e11 running nitrous question
Old Sep 3, 2007 | 08:04 PM
Xcentric's Avatar
GRINCHY
My e11 won't activate the relay to run my nitrous. I have it in normal mode
acting as a ground. I fiddled with all the parameters so it would activate
under light throttle just to test the solenoids. When I reverse it to inverted
and 12 volts, it activates constantly- sending 12v constantly.
Worse case scenario, i'll run a window switch and wide open throttle
switch externally. Anyone seen this before? btw I'm using pmw #1
Old Sep 4, 2007 | 01:47 AM
crispeed's Avatar
'Tuna'
Did you set up an AUX in to let the ecu know that the Nitrous system is armed?
You should post this in the ecu forums.
Old Sep 4, 2007 | 04:51 PM
Xcentric's Avatar
GRINCHY
ok, will try- thanks
trickster
Jul 1, 2023 04:40 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
