Building Peripheral Port housings
Old Oct 18, 2007 | 05:57 PM
  #451
rx413b's Avatar
hi
Scalliwag , very nice work indeed , what happen to post #69 pictures
cya
Old Oct 24, 2007 | 07:48 AM
  #452
DelSlow's Avatar
Hot Dicken's Cider
This is a stupid question, but once you have decided upon the port timing you want, how do you accurately translate it into dimensions on the rotor housing?
Old Oct 24, 2007 | 07:26 PM
  #453
C. Ludwig's Avatar
www.lms-efi.com
Degree wheel would be the best way.
Old Oct 24, 2007 | 07:42 PM
  #454
Jay7 Nyc's Avatar
wow great thread, i'm glad to see some of the experienced guys getting involved in this thread...
Jay7...
Old Oct 30, 2007 | 01:58 PM
  #455
DelSlow's Avatar
Hot Dicken's Cider
Is there any way to accurately predict the powerband based on port timing? I'm attempting to design a peripheral port for a boosted application that will only be revving to 8500, but there is very little information on RX7club and NoPistons about the subject.
I might just wing it based on what I personally think might work and hope for the best...
Old Oct 30, 2007 | 04:30 PM
  #456
Kenku's Avatar
spoon!
Depends on what you mean by "accurate". You can copy what other people have done and fudge here and there. Actual accurate prediction involves computer modeling.
Old Oct 30, 2007 | 04:45 PM
  #457
DelSlow's Avatar
Hot Dicken's Cider
I suppose just a general idea, like say X port timing should make peak power around 7-8k with a very good midrange.
The problem with copying is that very few people are actually willing to share detailed information about their setup and the results they achieved.
Old Dec 9, 2007 | 09:32 PM
  #458
Kenku's Avatar
spoon!
Pics to be posted after I take them, but finally buckled down and cut the S5 housings I have sitting around for PPort. Timing's about median between old style and new style MFR housings (that is to say, the numbers in that paper I keep bringing up) and looking at 1 3/4" ID on the tube. Which, yeah, may be on the smallish side compared to what some are doing, but I'm figuring on something roadrace/street oriented.
I'm figuring of doing a lot of dyno mule work on the intake/exhaust, as I'm fairly sure that's where gains are... hell, pulling my head out of my *** and looking again, on ye Maz paper, runner length and diameter played a lot larger part in shaping the powerband than timing. But hey, who knows.
Incidentally, I got sick of bottoming out the hole saw, so just chucked up a 1.5" end mill I've got sitting around and used that to make more room. Rough cut the hole with the holesaw, then used a boring bar to finish the hole to diameter, and open up the rest of the housing to tube OD. Made a nice press fit.
Old Jan 14, 2008 | 03:57 PM
  #459
DelSlow's Avatar
Hot Dicken's Cider
Did a bit of layout work to see how the port I was thinking of using would compare to the MFR port and to find out what the port timing would be.
The port I designed has almost the same port area as the MFR, would close at the same time as the MFR port, but would open 15 degrees later. I have been advised to increase the port radius's and open it earlier.
Any predictions for the performance of this port and advice to improve upon it to match my goals? Any thoughts on entry runner angle?
Finding port timing with degree wheel:
MFR port:
Square port I'm thinking about using:
Old Jan 14, 2008 | 11:59 PM
  #460
ultimatejay's Avatar
Looks good. What is the characteristics of the square port vs the round port?
Old Jan 15, 2008 | 07:07 PM
  #461
BLUE TII's Avatar
Rotary Motoring
I have read Mazda used square port for qualifying as it flows more but must be kept at high rpm to keep velocity up.
Round port for racing as it has good overall power due to same timing but more velocity in lower rpms.
Turbo applications may be able to use a big square port and keep the rpms low enough for race reliability.
Old Jan 20, 2008 | 10:24 PM
  #462
I am going to make some p-port housing for my 12a. It looks like the norm for 13b outer diameter is 2". What is a good diameter for the 12a since the housings are 10mm thinner?
Old Feb 11, 2008 | 04:55 PM
  #463
apexFD's Avatar
This thread is friggen insane.
You guys are damn brave haha.
I would like to see a PP with custom irons, becuase really you dont need those thick *** irons if you have a PP intake.
=Ben
Old Feb 11, 2008 | 05:10 PM
  #464
calculon's Avatar
On flats
hmm. . . that's an interesting idea that I hadn't yet considered. Anyone know if anybody has done anything like apexFD just mentioned. . . thinner intermediate(s) and a shorter e-shaft.
Old Feb 11, 2008 | 05:23 PM
  #465
BLUE TII's Avatar
Rotary Motoring
Well- of course, you still have to cool the surface of the sidehousings somehow so there may be a limit on how thin you can go.
I believe the NSU P-port production engines cooled the housings with radial flow instead of Mazda's axial flow, so that is one possiblility.
It might help to use aluminum for its superior heat transfer with a sprayed on wear surface like early Mazda 10A production engines and its new 16X concept.
Old Feb 18, 2008 | 04:41 PM
  #466
warwickben's Avatar
Registered shy guy
what do you guys think of this. i found the pic on the net. not this is back yard p porting.
http://www.geocities.com/izzmus/shotgun/shotgun.htm
Old Feb 20, 2008 | 08:17 AM
  #467
raceralexuk's Avatar
It's probably already been posted in this thread, but I don't have the patience to traul through it, but where can I buy factory peripheral port housings for a 13B?
It's for an FD3S motor but I guess it won't make a difference if I get second gen peripheral housings?
Old Feb 20, 2008 | 09:05 AM
  #468
calculon's Avatar
On flats
that intake is an abomination. . .
Old Feb 20, 2008 | 03:07 PM
  #469
warwickben's Avatar
Registered shy guy
thats the frist thing i thought of when i saw it. how about the door screen used as a oil baffle.
Old Feb 20, 2008 | 04:45 PM
  #470
rotarygod's Avatar
Rotors still spinning
Wasn't that Peejay's setup? It belongs to someone on the forum.
Old Feb 20, 2008 | 05:11 PM
  #471
warwickben's Avatar
Registered shy guy
iam not bashing it i just thought the screen was funny. wish he updated the web page and talked about how it went. the last thing on his page about it was ready to install.
Old Apr 12, 2008 | 05:39 PM
  #472
peejay's Avatar
Old [Sch|F]ool
http://www.youtube.com/watch?v=FR9hHHJKJA0
Friday, as it happens:
Goal is the next rallycross on the 20th.
Old Apr 23, 2008 | 06:20 PM
  #473
DriveFast7's Avatar
Blood, Sweat and Rotors
Did it start? Howz it run? That's a big squre port you've got there.
Old Apr 23, 2008 | 06:28 PM
  #474
warwickben's Avatar
Registered shy guy
how did it go
Old Apr 25, 2008 | 07:32 PM
  #475
peejay's Avatar
Old [Sch|F]ool
http://www.youtube.com/watch?v=Tr7vU3cbH6E
I should explain the screen. I had two reasons for it: first and most practical, I removed the screen on the pickup tube and bellmouthed it, and I am somewhat paranoid about random junk getting sucked into it and mangling the oil pump, so I figured the screen would protect against that sort of thing. Second, I was hoping that any air bubbles would get broken up and/or stay above screen level, to help ensure that the oil the pickup saw was "solid".
It was a lot of fussing around. This time, I just used an unmodified pickup. I'm not winging the engine up real high, the stock oiling system is good enough.
