S475 widebody build....
Old May 2, 2010 | 01:25 PM
  #276
Islander's Avatar
Did a fluid change yesterday.
Idemitsu rotary oil, and tranny/diff fluid. I cant say i can really feel a difference, but atleast i know there is fresh fluid in there.
Got everything from Bryan at Rotorsports, he keeps it all in stock so that was a plus. The change was pretty easy, but i did have access to a lift and a very nice pump to get the fluid in.
Hopefully soon i can get one of their dual oil cooler kits. Very nice piece, he picked up a set of the custom made lines from Goodridge. Very nice pre-fabbed lines with all the fittings and the thermostat.
Old May 2, 2010 | 06:29 PM
  #277
BDC's Avatar
BDC
BDC Motorsports
Thanks for letting us know you changed your fluids, Neal.
Old May 2, 2010 | 07:56 PM
  #278
Islander's Avatar
^^^^ LMAO.. Man i try to contribute to this site as much as possible.. lol
Old May 2, 2010 | 11:10 PM
  #279
BDC's Avatar
BDC
BDC Motorsports
Talking
Hahaha!
Old Feb 27, 2011 | 05:37 PM
  #280
Islander's Avatar
Wow, haven't been in here in a long time. Maybe some care , maybe some dont. Lol
Took the car to the dyno. I did 466hp/367ft-lbs @ 19psi on Dynojet.
Old Feb 27, 2011 | 05:54 PM
  #281
13B-RX3's Avatar
7s before paint!!!
Nice numbers and a beautiful car!
Old Feb 27, 2011 | 07:37 PM
  #282
BDC's Avatar
BDC
BDC Motorsports
Awesome Neal!
Old Feb 28, 2011 | 09:05 AM
  #283
djseven's Avatar
Eh
Those numbers seem way low for that setup? Sure you dont have a boost leak somewhere or other issues going on?
Old Feb 28, 2011 | 09:50 AM
  #284
Islander's Avatar
I kinda thought my numbers were a little low also. Catch22 just dynoed his car a few days before and did 522@18psi.
Almost the exact same setup. I will check for boost leaks soon. But i was thinking that my tune is really conservative! It stays in the 10's and dips in the 9's around 7k rpm. Also I was thinking it could be my rear housing. I have a custom .80 rear housing and my exhaust wheel is 83mm. Not sure if that has anything to do with it, but I was expecting higher numbers.
Also........."you guys don't laugh and poke fun at me".... but I'm on straight pump gas, no AI. I never run it at 19 on the street, I stay at wastegate spring, 1 bar. I will try to check for leaks and any other issues.
Old Feb 28, 2011 | 04:52 PM
  #285
KKMpunkrock2011's Avatar
dorito powered
on your wastegate there's a metal seal that inserts into the manifold side, did you forget that? My friend with an s2000 did this and it resulted in horrible spool time and lower power. Its essentially a massive pre-turbo exhaust leak.
Old Mar 31, 2011 | 01:33 PM
  #286
Gorilla RE's Avatar
GorillaRaceEngineering.co
Yes, I agree that the power is down on that setup... Do a compression test and pressure test the intake system.
-J
Old Mar 31, 2011 | 01:54 PM
  #287
silverfdturbo6port's Avatar
500+hp club
Originally Posted by BigIslandSevens
DO you still have the stock torsen diff? The spiders let go on mine the second trip down the strip. About 60 foot out it wheel hopped and went boom. I had waited over a month for it to show up to Hawaii at the time too. Went from the port, to the Hilo drag strip, to the tow truck flat bed, to my house in Kona Thanks AAA.
Are you going to the next tune session? Is it Friday?
Dave
lol that same **** happened to me lol
Old Apr 4, 2011 | 11:53 PM
  #288
evanwest94's Avatar
not really diggin the widebody, but i guesss its cool. FDs are dope
Old Apr 27, 2011 | 04:37 AM
  #289
WLD 07's Avatar
Can you post the dyno sheet?
Interested to see the boost curve with the bigger wheel & housing.
Old Apr 27, 2011 | 11:01 AM
  #290
Islander's Avatar
Pm catch22 and see.if he can send u the sheet.
Old Apr 27, 2011 | 07:09 PM
  #291
catch-22's Avatar
WLD 07 ill look around and see if i can find it.
Old Dec 21, 2011 | 05:45 PM
  #292
Islander's Avatar
I didnt want to start another thread, but had a few updates on the car.
I finally hit the 500hp mark. I did 514hp/388ft-lbs at 23psi. Thats on 100 octane..
I wasnt happy there so decided to turn it up. I went back to the dyno a few months later with my aquamist hsf3 installed and was running 93 pump and boost juice in the meth tank. Car made 540hp/410ft-lbs @ 27psi. Ok ok, im waiting on all the replies of "thats weak, and thats no power" lol. Broke the electrode off on the inside of the plug. I had denso iridium ire01-27, and ire01-31. When they broke i put a set of bur9eqp in and at the same boost level (27) the car only made 488.
Well the history behind my madness is the car doesnt have a high boost tune on it. I just keep turning it up. lol. I was running 25psi and 100 octane for about a year now. Motor only has a streetport and ALS seals in it. And catch-22 can vouch for how much i beat on my car. I finally broke my tranny running that kinda boost on the street. Im going for a 600hp dyno sheet, soon as my new tranny gets here and the race plugs arrive as well.
I have pics i need to post up and will very soon.
Old Dec 21, 2011 | 06:21 PM
  #293
Islander's Avatar
http://youtu.be/7NFgjO7v71U
Old Mar 6, 2022 | 05:21 PM
  #294
GucciBravo's Avatar
Piping done and installed.. Turbo mounted, oil drain/feed lines finished. BOV installed, downpipe and exhaust installed. Only thing left to do is wiring of the fuel pumps, battery and put in a few gauges... So soon folks, soon...
This is Gucci Bravo Approved, Islander!
Old Mar 11, 2022 | 02:14 PM
  #295
zx1441's Avatar
It's good to know that if ever I need to hire an archeologist, I know where to find one.
rx7jocke
72
Jun 17, 2016 03:48 AM
atticus_jay
Interior / Exterior / Audio
6
Oct 23, 2015 11:16 AM
CWA
Introduce yourself
Sep 23, 2015 12:59 PM
