wont go into gear
Old Mar 15, 2010 | 06:23 PM
dr phyco's Avatar
vert life
wont go into gear
brand spankin new clutch put in right, new pilot bearing, throw out bearing. fork is NOT bent and is on pivot ball. clutch feels really light. it was bled properly. it appears to be going all the way but not sure. slave cylinder or master bad? need help asap need it by running by friday.
Old Mar 15, 2010 | 09:57 PM
farberio's Avatar
NASA-MW ST4
Does it go into gear with the car off? Or does it never go into gear?
Old Mar 16, 2010 | 04:11 PM
dr phyco's Avatar
vert life
it goes in like butter while the car is off. i checked everything when i was putting it back together. i also cleaned the inside of the bell housing cause i looks like the rear main seal is a little leaky. but im gonna be doing a full jdm t2 swap later this year so i just need it to last until about August if not a little sooner.
Old Mar 16, 2010 | 06:04 PM
Turbonut's Avatar
If you shut the car off, put it in gear, try and start the car, the car will try and move, indicating that the main shaft is turning from either the clutch disc not releasing fully, or the pilot bearing is gone, which I doubt as it is new.
Look under the car to see if the fork arm moves when depressing the clutch, and has full travel.
Old Mar 16, 2010 | 06:14 PM
lonewolfrx's Avatar
try rebleeding your clutch slave. It might need to be bled again. If that doesnt work then it could be the pressure plate. Could also be clutch disc is too thick. I had a problem like that happen to me once on a honda crx. Changed the clutch with a new one and it wouldnt go into gear unless off. Took it out again to find out the clutch disc they supplied was too thick and wouldnt really disengage off the pressure plate.
Old Mar 16, 2010 | 07:37 PM
farberio's Avatar
NASA-MW ST4
This is more likely then you think, if the OP used a bolt to pull the trans together then the pilot bearing is toast.
Old Mar 16, 2010 | 09:46 PM
'88 s5 t2's Avatar
easiest way to see if your clutch is releasing is to watch the release fork move when someone is pushing the clutch pedal. no travel means no hydraulic pressure in circuit. if no movement, bleed clutch circuit again. if it goes through the gears fine with the eng off, that means the shift forks and hubs are moving properly. and if these things check out, chances are the pilot bearing is stuck to the input shaft.
there are some other things to check, but you will be doing that clutch job again to check them!
Old Mar 17, 2010 | 06:38 PM
dr phyco's Avatar
vert life
when i was putting it back in the transmission was supported and no weight was put on the input shaft and no play was on it. i greased up the bearing a good bit. i finally was able to see how much movement was on the clutch and it was minimal and the pedal feels really light. so im in the process of rebuilding my master cylinder. the rings around the piston are shot so i just need to get all this put back together. but an unfortunate thing is my water pump went so im waiting on that to come later today.
Old Mar 17, 2010 | 06:50 PM
ICEY?'s Avatar
this happen to mine awhile back, turned out a syncronizer went out in the trans.
Old Mar 17, 2010 | 07:01 PM
duo2999's Avatar
Pabs
make sure the lines arent leaking.
Old Mar 20, 2010 | 02:11 AM
dr phyco's Avatar
vert life
ok rebuilt the master. clutch feels fine but still wont go into 1-5 but goes in to r but ginds and wont fully go in. mechanic i talked to told me its mostly my synchros. so now for the search of a "new" s4 na tranny or might just do the t2 swap. if anyone has one please send me an pm. might see how much it is to have it rebuilt
Old Mar 20, 2010 | 07:34 AM
farberio's Avatar
NASA-MW ST4
How did you mate the trans? Did you use the bolt trick at all?
It sounds to me like you busted the pilot bearing instead of destroying all 6 synchos at once.
Old Mar 20, 2010 | 08:13 AM
SirCygnus's Avatar
whats going on?
clutch disc is on backwards.
Old Mar 20, 2010 | 09:43 AM
farberio's Avatar
NASA-MW ST4
^ or that
Old Mar 20, 2010 | 12:03 PM
dr phyco's Avatar
vert life
no bolt trick just slid right in and the clutch disk only is able to go in one way with the side that protrudes going in to the pressure plate.
Old Apr 1, 2010 | 04:24 PM
dr phyco's Avatar
vert life
take it from me. never trust a friends word. i would push in the clutch and he said the fork was going all the way but i had my dad push the clutch and its not going all the way. so ive already rebuilt my master now for stainless steel and either rebuild or new slave. then hopefully it will work.
Old Apr 10, 2010 | 01:13 AM
dr phyco's Avatar
vert life
ok really good news its going just fine. just need to adjust the pedal.
if anyone ever gets this problem.
ok put it in gear have the ebreak on and foot on the clutch. (i know sounds really bad but it worked) and start the car. my dad did this and he said he thinks the transmission was bound up for some reason. well that how he got it to work. i just wish i had known this a while ago. cause i would have been able to make it to the car show up in Pleasanton last month.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
