My BW S475 project... lots of pics.
Old Dec 5, 2008 | 02:55 PM
gusfd3s's Avatar
E85 Addict
So.. i finally sold my greddy t78 kit and went for a borg warner s475 with 1.10 A/R.
Car summer 2008
[youtube]http://www.youtube.com/v/uslGUyz3a5A&hl=sv&fs=1[/youtube]
2007/2008 winter build up with new fuel system, weldon 2035 pump and 6x1680cc injectors
2007/2008 i also installed the t78 turbo kit and made a new manifold.
The car was dynoed a couple of times in 2008 and at 21psi it made 548RWHP on E85 tuned by myself.
As usual that was fun for a few weeks and now winter has arrived and my fingers itches like hell!
Two weeks ago i received some material to work with, i've been welding some aluminum but never done anything useful with stainless..
First off, i did this to be able to make....
this fixture of the new manifold.
Old Dec 5, 2008 | 02:56 PM
gusfd3s's Avatar
E85 Addict
I bolted on the flanges and started to measure and measure, and finally cut!
Both runners made.
i finally got to weld
Old Dec 5, 2008 | 02:57 PM
gusfd3s's Avatar
E85 Addict
finally...
THe new turbo on the new manifold, the fixture did its job, it is tight but it fits
now the wastegates, 2 synapse 40mm wastegates.
First wastegate there..
Space was a big issue here, it was hard to make room for both of them, i probably got the manifold on and off the car 30 times before i got it right.
gusfd3s's Avatar
E85 Addict
Welding the flanges..
zoom zoom zoom zoom...
Time to weld.
both of them welded.
Welded backside of the flange.
Both wastegates mounted
Old Dec 5, 2008 | 02:58 PM
gusfd3s's Avatar
E85 Addict
Got a bit tired of all stainless so got some aluminum work done.
3.5" to 3"
got some bends on there aswell,.
zoom zoom zoom
Something like that!
so far so good. Lets weld some more.. :P
Old Dec 5, 2008 | 02:59 PM
gusfd3s's Avatar
E85 Addict
Getting close!
Lets do some stainless again... beginning of the downpipe
5" is kind of big...
got a reducer on there.
time for some welding..
zoom zoom zoom zoom
finally things are comming together.
gusfd3s's Avatar
E85 Addict
Making the rest of the downpipe.
Welded
Welding it to the downpipe.
Almost there
Yes!
Now i need to get some flanges to be able to continue,,
So far so good!
more to come..
Old Dec 5, 2008 | 03:19 PM
turboR1's Avatar
ErnieTKiLLA
looks very nice and great work.. im on a simliar path.. dam that turbo is going to be a tight fit. do the wastgates stick out from under the car at all?
Old Dec 5, 2008 | 03:30 PM
gusfd3s's Avatar
E85 Addict
Sweet!
They are about an inch under the subframe
Old Dec 5, 2008 | 04:08 PM
enzo250's Avatar
IRS Champion
Very Nice...
Now i know why you need upgraded axles.. LOL...
Old Dec 5, 2008 | 04:11 PM
Chaotic_FC's Avatar
wow this is a very nice build
what are your power goals?
also, what kind of porting do you have?
Old Dec 5, 2008 | 04:18 PM
Lasse wankel's Avatar
Nice job and fast as usual Gustav "thumbs up"! So you kept it 3" the last way? Must try to locate a good air filter for you or as we speaked about a cold air boxed system maybe is the way to go? Now to a question to all you BW 475 lovers, what kind of hp at 20 psi boost and at what rpm is Gustav gonna make? This would be on a RotoTest hub dyno. Myself i think 600 rwhp@7700 rpm@20psi!??
/Lasse
Old Dec 5, 2008 | 04:26 PM
Azcamel's Avatar
Put it in her butt
nice work, i wish i had skills like that.
Old Dec 5, 2008 | 04:27 PM
turboR1's Avatar
ErnieTKiLLA
600 is alittle high for only 20 psi esp since this turbo doesnt start moving until 20+psi.. prob 525 is a better number at 20psi. you have to run big boost with this turbo to make power.
Old Dec 5, 2008 | 05:10 PM
ZAN_TUNING's Avatar
Just turn up the boost!
Veryyyy nice! the welding looks great, lets hope it holds the weight of that beast
Old Dec 5, 2008 | 05:17 PM
mono4lamar's Avatar
In the burnout box...
The intercooler piping from the compressor outlet has too many bends IMO. I would have opted to a larger single wastegate and put it as close to the turbine inlet as possible... You're on the right track, we all just do it differently. Beautiful port matching on the Excessive LIM (I bet you hated how bad they come cast too...) Also, Excellent work on the manifold!
Old Dec 5, 2008 | 05:20 PM
Japan2LA's Avatar
I like you LIFT..
Old Dec 5, 2008 | 05:34 PM
KaiFD3S's Avatar
SINFUL7
Great work, wish I knew how to weld...
Old Dec 5, 2008 | 05:41 PM
enzo250's Avatar
IRS Champion
/Lasse
I'm gonna guess 625hp @ 25~27psi.
Old Dec 5, 2008 | 07:36 PM
mono4lamar's Avatar
Originally Posted by Japan2LA
I like you LIFT..
I was going to say that too.
Old Dec 5, 2008 | 07:38 PM
Gorilla RE's Avatar
GorillaRaceEngineering.co
I like you LIFT..
I thought the same thing....
-J
Old Dec 6, 2008 | 02:22 AM
Azcamel's Avatar
Put it in her butt
/Lasse
i would guess on 91-93 pump gas at 20 psi it woudl be in the low 500rwhp range, like 500-515. I put a little over 500 on 20psi on a GT42, either way both my and his turbo is still not waking up at that leve, it needs to be hin the high 20 to make monster boost.
Old Dec 6, 2008 | 04:21 PM
dregg100's Avatar
gotham used this turbo on a similar setup right before going under and made 608 @20psi on a mustang dyno. so dynojet numbers is well into 600s.
i will be using this turbo too in a little while and cant wait!
Old Dec 7, 2008 | 05:12 AM
gusfd3s's Avatar
E85 Addict
Thanks for nice comments,
I dont want to speculate about power, time will tell, will put the car on the dyno when im finished.
With the greddy turbo the car put down 499whp @ 17psi pump gas, 506whp@15psi E85, 548whp@21psi E85.
The goal with the car is to run a 10 on 1/4 next summer
the LIFT is my best tool
Old Dec 7, 2008 | 10:55 AM
justturbo2's Avatar
Registered User
real nice. the welds look awsome
