The AI Dyno Thread... Pump Gas Only
Old Oct 20, 2009 | 11:52 PM
SENZA PARI's Avatar
After some recent research there's reason to believe there's less than 380cc's of meth currently being used. We're waiting to hear back from Coolingmist on this...
A little scary considering the power levels, but at the same time quite amazing given its been making 600+ for 2500 miles now.
Also amazing is the amount of potential still waiting to be extracted... More fuel, more meth, new manifolds, custom Eshaft and center plate. Then turn up the boost to match and 800 rwhp on pump almost seems too easy.
Sick numbers rx72c...
Originally Posted by jdmfantasy
619 at 24 psi w/ meth injection. More details in the other thread....
https://www.rx7club.com/showthread.p...42+full+bridge
Old Oct 24, 2009 | 05:57 PM
929 cosmo dude's Avatar
howard, can you make this into a leaderboard, i think there is gonna be alot more big numbers to come, it would make it easier to read
Old Nov 14, 2009 | 11:49 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
here's a few 4th gear SAE dyno pulls from july. best was 506.94 call it 507. done at the max from my wastegate spring which was 20 psi. this was w my twin TO4 setup and my FJO two 700 CC/Min AI system on methanol and 93 pump. knock was under 10.
currently building a single turbo setup for 2010.
hc
Old Dec 14, 2009 | 01:20 PM
black06g85's Avatar
that random guy
haven;t dyno'd with the meth yet as I just installed it saturday, but previous on pump gas was 383whp at 12psi w/ 11.4:1 afr
now on 15psi and a 12.1 afr dropping to 11.8. hoping to hit the dyno again after the holidays.
and that 383whp was on enzo's dyno dynamics setup.
going out on a dyno jet next time out will redyno old setup and new for comparison.
Old Dec 14, 2009 | 02:24 PM
rx72c's Avatar
Why are you running such lean afrs?
Bring it into the low 11s at least.
Old Dec 14, 2009 | 08:48 PM
BDC's Avatar
BDC
BDC Motorsports
With you on that one.
B
Old Dec 15, 2009 | 05:40 AM
black06g85's Avatar
that random guy
yeah adjusting that this weekend.
Old Dec 15, 2009 | 02:36 PM
rx72c's Avatar
Also. You should go back to dyno dynamics so you get back to back power reading change.
Dynojet is going to be completely different.
Old Dec 16, 2009 | 05:41 AM
black06g85's Avatar
that random guy
yeah I know, but I live almost 200 miles from enzo's shop. that's quite a drive. I'll do a base run on what I was tuned at with the meth off, then see where it goes from there.
Old Dec 16, 2009 | 02:35 PM
rx72c's Avatar
Ok thats fair enough.
Just make sure you do that. Love to see how you go. Make sure you keep us posted.
Old Dec 17, 2009 | 06:04 AM
black06g85's Avatar
that random guy
will do, trying to find some time after new years to get down there. Got a few projects I'm working on at the moment so time is a bit limited
Old Jan 14, 2011 | 04:12 PM
hey guys i threw my car up on the dyno on thurs night, just a 13b mild port, scr seals, with a chinese GT45 (69mm comp wheel) also its through a big stall auto so that kills the power a bit, has RR water injection and crane CDI, lol it made 300.0rwkw on 19psi, i turned it up and it smashed the tires on the dyno, the operator was saying i was holding it flat too quickly or some ****.. broke a strap and got over it.
http://www.youtube.com/watch?v=YVhYM...layer_embedded
and of a bit of wheelspin on the dyno
http://www.youtube.com/watch?v=eRV_C...layer_embedded
http://s1.postimage.org/ih4kzfswv/DSCF0657_300rwkw.jpg
Old Jan 14, 2011 | 07:12 PM
300 rwkw is 402 hp... don't know if that is SAE or STD... there's about a 10 hp diff around 400
Old Jan 15, 2011 | 07:31 PM
dunno if the dyno is SAE or if it has STD's , but it's a brand new twin inhibitor dyno dynamic's, i know there alot harsher than the one's you guy's have over there, by feel it has alot more power than the 350rwhp it had on a mainline dyno(even harsher) before.
Old Feb 5, 2011 | 10:08 AM
thelevman's Avatar
thought id add a couple little videos of my car
water injection test on low boost
http://www.youtube.com/watch?v=sDxxV...eature=related
early stages of tuning
http://www.youtube.com/watch?v=hKVo5...eature=related
testing on private track
http://www.youtube.com/watch?v=BsZv4QvgHgw
Th0m4s
Feb 26, 2019 02:04 AM
Rotospectre
Mar 28, 2018 03:33 PM
stickmantijuana
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
Clacor
Aug 14, 2015 09:17 AM
