My new 73 Rx2!
Old Nov 25, 2015 | 11:53 PM
  #151
sen2two's Avatar
Rx2 > FD
Getting there....
Old Dec 12, 2015 | 08:41 PM
  #152
sen2two's Avatar
Rx2 > FD
Once again spending way too much time making a simple part complex. But hey, that's what makes it such an enjoyable hobby. But I need to stop messing around and get this thing to DGRR!
Fuel level sight gauge. There will be no electric level. I don't want to add wires and clutter if it's not necessary.
Starts off like this:
Drill holes for tapping. My lathe is down right now, so I did this all in the mill.
Then swapped to this collet block to make it look fancy
Old Dec 12, 2015 | 08:43 PM
  #153
sen2two's Avatar
Rx2 > FD
Plain vs. Fancy. I think it was worth the extra 30 minutes to do this.
Old Dec 12, 2015 | 08:46 PM
  #154
sen2two's Avatar
Rx2 > FD
Annnnnnnddddd..... Done. Time to put some gas in it and see if she runs! Hopefully, now that I can actually adjust my fuel pressure correctly, and it has a return line to not overrun the fuel bowl. It will actually run half decent. Instead of over flowing the float so bad the car would run for about a minute even after I disconnect the battery, lol.
Old Jul 27, 2016 | 12:13 PM
  #155
Medevack1's Avatar
Great Post!!
Old Dec 22, 2017 | 02:12 AM
  #156
MATT's Avatar
i am after an IDF inlet manifuold, do you have a spare to sell or know where one my be for sale?, cheers matt
Old Mar 9, 2019 | 09:03 AM
  #157
sen2two's Avatar
Rx2 > FD
Well... a little over 3 years since I have posted anything. Not much has been done in that time. most of it the car sat as I was unsure of the direction i wanted to take with the car. Now I have a decent idea. So... out comes the 12a street port. and progress on the Renesis PP build begins!
Dusty ol' Bitch. Time to get some love.
Old Mar 9, 2019 | 09:04 AM
  #158
sen2two's Avatar
Rx2 > FD
12a no more...
Old Mar 9, 2019 | 09:08 AM
  #159
sen2two's Avatar
Rx2 > FD
Mocking up the Reni-PP with some cheap headers. There will be some modification needed for them to fit. but saves me a ton of time on starting from scratch.
The engine is just kinda sitting there resting on the sub-frame. I will be pushing it back and keeping it about that low. The Renesis is about 1.5" longer than a normal 13b. So I wanted to keep the weight as centered as possible.
Old Mar 9, 2019 | 09:10 AM
  #160
sen2two's Avatar
Rx2 > FD
I am using a 51IDA Racing Beat Weber. This flange was for 48mm. So I needed to open up the bores some.
Done...
Old Mar 9, 2019 | 09:11 AM
  #161
sen2two's Avatar
Rx2 > FD
The start of the Intake manifold Build.
Old Mar 9, 2019 | 05:22 PM
  #162
JOE68's Avatar
good weberrrrrrr ..... somethings need to be left simple ..
Old Mar 11, 2019 | 04:12 PM
  #163
IamRobbyah's Avatar
wants some ube
Kudos to such an awesome build so far! I love that the old pics all still work too.
Old Mar 12, 2019 | 12:51 PM
  #164
sen2two's Avatar
Rx2 > FD
Intake manifold has been cut to size. I made it the shortest I plan to go, this way I can easily and length to the runners or the Velocity stacks to see if another length would give me more usable power.
The V-band connection might be an overkill. But, I wanted to give the Rx2 the quality it deserves. I do not plan to shortcut this car.
[img]https://i.imgur.com/chgOfOv.jpg[/img]
Old Mar 12, 2019 | 12:55 PM
  #165
sen2two's Avatar
Rx2 > FD
Few pics of the manifold mocked up (Not yet welded) with the Webers. The Webers are in good condition. But I plan to have them Powder Coated to clean up the look some.
Old Mar 14, 2019 | 09:01 AM
  #166
kutukutu1's Avatar
A beauty.
Old Mar 14, 2019 | 12:27 PM
  #167
rotorholic's Avatar
DPG Burnout
Them horns tall enough for you? intake looks clean but I wouldn't go solid mount on the engine if staying carbureted, that float bowl might splash fuel with heavy vibrations
Old May 23, 2022 | 11:09 AM
  #168
Snaple07's Avatar
I remember watching this RX-2 in an AutoX even in Sioux Falls SD in 2009-2010 & was trying to save up the money to purchase it, but I was too late. I was a really sad day, but I kept looking. Decade later I found another one in a lil rougher shape in Bennet Colorado and just scooped her up a couple weeks ago. Beautiful car man!!! you got any new updates?
chiefmg
Sep 10, 2015 07:46 AM
