I need help fast!
Old Dec 23, 2001 | 05:43 PM
tweaked's Avatar
I need help fast!
Last night I smelled fuel. to today I wanted to fix it .
It is the input line that feeds the secondary injector fuel rail. The one located next to the firewall. I don't know where the other end is. Can I change this with out removing the manifold. I can't see where it goes
I need to drive to my mothers tonight or tomorrow, but none of the parts stores wil be open tomorrow. I need the don'e tonight.
Please help!!!
Old Dec 23, 2001 | 06:03 PM
Scott 89t2's Avatar
SOLD THE RX-7!
so you can see that the hose is leaking??
Old Dec 23, 2001 | 06:05 PM
tweaked's Avatar
Yes there was fuel running from it. so I started to take it off and now I can't find the other end. I had to cut a slit down the side too so I could get it off the nipple. so now I have no car
Old Dec 23, 2001 | 07:19 PM
Hmm you are going to have to remove partly the upper take and work that way. Sounds more like it could be the pulsation damperner.
C
Old Dec 23, 2001 | 07:54 PM
Wicked7's Avatar
You're SOL. Go buy a new car.
Old Dec 23, 2001 | 09:57 PM
Silkworm's Avatar
Has been.. hangin' around
It ain't quite that bad Wicked7
But, you're going to have to pull the upper manifold. Sorry, not enough room there to get at the hose without it.
PaulC
Old Dec 23, 2001 | 11:01 PM
Scott 89t2's Avatar
SOLD THE RX-7!
C
well the damperner is on the front. and he said it was the line by the firewall that was leaking. you need to remove the upper manifold. you'll need a new intake gasket after too.
Aramir
Oct 18, 2015 02:39 AM
Devon Murray
Sep 26, 2015 08:15 AM
