Kevin Wyum's IC pipe test fitting - airpump friendly
Old Dec 10, 2004 | 08:08 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Kevin stopped by to test fit his 'airpump friendly' IC pipe on my street car.
Here are pics I took:
some of the pipe:
some of it on my car during the test fit:
some shots of airpump clearance and tower bar clearance:
Old Dec 10, 2004 | 08:30 PM
BlueRex's Avatar
Looks good. Is that and M2 intercooler? Any other stock mount intercoolers that he will be making piping for?
Old Dec 10, 2004 | 08:43 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
that is Kevin's ASP intercooler
Old Dec 10, 2004 | 09:03 PM
Kevin T. Wyum's Avatar
None
The M2 Intercooler is actually the Kevin Wyum ASP Racing IC : ). I had a contract with M2 to let them make copies of both of my intercoolers for a number of years. They wanted to use their shop name which was fine with me.
We made this pipe to be pretty universal, not just for my IC's. Of course the first function was for it to fit with my IC's with the airpump in place and to clear the OEM strut tower brace without scraping etc. The unfortunate reality before was that the stock setup uses 2-3/4" tube diameters and a rule of thumb is that you cannot bend tubing on a sharper radius than its diameter. Because of that you could never make a tubing based pipe that didn't cut real close to hitting the strut tower bar, hood etc. because the bend coming out of the turbo Y pipe was too sharp to make with tubing, hence all this effort of a new cast pipe.
The universal part comes when we talk about people using front mounts or a lot of other IC's, on the twins, being forced to use the OEM flat plastic tube that goes around the inside of the airpump and forces a lot of extra tubing bends, which is not a desirable thing. They could now use this pipe to make a much straighter path to their IC while still having good clearance for the brace and hood etc. The best way to think of it is to imagine routing your IC piping from where my ICs start at with a coupler. It should be a much better flow path as I mentioned. Well the pictures above should explain it best.
Thanks Damian for posting those. I'm not nearly as web handy and sure admire his fancy camera : ).
Kevin T. Wyum
Old Dec 10, 2004 | 09:19 PM
Kento's Avatar
2/4 wheel cornering fiend
Looks great, Kevin. I guess good things really do come to those who wait, eh?
I'm going to have to get my Efini flange welded to that thing, I guess....
Old Dec 10, 2004 | 09:20 PM
AgentSpeed's Avatar
BNR built motor and twins
Looks pretty. It would be a nice piece for the folks that have the air pump.
Old Dec 10, 2004 | 10:47 PM
artowar's Avatar
FD3SW211E55
Ditto, Kento-- have you got a line on a good welder?
Old Dec 10, 2004 | 11:14 PM
Jason's Avatar
The one
Wow, looks good Kevin
Jason
Old Dec 10, 2004 | 11:22 PM
the_glass_man's Avatar
Will u do me a kindness?
Airpump???
Old Dec 10, 2004 | 11:34 PM
the ancient words's Avatar
solution: cut the y-pipe down
Attached Thumbnails Kevin Wyum's IC pipe test fitting - airpump friendly-pic1.jpg
Old Dec 10, 2004 | 11:57 PM
None
That actually looks pretty nice. Is that the Efini Y pipe and flange?
Kevin T. Wyum
Old Dec 11, 2004 | 12:10 AM
it's not the greatest pic and my engine bay could use a good cleaning, but, no, that is a bone stock y-pipe cut down and re-fit with a flange....really cleans up the turbo to IC connection....like I mentioned in another thread, my boost creep went way up after installing this modified y-pipe so I'm confident the flow significantly increased, relative to the half collapsed coupling and "s bend" M2 pipe I ran before
Old Dec 11, 2004 | 05:18 AM
scratchjunkie's Avatar
sexy no jutsu
wow, where can i order one?
Old Dec 11, 2004 | 10:32 AM
DamonB's Avatar
That, ladies and gentlemen, is how it's done
Also notice how the walls of the casting are still pretty thin. Looks great.
Old Dec 11, 2004 | 11:05 AM
JaNusSolSumnus's Avatar
TRINGLS
Originally Posted by the_glass_man
Airpump???
Thats what I thought.
I'd like to see a similar version for the Enfini pipe for cars without the airpump... althought I'm not sure how many would be interested.
I would love to have a nice quality pipe like that running strait over and into the IC... as it looks now the Greddy FMIC has too many bends because of that thing that I'd like to negate.
~Kris
Old Dec 11, 2004 | 11:19 AM
7racer's Avatar
Kevin That looks great! Congrats on all the hard work.
Damian. I have a Rx7fashion airbox that is similar to the older M2 boxes. This causes a shift of that pipe more toward the drivers side. Do you know anyone who can test fit that pipe in a car with a airbox?
Old Dec 11, 2004 | 12:53 PM
None
It's not just for the airpump. It alao makes a much straighter path for anyone that uses the stock pipe running by the alternator.
Kevin T. Wyum
Airpump???
Old Dec 11, 2004 | 01:07 PM
iluvmy3rdgen's Avatar
I live in a Museum
Kevin T. Wyum
So howmuch??
Old Dec 11, 2004 | 01:13 PM
None
I'm having an extra 10 or 15 made with the first batch, I do intend on selling them alone as well as part of the kits. Pricing will be $185 since I need to recover the costs of the pattern and prototypes in the next year or so and this is really small volume stuff. Bulk orders or vendor deals will be available. Shops should call or email me directly for arrangements. I'll probably just use a paypal account for direct credit card payments. I don't see setting up another merchant account just for this.
Kevin T. Wyum
Old Dec 11, 2004 | 04:03 PM
artowar's Avatar
FD3SW211E55
$185 ? I've already been charged $205. How heavy is this thing?
Old Dec 11, 2004 | 04:24 PM
None
It's not a flimsy piece by any means. Damian's first reaction was, "This thing could be a weapon." It's along the lines of the stock cast parts maybe a little tougher. The foundry didn't want to be too thin because of pitting during the casting process and possible leaks since it's for a pressurized application. I was definately surprised how strong it is but don't have a small scale for this kind of thing, I'd guess a couple pounds.
Kevin T. Wyum
Old Dec 11, 2004 | 04:30 PM
artowar's Avatar
FD3SW211E55
Kevin T. Wyum
I know that you'd never foist a tinfoil POS on us I'm just making a crack about what I've apparently been charged for shipping....
Old Dec 11, 2004 | 04:50 PM
None
Oh sorry. I don't have anything to do with that part. I just sold everything to Jason as a bulk order. Yeah I misunderstood as well : )
Kevin T. Wyum
Old Dec 12, 2004 | 12:01 PM
sexy no jutsu
i'll give you $200 for it! let me know where and how i can pay you.
Old Dec 12, 2004 | 12:46 PM
silverflash2's Avatar
Kevin, I'll buy one now, I have a ASP race IC, but my piping is for a single, all i need is this pipe then i can install my IC, Please sell it to me !
