*** 1st Gen 1/4 Mile Leader Board ***
Old Jul 22, 2009 | 01:53 PM
  #176
jjbrozak's Avatar
I have a new 1/8 mile time. 9.03@77mph with a 2.1 60'. Sounds like my car and peejay would be a really good race. I ran that time on the stock gears though. Since then I have put the GSL-SE 4.08 gears in. Hoping that will make the difference. I really wish there was a 1/4mile track close by. I dont even know if Ill be able to make it back to the 1/8 this year.
Good NA run though peejay. Its nice to see another NA out there that will probably break into the 13s for sure with some traction.
Old Jul 23, 2009 | 08:38 PM
  #177
peejay's Avatar
Old [Sch|F]ool
13s will be in the bag as soon as I ditch the throttle body. I have seen as low as 85KPa at full throttle and high RPM. That's roughly 3-4" of vacuum! Atmosphere is normally 95KPa here.
Ideally I'd like an IPRA style intake manifold, but I will "settle" for a Holley 750-based throttle body with a suitably ported Holley style manifold. For now, I have a 75mm throttle body setup in the works, but first I must upgrade the fuel injectors. And buy some green Rolocs so I can finish cleaning up the plenum.
Oh and I killed another rearend.
Old Jul 29, 2009 | 11:08 PM
  #178
immanuel__7's Avatar
well i might as well post my new times.
Reaction ---+.5310
60Ft---------2.2001
330FT-------6.0567
Et@594-----8.6378
1/8-----------9.2018
1/8MPH-----79.78
1/4----------14.0222
1/4 MPH-----101.27
no traction in 1st and second.
mods:street ported 13BTII stock ecu, no tps, no o2 sensor. 6 psi boost. 3" exhaust.
going to install an ms in a few weeks hope things work out better
Old Aug 9, 2009 | 12:12 PM
  #179
NoPis10's Avatar
Committee Member #2
Here are some NEW times from my visit to the local 1/8 mile track in my TII powered 85 SE... Everything is better with the Mickey Thompson drag radials, only problem is it distroyed my LSD...
Reaction... .107
60'....1.89
1/8.... 7.77
Mph...95.7
L8R
Old Aug 9, 2009 | 12:21 PM
  #180
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
Nice times!
yeah....I'm not launching my car at the track cause i want to keep the rear together.
Old Aug 9, 2009 | 10:26 PM
  #181
TERVO's Avatar
A unique monter of a engine! The rotary....
SWEET! MY BEST TIME IN MY 12A WAS 8.1557 IN THE 1/8 MILE WILL POST 1/4 MILE WHEN I BRAKE THIS NEW REBUILT IN! CHECK THESE ROTARYS OUT WORLDS FASTEST ENJOY..... 12A 13B 20B BEAST OUT! http://www.youtube.com/watch?v=n0Ab4ABB9Fw http://www.youtube.com/watch?v=O1ZStKvjVTk 13B http://www.youtube.com/watch?v=cGkgEBXZLoM
Old Aug 16, 2009 | 09:03 PM
  #182
JTPERF's Avatar
finally took the car the track on drag radials, 85 gsl-se 13b turbo
reaction... .058
60'... 1.953
330... 5.400
660... 8.196
mph... 90.37
1000... 10.607
1320...12.637
mph... 113.52
Old Aug 27, 2009 | 02:53 PM
  #183
#garageguybuild
Veteran: Air Force
new time for me
12.3 @ 113 ..... I'm still at 12psi
I know i can get a high 11 out of her, just need to shift faster!
I'll post the slip tonight
Old Aug 27, 2009 | 07:05 PM
  #184
#garageguybuild
Veteran: Air Force
^ pic of my slip...... yeah i know red light!
Old Aug 27, 2009 | 07:51 PM
  #185
Viking War Hammer's Avatar
*** Bless The USA
How much do you and your car weigh?
Old Aug 27, 2009 | 08:16 PM
  #186
Jobro's Avatar
SAE Junkie
I went again last week.
On this first run I left the line at 2000rpm riding clutch and fed it throttle, normal tidy shifts and reved 4th gear to 8000+rpm as I crossed line (this rpm is above my peak power). Start didn't bog but you can see it was lazy.
60' 2.410
330' 6.160
1/8 9.096
MPH 84.00
KPH 135.19
1000' 11.576
1/4 13.645
MPH 109.20
KPH 175.74
and
On the 2nd run I left the line from 4000ish rpm riding clutch, not lots of throttle again. I didn't want a repeat incident of a snapped and twisted axle. Because the run felt so tidy I decided to flat change from 3rd to 4th gear, and then I decided I would see what happened to trap speed if I changed into 5th at end of peak power. I did the 4-5 change foot pretty much flat to floor again and still lost 3mph. Interestingly I was 1.17mph down at the 1/8th track even tho this run had a faster 60ft so I'm wondering if I hit a bad cell in tune and the car bogged.
Even in 5th gear I crossed the line at 6500rpm.
60' 2.355
330' 6.150
1/8 9.154
MPH 82.83
KPH 133.30
1000' 11.696
1/4 13.839
MPH 106.07
KPH 170.70
Both of those with no burnouts and conservative takeoffs. Mostly I wanted to see what it would trap.
Basically I realise I need either 4.1's or a taller tyre. I think I should get a better diff with 4.1's in it and worry about a slightly taller tyre when I have more HP. Seeing as the cars PB is still 13.362@103 with a 2.15sec 60ft I know I can get into the 12.99 bracket without more HP just with a stronger driveline.
Also sometimes when I'm racing (street) I bake the clutch by accident and it slips. So Really its coming back to the whole driveline needing an overhaul. 4.1 toyota hilux rear end with torsen or clutch LSD and a s5 turbo gearbox with a better clutch money I don't have at the moment
Old Aug 27, 2009 | 09:43 PM
  #187
#garageguybuild
Veteran: Air Force
Not sure, it has full interior + 3/4 tank of gas and me/180lbs last night
I think she is about 2800 but I'm not really sure
Old Aug 28, 2009 | 12:18 AM
  #188
Jobro's Avatar
SAE Junkie
My 1982 GSL is 2575 lb with me and a full tank of fuel (I weigh roughly 230lb)
This is with some stuff removed but full interior, stereo, turbo, 3" exhaust, 50lb battery in the trunk.
Removed air con, air pump, all emissions.
Old Aug 28, 2009 | 02:09 AM
  #189
Jobro's Avatar
SAE Junkie
new time for me
We have FC's over here trapping 125MPH on 15psi with that engine and turbo combo. Your tune must be VERY conservative. 12.3 is hardly a SLOW pass and this car has A LOT of potential left in it.
Old Aug 28, 2009 | 10:11 AM
  #190
#garageguybuild
Veteran: Air Force
^ yeah, I know the turbo/car has alot left in her.
It is a conservative tune, when I get a rear in (one day) i'll retune and trun up the boost!
Old Sep 28, 2009 | 11:29 AM
  #191
xdoomcannonx's Avatar
Anemic Hampster pwns
1979 sa22c 12 blowthrew carb t70 turbo 50mm waistgate 255lph fp 4309fpr large fmic aluminum custom rad and spal efan mild street port 84gsl trans and rear end on 225 50 zr 15,s ventus rs-2,s best run yest at ubly dragway in MI. 1.9179 60ft 5.4783 330 ft 7.9364 et at 594 ft 1/8 et 8.4863 1/8 mph 81.82 13.2910 1/4 et 101.96 1/4 mph lost to a 72 chevelle
on juice by .1708 but it was my best run of the nite backed it up with a 13.33 2 runs later
hope this gets me on the board o yeh and that was on 7 psi boost lol get some
Old Oct 28, 2009 | 07:45 PM
  #192
Electronblue's Avatar
BUY MY PARTS!!!
I ran a 9.2 in the 1/8mile
chevy 305 TransAm T5 Tranny, GSL LSD
Hankook rs-2 225/45
That was starting in 2nd gear (no traction to be found in first) so I had a 2.58 60ft (Bogged after launch)
Old Nov 2, 2009 | 09:36 PM
  #193
Bryan@BNR's Avatar
"your turbo source"
Hey all.
I went an 11.21 at 126.28 MPH on T67 at 19 psi. The car was sitting on 26 by 10.5 ET streets. Car has much more in it, as I was lift shifting. 10 second pass is coming soon! Had a 1.62 60 ft.
Major mods:
T67 at 19 psi
E6K
8.8 ford rear with 4.88's
REW street port
ET streets
Old Nov 20, 2009 | 10:38 PM
  #194
dj55b's Avatar
Not a quicker time, similar but now trapping a bit higher MPH:
Reaction - .2459
60 ft - 2.2521
330 ft - 6.2139
1/8 ET - 9.5250
1/8 MPH - 73.78
1/4 ET - 14.6781
1/4 MPH - 94.50
Hopefully when I do all my air cooling mod next year I'd get close to 100mph.
Old Nov 24, 2009 | 11:02 PM
  #195
Bryan@BNR's Avatar
"your turbo source"
I also forgot to tell you that I raced it with a cracked seal. It had 80-30-30 compression in the rear rotor. So 11.21 with a hurt engine .
Old Dec 7, 2009 | 08:13 PM
  #196
ProjectRX-7's Avatar
ProjectRX-7......82 GSL 17.206 @ 81.05mph 12a stock port, 2.5 in. Drift style exhaust, 3spd auto trans
Old Feb 6, 2010 | 09:20 PM
  #197
aerosev's Avatar
aerosev
1978 s1 rx7, 12a mild extend port, lightened flywheel, electronic ignition, standard carb(tuned) standard wheels, s2 lsd, otherwise stock
14.565 @ 92.4mph
Old May 22, 2010 | 06:06 PM
  #198
blown7's Avatar
Double Ds for me to share
My most current time from last year is 13.326 @ 100mph
Hoping for a 12 later this year with the new tune.
Old Jun 19, 2010 | 11:25 AM
  #199
Crazy Ivan's Avatar
First time out last night and I bogged it something fierce on the launch lol
R/T - 0.618
60' - 2.705
330 - 7.316
1/8 - 11.114
MPH - 66.60
1000 - 14.336
1/4 - 17.069
MPH - 82.26
85 GS, minor go fast mods include:
RB full street exhaust
Rats nest & air pump delete
GSL rear end
stock everything else
Old Sep 20, 2010 | 11:20 PM
  #200
1sgen's Avatar
583 rwhp 1st gen
60ft 1.488
330 4.475
1/8 7.01 @ 98.08mph
1000 9.125
1/4 10.869 @128 mph
pump gas @ 18psi
