Having trouble removing pressure plate bolts
Old Nov 19, 2009 | 07:57 PM
James2u's Avatar
I am having trouble removing the 6 pressure plate bolts from the flywheel. They turn, but they will not come out. I am trying to remove them in a crisscross pattern, but no luck in removing them. Any suggestions? The goal is to remove the engine. Car is a 94 RX7, ACT clutch, Racing Beat 9.5 flywheel.
Old Nov 19, 2009 | 08:13 PM
Mahjik's Avatar
Mr. Links
If it's a Racing Beat flywheel, there are probably nuts on the back of the flywheel (i.e. the flywheel itself isn't threaded).
Old Nov 19, 2009 | 08:19 PM
James2u's Avatar
I was afraid of that. I have remove service hole A and B for access. There is not much room to hold the nut while loosening the pressure plate bolt. Any solutions?
Old Nov 19, 2009 | 08:22 PM
MOBEONER's Avatar
It's finally reliable
+1 check for nuts<-----
Old Nov 19, 2009 | 08:32 PM
Mahjik's Avatar
Mr. Links
Undo the throw-out bearing properly.
https://www.rx7club.com/showpost.php...48&postcount=6
I think the video link in that post is dead, but it was put on YouTube:
http://www.youtube.com/watch?v=uPCi4RpGQCU
Old Nov 19, 2009 | 08:36 PM
James2u's Avatar
I tried that, but I didn't have any success.
Old Nov 19, 2009 | 08:38 PM
James2u's Avatar
I read all the stickies and watch the youtube video of releasing the throwout bearing in a Mazda RX7 FD3S
Old Nov 20, 2009 | 11:45 AM
dgeesaman's Avatar
If you are removing the engine, I recommend you pull the trans with it. Many people prefer to do it that way in the first place. Then you'll be able to work the release collar better when it's clear of the car.
Dave
Old Nov 20, 2009 | 12:07 PM
Force13B's Avatar
No more G6
why couldn't i find that video 4 years ago when i was taking my clutch out
Th0m4s
Feb 26, 2019 02:04 AM
