The FD Restoration - $$$$ Damnit
Old Feb 17, 2008 | 07:18 PM
  #701
Nick_d_TII's Avatar
Thats a healthy fuel system! What kind of pump? Are those fans gonna pull enough cfm and hold up to the elements? Are they for cool down after some track runs?
Wow, Keep up the great work.
You should get the Most Improved RX thread award!
Or Most hrs and $$ spent in 12 Mo's award!!
Old Feb 18, 2008 | 11:46 AM
  #702
Bosch 044; It a sealed fan so the elements are covered, and it is for cool down after some track time runs or stop and go traffic. It's only rated at 330 cfm at 13.5 volts. Which will be activated either by temperature switch or by my fan switch I have in the cabin.
Thanks for the props. Most hours and $$ spent in 26 months is more like it.
Midpipe finished and lastly need to extend the WG outlet tube. I'm going to add some shielding to the WG body to help it out on the temp side. Bobby added louvres to my wheel well plastics to improve air evacuation on the oil coolers. In person they look pretty good.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09293x.jpg   The FD Restoration - $$$$ Damnit-dsc09294x.jpg   The FD Restoration - $$$$ Damnit-dsc09297x.jpg
Old Feb 19, 2008 | 02:19 AM
  #703
WG outlet done and in, the pipe is the lowest point of the chassis. Bobby also fab'd up a heat shield to protect the secondary injector and electrical wiring. IC and Airbox next.
Attached Thumbnails The FD Restoration - $$$$ Damnit-img_1592x.jpg   The FD Restoration - $$$$ Damnit-img_1594x.jpg   The FD Restoration - $$$$ Damnit-img_1597x.jpg   The FD Restoration - $$$$ Damnit-img_1598x.jpg   The FD Restoration - $$$$ Damnit-img_1599x.jpg
Old Feb 19, 2008 | 04:21 PM
  #704
Looking at the hours needed to complete this car and Tune it, I won't be able to make the 24th track day. But I will be able to make the March 1st event.
Things to do:
IC Mounts, endtanks & ducting, Air Box & Vacuum Lines, Catch tank final fit up, wiring harness re-routing, Cooling system block off seals, final engine reassembly, compressor housing mod for improved routing to IC, Second BOV install & recirc routing, front bumper cut & buff, oil cooler ducting, adjust lights, street then dyno tune, emissions, then register vehicle and finally get custom vinyl stickers made. ~50+ hours
Old Feb 19, 2008 | 09:47 PM
  #705
MWMburton's Avatar
vinyl stickers??? what r they gonna say, "my rx-7 is better than any car ever concived by man!" lol jk.
Old Feb 19, 2008 | 10:12 PM
  #706
The Spyder's Avatar
Never give up!
Things to do:
50 hours my ***, I only see like 7 things that need to be done so you could drive it, lol.
Old Feb 19, 2008 | 10:59 PM
  #707
Maybe if I was driving on the street doing quick bursts, yes. Overheating at a track when pushing it is a given, all just a matter of time. Besides I gotta look good doing it, or what's point...kidding.
The vinyl stickers are: car number, electrical shutoff, and few other ones I need for other racing events this year. This doesn't take that long, just another thing I got to take care of.
Old Feb 21, 2008 | 12:20 PM
  #708
Top end coming together. The catch tank in in all the lines routed including the line to the rear secondary turbo oil drain. Bobby, just say no to crack, mmkay.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09325x.jpg   The FD Restoration - $$$$ Damnit-dsc09332x.jpg   The FD Restoration - $$$$ Damnit-dsc09326x.jpg   The FD Restoration - $$$$ Damnit-dsc09319x.jpg   The FD Restoration - $$$$ Damnit-dsc09331x.jpg
Old Feb 21, 2008 | 09:04 PM
  #709
cartapex's Avatar
Booby! I was wondering why I have been finding cigarette butts all over the parking area of the shop!
Old Feb 22, 2008 | 12:37 AM
  #710
MWMburton's Avatar
so wheres this fancy oil resivoir for premix u told me about or is this still in the process of purschase
Old Feb 22, 2008 | 10:59 AM
  #711
Still in the process of deciding if I really need it faze. If I went to a Motec ecu unit, it would be a prerequisite. And it's not just a reservoir, http://www.rotaryaviation.com/oil_in...p_adaptors.htm
Well progress being made, the long task of making an aluminum Airbox and IC endtanks has arrived. Going to seals unlimited today to get some specialty seals.
As discussed by other 500R owner a sacrificial 9/16" wrench is needed in order to tighten one of the nuts. All hail to the turbo Gods.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09350x.jpg   The FD Restoration - $$$$ Damnit-dsc09352x.jpg   The FD Restoration - $$$$ Damnit-dsc09354x.jpg   The FD Restoration - $$$$ Damnit-dsc09356x.jpg
Old Feb 22, 2008 | 02:15 PM
  #712
zeroecco's Avatar
look at it this way, your ride is going to blow the doors off of most cars. period. I would even say a 600+ hp maserati will have a hard time keeping up. take your time man, if you do not take it slow I swear that murphy's law will catch up with you, and thats sucks big time (I lost six motors because I was being stupid)
Old Feb 22, 2008 | 02:42 PM
  #713
Nick_d_TII's Avatar
Originally Posted by zeroecco
... (I lost six motors because I was being stupid)
Rly? six. Rly? Maybe you just misplaced them? I can help you look for them. J/K
Almost looks like a sattelite under there w/ all that gold and shiny stuff.
Secretly, this things a spaceship... probably costs about as much. j/k
Seriously, thats one cramped engine bay. Looks excellent tho...
Old Feb 24, 2008 | 09:39 PM
  #714
Slowly but surely. Need to finish the endtanks, weld in the Second BOV flange and start cutting up the 4" tubing for the air box.
Peace
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09371x.jpg   The FD Restoration - $$$$ Damnit-dsc09374x.jpg   The FD Restoration - $$$$ Damnit-dsc09375x.jpg   The FD Restoration - $$$$ Damnit-dsc09379x.jpg   The FD Restoration - $$$$ Damnit-dsc09380x.jpg
Old Feb 25, 2008 | 11:55 AM
  #715
IC endtanks done, not totally happy with how they turned out so these will be classified as version 1.0. Will see how they perform and make new ones down the road if needed. Space limitations were a real limiting factor. Need to setup and finish the mounting arrangement of the IC and work on the air box setup.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09381x.jpg   The FD Restoration - $$$$ Damnit-dsc09386x.jpg   The FD Restoration - $$$$ Damnit-dsc09388x.jpg   The FD Restoration - $$$$ Damnit-dsc09391x.jpg   The FD Restoration - $$$$ Damnit-dsc09393x.jpg
Old Feb 26, 2008 | 12:31 AM
  #716
MWMburton's Avatar
thats going to be a pretty awesome recirc system if thats what i am looking at, if not nevermind disregard lol. the endtanks look pretty good but i bet version 5 will be awesome lol
so how is this premix omp pump supose to work. it doesnt explain how it works in conjunction with your stock omp. . . wait nevermind figured it out hehehe. thats awesome, where in the world are you going to mount this?
Old Feb 26, 2008 | 10:49 AM
  #717
This will give you a better idea on the recirc.
Old Feb 27, 2008 | 02:02 AM
  #718
MWMburton's Avatar
so your tuning the bov to vent to atmosphere but taking that air and just putting it back to feed the turbo?
Old Feb 27, 2008 | 11:33 AM
  #719
Yes, when the BOV discharges, it blows pressurized air at the compressor and if done right makes it spin faster for a short period. The byproduct is it improves turbo response between shifts.
Intake tube done, next up final IC mounting, IC ducting, temporary airbox/rad block-off, fluids and start her up.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09403x.jpg   The FD Restoration - $$$$ Damnit-dsc09405x.jpg   The FD Restoration - $$$$ Damnit-dsc09407x.jpg   The FD Restoration - $$$$ Damnit-dsc09411x.jpg   The FD Restoration - $$$$ Damnit-dsc09413x.jpg
Old Feb 28, 2008 | 11:57 AM
  #720
Well, Bobby and I went to the wee hours of 3am last night, but didn't quite get done. Bobby is still working on the temporary aluminum duct for the IC. So tonight finish that, check fluid's, finish block-offs and start tuning. Anybody want to be my high on ramp spotter while I do some triple digit pumps.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09414x.jpg   The FD Restoration - $$$$ Damnit-dsc09416xx.jpg
Old Mar 1, 2008 | 06:11 PM
  #721
Well bad news, the wg did not open on my first pull and I overboosted to 34 psi and blew the apec seals on my rear rotor and destroyed the turbine the 500R. I am in the process of talking to Synapse on the malfunction/mis-information.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc09445x.jpg   The FD Restoration - $$$$ Damnit-dsc09431x.jpg   The FD Restoration - $$$$ Damnit-dsc09432x.jpg   The FD Restoration - $$$$ Damnit-dsc09433x.jpg
Old Mar 1, 2008 | 09:38 PM
  #722
The Spyder's Avatar
Never give up!
Its bad. Its really bad.
I fingered his exhaust port before he started pulling the motor a few hours ago... its bad...
Old Mar 1, 2008 | 09:44 PM
  #723
islanders_rx7's Avatar
Damn Adam....Sorry about that!
Old Mar 2, 2008 | 02:14 AM
  #724
DeclareYrWar's Avatar
Miss_My_Rotary
wow man, thats terrible. be sure to let us know what happens with synapse. my company works pretty closely with peter and the guys down there, good people. im sure they'll get everything worked out.
Old Mar 2, 2008 | 03:53 AM
  #725
RX72NR's Avatar
paying to play
Damm bro, that sucks. Hope you get everything worked out. -Matt
