what wire to hook up power for e-fan?
Old Jan 12, 2003 | 01:59 PM
im lookin for the wire that i hook my electric fan up to so that the fan turns off with the car. anyone know where its at?
Old Jan 12, 2003 | 02:16 PM
Turblown's Avatar
Turn up the boost
There is one over by the leading coils(? maybe its trailing) either way the coil right by the front headlight. There is a green prong that is unused, just look for the wire that is black with a yellow stripe, that color is +12V ignition switched.
Old Jan 12, 2003 | 02:26 PM
dr0x's Avatar
pei > caek
Or just hook it up straight to the battery w/ an inline fuse. Then get the temperature switch from http://www.flex-a-lite.com/auto/electacc.htm
It turns on the fan at a given temp. So its not running when the car isnt on either.
Old Jan 12, 2003 | 02:31 PM
silverrotor's Avatar
I use the 6 plug connector that Is found at each Shock tower. This harness Is used for the AAS. Obviously not all 7's had this feature but Mazda designed It so It was readily available.
On the harness plug, you'll use the center one that Is opposite from the clip.
I use the Left one for my efan and the Right Is used for my fully blown electric auxilliary port rpm switch.
Old Jan 12, 2003 | 03:26 PM
dr0x's Avatar
pei > caek
I thought you broke your electric aux port setup?
Old Jan 12, 2003 | 03:30 PM
You mean a flopped project? Nah. The Air Compressor (AC) I used was not meant for long durations. I did, however, gain a "heavy duty: AC that still maintains the Integrity of the Auxilliary Ports. Right now, I can't complain.
Old Jan 12, 2003 | 03:35 PM
Jimmy325i's Avatar
No longer cares
Directly off the battery will keep the fan going untill the thermo switch cools below its switched point.
What I did was use an ignition switched lead to activate the relay which is inline with my thermo switch for the fan's power. Power is fused through the battery for the latching side of the relay. The the ignition power is fed to the coil positive and then the coil negative is fed through the thermo switch to ground.
This configuration is easiest on all components as there is no current running through the relay unless the fan is on, and there is very little current running through the thermo switch to potentially burn it out.
Old Jan 12, 2003 | 04:21 PM
Aaron Cake's Avatar
Engine, Not Motor
I recommend connecting it directly to the battery (fused, of course) and using a thermal switch and relay to activate it. It is the most reliable thing to do, completely automatic, and works very well. This is how I have my fan set up.
Old Jan 12, 2003 | 05:45 PM
Turblown's Avatar
Turn up the boost
yea me2, except i have my haltech controlling it. I just used a relay from the A/c.
Old Jan 12, 2003 | 07:45 PM
Digi7ech's Avatar
I break Diff mounts
I used fused line from the battery and a ignition wire from ther front of the car.
The one I used is right in front of the radiator. In the same bumper/compartment as the radiator overflow tank. I think it was a yellow wire. I just turned my key on and fished for ignition source.
I have a efan with temp switch. Now I am thinking of redoing it though so the keys don't have to be in to turn the fan on.
Old Jan 12, 2003 | 08:50 PM
Jimmy325i's Avatar
No longer cares
Yeah I found a wire up in that cluster as well for the ignition hot lead.
Old Jan 13, 2003 | 03:56 AM
NZConvertible's Avatar
I'm a boost creep...
Always wire up an electric fan via a fuse and relay, or you risk blown fuses, or worse, a fire. Like this:
A handy source for the switched ignition is the 6-pin diagnostic plug by the battery and leading coil.
Old Jan 13, 2003 | 04:42 AM
Jimmy325i's Avatar
No longer cares
My thermo switch connects to ground when closed. Threaded directly into water jacket on the thermostat housing. A little different than that schematic, but the same idea. I also used a 20A breaker from my parts bin rather than the fuse.
Good use of the a/c switch jason. I'm thinking about using it for the arm switch on my n20. (if I ever go that route)
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
