would an 87 T 2 engine bolt up to an 87 n/a tranny
Old Aug 17, 2007 | 03:30 AM
bshumate2003@yahoo.com's Avatar
MAZDASPEED
jw?
Old Aug 17, 2007 | 07:30 AM
cps87rx7se's Avatar
Swap the flywheel from your N/A to the Turbo II, and you should be able to use the rest of your N/A drive line after you do that. This is what a reilable person posted to me.
CHRIS
Old Aug 17, 2007 | 07:45 AM
pfsantos's Avatar
(blank)
See above...but note that even if it fits (I won't confirm this), it may be too much power for the tranny to last a while.
Old Aug 17, 2007 | 08:38 AM
HendrixJr's Avatar
You would want to go with a TII tranny, the N/A tranny, like pfsantos said wont last too long
Old Aug 17, 2007 | 09:58 AM
killinit937's Avatar
when i went to pick up my motor the guy had an n/a tranny bolted up to a s4t2 motor.
it had the n/a flywheel clutch and pressure plate. so it will deff work you just have the shatter effect if your lucky enough
Old Aug 17, 2007 | 11:08 AM
cps87rx7se's Avatar
I wasnt saying that the tranny would hold up! (Maybe low boost and no hard launches!) Just stating the fact that it could be done for him.
Old Aug 17, 2007 | 11:46 AM
GtSuper99's Avatar
ok, while we're on this topic. would there be a problem if we keep the NA rearend but use the T2 motor/tranny? meaning with 250-300ish horses...
Old Aug 17, 2007 | 12:05 PM
Force Fed's Avatar
Rotary Apprentice
What is the general power limit for an NA trans?
Old Aug 17, 2007 | 12:10 PM
djmtsu's Avatar
DGRRX
I know Landers was putting clost to 300hp into his with no problems.
Mine has been going strong for 2 years now with no issues.
Old Aug 17, 2007 | 12:14 PM
wvumtnbkr's Avatar
Sit and Spin
You could.
You can keep the rearend, but you must use an Automatic driveshaft. The automatic driveshaft is a little shorter than ideal, but it will work.
I think MazdaTrix also makes a driveshaft specifically for this application.
If you have an LSD rearend, I think it will hold up to 250-300 horses, but I wouldn't. Just swap over to a T II rearend. <-- that being said, I have never tried that much HP through one of these rearends so I should probably STFU and let somebody answer that has tried.
Old Aug 17, 2007 | 12:18 PM
topspeed7's Avatar
rx7doingeleven
i used my 12s motor on a gtu and it held up fine, all u have to do is install the na flywheel and clutch.
Old Aug 17, 2007 | 12:20 PM
fidelity101's Avatar
Rallye RX7
CHRIS
and the starter!
if your using the NA tranny and flywheel you need the NA starter.
Old Aug 17, 2007 | 01:03 PM
Aaron Cake's Avatar
Engine, Not Motor
As mentioned earlier in the thread, the TII engine will bolt up fine to the NA drivetrain if you swap on the NA flywheel and clutch assembly. That's all there is to it. Any 2nd gen engine will match any 2nd gen transmission as long as the flywheel and clutch are swapped to match the transmission.
As for the power handling of the NA drivetrain, I'm currently running 13 PSI on a GT40R on my bridgeported engine with an NA drivetrain behind it...
Old Aug 17, 2007 | 03:08 PM
djmtsu's Avatar
DGRRX
so fidelity101................where'd ya get yer hood?
sYnth.
Aug 19, 2015 06:27 PM
Wicked93gs
Aug 17, 2015 12:14 PM
ncds_fc
Aug 15, 2015 10:06 AM
