RX-8 13B-RE conversion!
Old Apr 25, 2015 | 08:52 PM
  #376
Hock87's Avatar
that is the exact front bumper and hood look I want form my rew swap. I just need to find an oilpan solution to go with the rx8performance mount.
Old Apr 7, 2016 | 02:05 PM
  #377
Zhakler's Avatar
Newbie
Originally Posted by ChrisRX8PR
Quick update
Got the front cover off the Renesis so I could see what I would be dealing with installing this cover onto a BRE front plate. On Wednesday I fly to Puerto Rico for a week for business but while there will visit a friend that has a rotary shop. He has succesfully installed the Renesis front cover onto REW/BRE engines and with a bit of modification has gotten the Renesis OMP etc working properly so it doesn't require premix. From talking to him I know there will be a bit of clearancing required to get the front cover on simply because on the renesis the front counterweight is sunk into the front plate and on earlier models the counterweight is out into the front cover. He also said something about drilling an oil passage or something...we'll see.
Here you can see the front cover off the engine
Here you can clearly see how the front counterweight is sunk into the renesis plate
Another from a different angle.
I read the whole topic . I want to ask is it possible to do was insert section between the lid and the lid in the aggregate 13mm
Old May 6, 2016 | 10:07 AM
  #378
Schartz's Avatar
Duluth/Superior
Any updates on your car?
Old May 17, 2016 | 07:02 AM
  #379
Zhakler's Avatar
Newbie
Old May 21, 2016 | 05:17 AM
  #380
Zhakler's Avatar
Newbie
Old May 22, 2016 | 02:27 PM
  #381
Warrior777's Avatar
REW swap coming soon.
wow that is great. what are the specs for the spacers? Why the need for two?
Old May 22, 2016 | 03:29 PM
  #382
Zhakler's Avatar
Newbie
Laser does not take 12mm , That's why 2x6mm . in this case, and alternator good falls into place
Old Sep 28, 2021 | 01:42 PM
  #383
NathanJarvis's Avatar
New to the Club!
13b re transmission
Sorry to bring up a dead thread, but quick question.
Did you use a stock rx8 transmission for this swap? I'm currently trying to mate my 13b re with a series 1 rx8 trans using act 6 Puck clutch and pressure plate, prolite flywheel and 13b re stock counterweight. A new pilot bearing and release bearing also installed.
However, there seems to be a 2 inch gap around the trans and engine bellhousing. I'm pretty certain the trans input shaft is seated in the engines pilot as when cranking the engine (in gear) I can hear the drive shaft moving. I can also see a couple of nicks in the pilot bearing after taking the engine back out suggesting it was seated in there. When I measure the trans input shaft it seems as if its slightly too long - I.e its seating in the engine at the point where there'd still be a 2 inch gap from the bellhousing to trans.
I've been told the 6 speed rx8 trans should bolt up to this engine using an aftermarket flywheel and act clutch kit, while keeping the counterweight. The only thing I can think of is that I should be using a series 2 trans or I've missed something blatantly obvious.
Did you have any similar issues? Any help would be much appreciated.
Coochas
44
Nov 5, 2019 11:08 PM
