** 1st Gen Dyno Sticky **
Old Aug 10, 2008 | 08:14 PM
  #76
aFBatw!'s Avatar
Noobist
110.77 hp
108.67 ft/lbs tq
better than i had expected but not great
85' gsl 12a stockport 101,000 miles, rb header strait back to *cough*flowmaster muffler, knn filter, and msd 6al dilfis(disconnected due to issues im currently trying to work out)
Old Aug 15, 2008 | 12:52 AM
  #77
blown7's Avatar
Double Ds for me to share
210 rwhp
150 ftlbs
Old Sep 7, 2008 | 11:58 PM
  #78
bstrange99's Avatar
unregistered rex offender
141.3 rwhp
139.6 ft lb
s4 6 port 13b, stock port, custom fabbed intake, Sterling carb, Racing beat street port exhaust system, gsl-se rear diff. 2gdflis.
And most imporantly.......two stickers with flames AND skulls.
Old Sep 26, 2008 | 07:23 PM
  #79
dj55b's Avatar
I've got 153.9 whp before swapping out the flywheel now ... will be going to the dyno for new numbers after the flywheel. I can't remember TQ right now, once i get the sheet i'll update on that too. Should be very close to 160whp thought with my SP 12a now
Old Oct 2, 2008 | 05:29 AM
  #80
EpitrochoidalPower!'s Avatar
dj55b umm a lightweight flywheel wont affect power figures, will make your car faster, but doesnt increase power, so if u just going to dyno to check increase rather save your cash, unless u going to tune some more then its all good
Old Oct 2, 2008 | 12:46 PM
  #81
purple82's Avatar
Absolute Power is Awesome
Originally Posted by blown7
210 rwhp
150 ftlbs
What's your set up?
Old Oct 3, 2008 | 12:29 AM
  #82
dj55b's Avatar
I've already dynoed it actually with the flywheel on there and there is a difference on the dyno. In the bottom end we saw about 20-30 ft-lb of torque diffence, the top end my TPS wasn't calibrated but with richer AFR (about mid 12's, best power when i was dynoing it was about 13.3) it did pretty much the same hp so there is some to be gained.
Old Oct 6, 2008 | 06:20 PM
  #83
djjjr42's Avatar
Registered Offender
The engine doesn't make more power, but the lighter flywheel allows more of that power to be used to turn the wheels faster rather than spinning around the heavier stock flywheel.
Old Oct 6, 2008 | 11:21 PM
  #84
dj55b's Avatar
I know that the engine itself isn't producing more HP but more is going to the wheels, and I think he was trying to say that I won't see the change on the Dyno as far as HP, but it did. Since you have more TQ to the wheels its directly translated to the dyno rollers.
Old Oct 6, 2008 | 11:34 PM
  #85
blown7's Avatar
Originally Posted by purple82
What's your set up?
13B-PP
weber 48 IDA with 46mm chokes
stock ignition
8lbs flywheel
act 6 puck clutch
GSL-SE rotors
12a transmission
4.44 rear gears
MFR intake manifold
header with dual 2" exhaust
Old Oct 10, 2008 | 12:02 PM
  #86
RX-7 Chris's Avatar
137 whp at 6500rpm
112 wtq at 6200rpm
12A streetport, RB holley setup, RB exhaust, RB lightweight steel flywheel.
this is at about 6800 feet above sea level.
Old Mar 2, 2009 | 04:09 PM
  #87
Hyper4mance2k's Avatar
The Shadetree Project
Bump bump bump!
1984 Base model
13b small streetport
48IDA weber
Hyper4mance Industries Exhaust
Mallory directfire igniton
light fly.
189.65 whp and 144.72 ft.lbs of tq.
Old Mar 8, 2009 | 06:32 PM
  #88
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
Heres a video of my car on the dyno last week.
She did 305@12psi before Ray my tuner had to stop becaus of CAS problems
The haltech would drop the CAS signal in the middle of some of the runs.
Once thats fixed ill be getting the tune completed and up th eboost to 15-16psi
Thanks for looking!
Steve
mods are, GT35R, Haltech E6X, S5 TII Streetported.
Old Mar 9, 2009 | 09:33 AM
  #89
#garageguybuild
Veteran: Air Force
^my dyno run
Old Mar 12, 2009 | 07:49 PM
  #90
Damn someone up date teh list!! I'm on top of the NA croud, well except for that one bridge on there. Until next time. I gaurentee you all a 200whp NA FB.
Old Mar 13, 2009 | 12:01 AM
  #91
dj55b's Avatar
As long as i get the top 12a on that list ... ill be fine btw ... i'm at 159.4 whp, trying to find my dyno sheet, hopefully its not on the damaged hard drive :S ... Once i get rid of my crush bent exhaust and have a cold air feeding it, I wouldn't be surprised to see about 170ish whp.
Old Mar 25, 2009 | 10:20 PM
  #92
lx_machado's Avatar
stock port 12a
holly
rb intake
rb exhaust
120 whp and 109 ft.lbs of tq.
Old Mar 26, 2009 | 08:16 AM
  #93
purple82's Avatar
Cool, now I've got a project for the summer. 191 RWHP!
Old Apr 5, 2009 | 08:13 PM
  #94
cincoletra's Avatar
170 rwh 85 GSL-SE 13B Streetport, Racing Beat holley 550, RB intake, headers, RB exhaust
Old Apr 23, 2009 | 08:36 PM
  #95
LongsTurboFB's Avatar
Rotor or No Motor
12A bridgeport not ran long and had low timing 87 pump gas and made 172.7RWHP and 124.1 torque So with more timing and good gas maybe 190 RWHP all motor.So here is the sheets.
Old Apr 23, 2009 | 08:39 PM
  #96
Rotor or No Motor
Talking Dyno sheets
Old Apr 23, 2009 | 08:45 PM
  #97
Rotor or No Motor
The car is all motor and the turbo is not going on it in tell it is broke in but I think that this is a very good start and just freekin look at the torque coure thats just awsome. The timing was low for the motor being new but soon I will get some more runs with the timing up and good gas. Then Put the T67 on and run some more
Old Apr 23, 2009 | 08:48 PM
  #98
bad 83's Avatar
PSHH! PSHH! HEAR ME NOW?
We had a really good day. Good run on the dyno makes Long a happy boy. Some pics of the port work I did for ya
Old Apr 23, 2009 | 11:36 PM
  #99
cbweed420's Avatar
ONE DRIFT
127 rwhp 112rwtq stock port 12a, oer 47 carb, rb header 5ft primaries,rb prima flow muffler
Old Apr 24, 2009 | 01:34 PM
  #100
cbweed420's Avatar
ONE DRIFT
83 gs
