Latest Experiment…Failure!
Old Jun 30, 2008 | 06:26 AM
  #101
Barry Bordes's Avatar
"Elusive, not deceptive!”
Looks really nice Adam.
Are you using the TB (Throttle Body) heater line for something? If it is just by-passing the exhaust side of the engine I would plug it.
Barry
Old Jun 30, 2008 | 11:03 AM
  #102
Barry
Throttle body heater line at the back of the motor is plumbed back to the thermostat housing. Explain your reasoning? Maybe I'm missing something.
Old Jun 30, 2008 | 09:24 PM
  #103
My thought is, why bypass any cooling fluid past the exhaust side of the engine? The least resistance rule would rob cooling water from the engine. That reminds me, doesn't the heater core bypass water also?
Barry
Old Jul 1, 2008 | 11:42 AM
  #104
Barry
The heater core does bypass water and lots of it. I don't know, if Mazda did it right they would have took into account the throttle body heater line and heater core line, and as such they're really isn't much to be gained by blocking off both. The main reason I jumpered the TB line to the front is to allow a passage for air to escape the system that would otherwise be trapped at the back of the motor. It is the second highest cooling point on the motor.
[/QUOTE]
[/QUOTE]
Old Jul 1, 2008 | 03:13 PM
  #105
Yes a very good place to burp the system. Still how much water flow can we afford to bypass?
Nice looking fuel pressure sensor. Your engine really is gathering bling! The gold foil looks so trick.
Barry
Old Jul 1, 2008 | 03:20 PM
  #106
An inline restrictor pill would allow burping but limit bypass flow at the TB line.
As far as the heater core.....an inline shut-off valve?? Though, I really don't want to do that. I'll give this some thought.
Racing Bling Baby
Old Jul 1, 2008 | 03:31 PM
  #107
Racing Bling Baby
Yes RBB,
Maybe a restrictor in the heater line also, that way the heater core would be less likely to corrode.
Barry
Old Jul 1, 2008 | 11:22 PM
  #108
dj55b's Avatar
good to see a thread with this much good updates on there ... where do you spot that gold shielding though?
Old Jul 2, 2008 | 12:41 AM
  #109
Viton restrictor pill in. And here's your gold shielding pic.
[/QUOTE]
[/QUOTE]
Old Jul 2, 2008 | 06:56 AM
  #110
Simple but elegant.
Seals well, no corrosion.
I usually rap a piece of colored tape around the restrictor location to remind me of its presence.
Barry
Old Jul 2, 2008 | 11:31 AM
  #111
Good idea on the tape, I might do that.
You know what would be cool is a compact electric motor actuated shutoff off valve that would be used at the return line for the heater core. I can easily get them, but they're bulky and ungodly expensive; especially the stainless steel units.
Or just do a manual one:
http://www.rcaccessory.com/index.asp...ROD&ProdID=267
http://www.speedwaymotors.com/p/7911...ff-Valves.html
http://www.pexsupply.com/product_dtl...droPEX&cID=347
Old Jul 2, 2008 | 01:55 PM
  #112
Viking War Hammer's Avatar
*** Bless The USA
damn, looks like you're off to the moon with all that foil !
Old Jul 2, 2008 | 03:09 PM
  #113
Funny, your not the first to make the space flight comment.
Old Jul 2, 2008 | 09:46 PM
  #114
I like that idea. We could easily switch off/on to test for any improvement. Plus when we get a cool front.......
Barry
Old Jul 5, 2008 | 09:25 PM
  #115
I was talking with Chuck Westbrook today and he brought up an interesting question. Has anyone using synthetic oil seen the carbon spots on both sides of the spark plug holes?
Chuck’s contention was that since the housing gets to be 400şF wouldn’t it be logical for there to be carbon produced in that area.
Very true, since mineral oils die before that 400şF.
My thoughts were that the seal would soon wear it off if the housing was flat in that area, and that the hot spark plug boss was the problem for the stains and possibly the main cause of apex seal breakage…..
Anyway has anyone using synthetic oil not seen the carbon stains?
Barry
Old Jul 6, 2008 | 01:33 AM
  #116
Gorilla RE's Avatar
GorillaRaceEngineering.co
Barry,
If you recall my auto engine ran on synthetic oil before I got it.... Still had the black marks.
-J
Old Jul 7, 2008 | 10:35 AM
  #117
Originally Posted by internal comsucktion engi
Barry,
-J
True, anyone else?
Barry
Old Jul 21, 2008 | 09:30 PM
  #118
ronbros3's Avatar
most localized overheat causes an actual bubble to form at the plug area, bubble can not transfer any heat away from that area, and temps skyrocket in only that area, wont show on temp gage, I use Evans coolant does not allow bubbles to form,400* boiling point. no water at all to boil. and my water pump mods,might not work for everyone. but used a machined S4 pump with a big impellor from a 1975 Cosmo pump, very hi volume and hi pressure flow. YUP! did these mods about 10yrs ago. Thx Ron
Old Jul 22, 2008 | 01:26 AM
  #119
dj55b's Avatar
curious how much does that gold shielding reduce intake temperatures? I've got a new heatshield in there but still is hotter than what i'd like. Also who make it? also do you use any special gaskets inbetween the engine and the intake to reduce temp transfer? Sorry to get a bit off topic ...
Old Jul 22, 2008 | 11:16 AM
  #120
Ronbros,
Thanks for the tips on the water pump.
The extra flow from the pump would be a big help. Is the impeller on the 1975 Cosmo pump the same as the newer RE engine's pump?
Barry
Old Jul 22, 2008 | 12:58 PM
  #121
ronbros3's Avatar
I dont know if the RE impellor is the same as 1975 Cosmo imp, cosmo imp was about 3/8 " larger in diameter, than S4 turbo pump, made of cast iron so could be polished and shaped, had to machine the housing to make it fit with a tite clearnce, as i remember the s4 had a pretty wide clearence, like 1/8", tighter you can make it more pressure the pump can make, volume you get from the diameter, and smoothing things out to enhance flow. its all basic hotrod ideas from the last 40-50yrs. when you get guys thinkin they can come up with good S#^T, the internet has just sped up all the info. Thx Ron
Old Jul 23, 2008 | 03:16 PM
  #122
neit_jnf's Avatar
Are you referring to the 1/8” groove cut between the housing running surface and the bolt hole boss.
Good example,dj55b, it looks like the larger 16X housing allows larger cooling tunnels.
Barry
just a quick correction here, the 16x housings are the same external size as the current renesis. The internal size is what increased for the larger rotor thus making the rotor housings "thinner" and the cooling passages smaller in the perpendicular direction.
the 16x is shorter also, with the narrower rotors; and much lighter since its all aluminum...
Old Jul 24, 2008 | 06:38 AM
  #123
jantore's Avatar
Barry what do u think has happend here?
My old housings did not look like this at all, this housing is brand new, and has maybe 30-40 hours on them. Now i should say that im running BUR9EQP on E85 on this engine. And also using a castor based 2 stroke syntethic oil. I used to use AGIP 2 stroke racing oil before and my old housings look realy good.
Jan-Tore
Old Jul 24, 2008 | 08:52 AM
  #124
dj55b's Avatar
Hmm i remember reading somewhere tha they stated that it was wider and heigher than the pre-existing 13b engines.
Old Jul 24, 2008 | 11:15 AM
  #125
Nope same external profile to the 13B.
Update:
EGTs were dead nuts when on the dyno, note I'm running a GZ LIM, but still it's looking like the front and rear rotors are pretty close as far as AFRs.
Only minor coolant blow-by at the lower earl fitting on the rear rotor. Will be going to a more flexible setup later.
My timing curves are still conservative at this time, once I have more time to spend on a dyno to finish the maps I will post what I was able to acheive before I experience minor knock. As it stands I'm at 400whp and 300 ft-lbs at 15psi on pump with premix.
This weekend will be a true stress test a far as coolant performance with the Time Attack. Wish me luck!
Adam
