old May 17, 2007 | 09:36 AM
  #51
sk8world's Avatar
Chasing numbers
Let me know Sean! Thanks for the info GoRacer
Old May 21, 2007 | 09:19 PM
  #52
2FAST7S's Avatar
Can someone send me a pm on how much this kit is??? I'm interested in the 40R but curious about this one now.
Sean, how long does it take to get a kit?
Old May 21, 2007 | 11:03 PM
  #53
sk8world's Avatar
Chasing numbers
I can not provide numbers (hp) yet on my kit but I can say you will be very happy with the quality. Sean does very nice work.
Old May 29, 2007 | 01:01 AM
  #54
sk8world's Avatar
Chasing numbers
Sean, Any news on my DP? When should I expect it?
Old May 29, 2007 | 11:32 AM
  #55
Zero R's Avatar
Just in time to die
Hey Mike the DP as it the coaters just waiting for delivery then off to you.
-S-
Old May 29, 2007 | 01:24 PM
  #56
sk8world's Avatar
Chasing numbers
-S-
Sean, Did you add the second bung? Also I need a longer oil drain line, what size is the one that came with the kit?
Old May 29, 2007 | 09:26 PM
  #57
Old Slow Coach's Avatar
Front Range Express
I'm curious what efficiency level this is at 30 psi. Do you know? Thanks!
Old May 31, 2007 | 07:15 PM
  #58
Zero R's Avatar
Just in time to die
Effifiency can be effected by many things but the general area would be 71-72% eff.
-S-
Old Jun 1, 2007 | 08:17 PM
  #59
Zero R's Avatar
Just in time to die
That line is -10 it shouldn't need to be any longer??? Also yes additional bung added. The DP will be leaving monday as it arrived from coating after UPS pickup.
-S-
Old Jun 5, 2007 | 11:48 PM
  #60
sk8world's Avatar
Chasing numbers
oil drain line.
Sean, I went over it tonight again and I can not see any possible way unless I was to use the old oil extension to make it work. It is just too short. No matter how he center section is aligned it comes up 1-2 inches too short and that is bending the hose pretty good. I think it needs to be 2 inches longer and have a 9o degree fitting ti make the turn. You can see the fitting that I put together to try and make it work. It worked just leaked.
Attached Thumbnails New turbo GT4094R-dsc01344-300x305.jpg   New turbo GT4094R-dsc01345-300x305.jpg   New turbo GT4094R-dsc01347-300x305.jpg   New turbo GT4094R-dsc01348-300x305.jpg
Old Jun 5, 2007 | 11:55 PM
  #61
sk8world's Avatar
Chasing numbers
you see by the first pic the fitting is located close to even with the exhaust inlet. You see by pic 2 that I come 2-3 inches short of the manifold/ turbo mounting point. This is also pulling it too tight and having it touch the front runner. I need a 12-14 inch drain line.
Old Jun 10, 2007 | 02:10 AM
  #62
sk8world's Avatar
Chasing numbers
Ok, the new DP fit perfect. Much differant then the first one sent. The oil return line was too short so i bought a 90 degree fitting and a -10 female to female connector and that fixed it. So I am good now. Dyno numbers soon!
Old Jun 11, 2007 | 04:10 PM
  #63
Zero R's Avatar
Just in time to die
Mike, I am in the process of getting new oil return fittings made out of aluminum once I do I will send you set to try out. They will be pretty nice units that are all aluminum and have -10 male ends.
-S-
Old Jun 13, 2007 | 12:42 AM
  #64
sk8world's Avatar
Chasing numbers
sounds good...
Old Jun 13, 2007 | 07:33 AM
  #65
Can't wait to see the results Mike, I hope to see the car in person at next year's DGRR
Old Jun 14, 2007 | 11:04 PM
  #66
sk8world's Avatar
Chasing numbers
Rich, I am 100% sure I will take it to the gap next year! You going to make the trip back down again?
Sean, Are you sure the spring in the Tial wastegate was .9 bar? I have not been able to run below 16.5 psi yet. Wastegate is hooked up correctly and boost control turned off and still 1.14bars at 5300rpm.
Old Jun 15, 2007 | 09:14 AM
  #67
Zero R's Avatar
Just in time to die
The chances of it not being .9 bar are slim if you want to confirm it, it will be a large blue spring. A boost reading can be effected by where you source it. We tried on one car here as a test to see the difference, and on three different sources off the UIM we got three different readings at the same time, on the same run, showing a 3psi variance. Gauge, boost controller, and Map/ECU all read different.
-S-
Old Jun 15, 2007 | 10:37 AM
  #68
sk8world's Avatar
Chasing numbers
Ok. I think I will go over my lines as well since the one going to the profec inside is 6+ years old!
Old Jun 28, 2007 | 12:38 PM
  #69
sk8world's Avatar
Chasing numbers
Sean, I ran it today with top of gate going to manifold and side of gate vented. I made many pulls today and kept seeing peaks around 1.18-1.20. So 17.psi. Do they make a 17.5 psi spring?
Old Jun 28, 2007 | 12:39 PM
  #70
sk8world's Avatar
Chasing numbers
I guess I can just pull it out tonight and check the color also.
Old Jun 28, 2007 | 01:29 PM
  #71
BDC's Avatar
BDC
BDC Motorsports
You sure that's not backwards? Top of gate being the one that faces the rear bumper, side of gate facing either fender of the car...
B
Old Jun 28, 2007 | 01:35 PM
  #72
sk8world's Avatar
Chasing numbers
Brian, My gate faces down. So when I say top I mean the very top of the gate (faces down on my set up). Is this wrong?
Old Jun 28, 2007 | 04:50 PM
  #73
Zero R's Avatar
Just in time to die
You need to run manifold pressure to the sideport on the gate, this port is on the valve side of the diaphragm. The top port (spring side) is used for when you put the boost controller on. It is irrelevant to WG orientation. The side port on the gate is the side port on the gate. Just run that first see where your at. It is a 13lb spring, it might see 16lbs as some have and some have not. If it winds up giving you more of a lower boost setting than you want then I can get a lower spring sent out. Anywhere from 2.9lbs on up.
-S-
Old Jun 28, 2007 | 11:06 PM
  #74
sk8world's Avatar
Chasing numbers
ok, I will give that a try...
Old Jun 30, 2007 | 11:25 PM
  #75
sk8world's Avatar
Chasing numbers
ok, side port to UIM, top vented and 1.20 bars max. So it must be a 17.5 spring?
