T60-1 vs GT30r
Old Jan 19, 2012 | 09:51 PM
nsk1's Avatar
modest beginnings
Originally Posted by Turblown
You are looking for a 60 trim To4E, ball bearing with a .84, tubular manifold, and a big exhaust system.
The other smaller stuff will create a lot of exhaust backpressure, and egts will skyrocket in the higher rpms. I have done it before, if I remember correctly was near 1800 deg F past 6200rpms. Was 400rwhp @ 16.5psi on something extremely close to a GT3076R..
when you say .84 you mean a/r correct? would a 1.0 a/r spool faster?
Old Jan 23, 2012 | 09:14 PM
nsk1's Avatar
modest beginnings
from what i understand the .84 a/r would spool faster than the 1.0 a/r. i'm just curious if the .84 a/r would be too small and cause excessive backpressure and heat.
smaller a/r should just shift the powerband down. i would rather take under the curve power over top end power. for the modest (if 400hp is modest) i'm after i doubt the falling off effect would really come into play with the smaller turbo.
books
Dec 24, 2020 08:09 AM
Komodo1982
Racing Kills Lounge
125
May 31, 2010 12:35 PM
Cowzzz
Mar 14, 2006 12:21 PM
badass7
May 29, 2005 05:09 PM
Garrett
Sep 23, 2003 10:44 AM
