BLUE TII new fitment: stock fenders and 255/40-17 front 275/40-17 rear
So my old set up of 245/45-16 Toyo RA1 all around on 16x7.5 front and 16x8 rear was nice, but lacked traction on acceleration.
I considered buying a pair of 17x9.5 TE-37 for the rear and rotate the 16x8 to the front, but DAMN the price of Volks just keeps going up.
I searched Ebay for a couple of months until I saw the perfect fitment TE-37 come up off of a JDM car.
17x8.5 +30 for the front and 17x9.5 +40 for the rear for less than the cost of a new pair for the rears, only problem was they were 90's forging in washing machine white...
Had them powder coated bronze and put 255/40-17 and 275/40-17 Nitto NT01 on them.
Just as I calculated, perfect fitment with stock fenders and JIC FLT-A2 coilovers.
Pics of new fitment up front
NASA geek
Kick ***. Don't forget to mention the use of cam or "crash bolts" so those clear the coilovers. I run a close fitmit to yours 18x8 38 offset 235/40 and 18x9.5 35 offset 265/35. I had to use crash bolts to gain some room inside and dialed back in neg camber with the top plates.
~Mike...................
Trending Topics
are you that against rolling the fenders or slight pull??
I would pull the front out a bit if it was needed to clear the 255 up front, but it isn't and keeping with the reasonable +30 offset up front REALLY helps reduce the bump steer, trammeling, hunting under braking and the large scrub radius of a lower offset rim.
I have a friend w/ 255 on a 17x9 +15 up front and the immediate turn in is awsome but the downsides are a bit scary on the street and I wouldn't want to do 100mph + on bad pavement like the hillclimb.
I had considered the shine widefenders and still have that as an option for rotating the 17x9.5 to the front with a spacer and running a 275 up front.
usually im not at fan of the flat TE, but you car does look good
Don't forget to mention the use of cam or "crash bolts" so those clear the coilovers..
Nicely done ian. Man it gets real close with that backspacing. HOpefully there's no tire flex. hehe.
As long as your tire doesn't have a rim protector bead (race tires don't :P). The 235/45 Trampio Vimode (JDM Toyo) that came on the rims didn't fit because of the rim protector.
I think I will have to get some sway bars or stiffer springs as I started getting some body roll w/ the 245 RA1 and the 7k 5k springs.
Received 2,604 Likes
on
NASA geek
I have Flex's, and with 17x9 +24 245/40/17 there is 3mm clearance between the tire (with rim protector) and the spring seat.
btw Blue TII- keep an eye on the area about 6" forward of 12 o'clock on the rear fenders. thats the first place the tire will rub. it may clear when you just jack the tire up into the fender, but under hard acceleration/cornering the susp geometry gets a little screwy. i'd check the trailing arm for rubbage too after hard driving (same deal)
Mine are made by Eibach and never moved on me from my "drive like an A__hole" on the street, to even r1 tired autocrosses in 3 hard years of driving.
There is a LOT of contact area getting pinched between the strut housing and hub carrier on the FC so it would definitely take some force, but even just a sticky slick can really generate some loads...
Wow, those JIC's must have more room then my TEIN FLEX do.
Thanks for the heads up. That is relevant info because in the rear I am trying to keep the neg camber to -1 degree as traction available for acceleration really starts to fall off fast past that and that is the whole reason I have the wider tires...
I may have to roll the top section of the rear fender lip under like I did the front. Even the 245 on a +30 rubbed the spot you indicate on the rear fender if I tried to take out all the negative camber.
Up front my 245/45-16 have already worn a shiny spot on the inside fender well from hitting bumps while braking and turning.
The 255/4017 clear full lock at rest, but will have more of the same problem on compression as they are taller.
never hurts to roll dude. well, it can hurt the paint i suppose..
i'm looking forward to a rub report once you track the new setup.
and by rub report, i mean tires. not what you do at home on a saturday night (jk lol)
my lil 2 cents- i have 245F 17x9 +24 and 275R 17x10.5 +27. the fronts are irrelevant thanx to different coilovers. the rears have rubbed the control arms slightly, most likely during a bumpy autocross. i have BFG G-Force TA KD's, which are decently sticky (for street tires), but may also have more sidewall flex that the yours. my fenders are pulled, but the tires still hit about 1.5" up inside the fenderwell. i set the ride height accordingly to avoid it. (i also have 1 degree camber in back)
you may try setting your ride height and alignment, then unbolt the rear strut and compress the suspension (& tire) with a jack. this will give you an indication how much rolling you'll need for full travel.
on
Thanks for the info, but its apples to oranges perhaps. As I'm sure you know, Miata's have double control arms were the FC has a strut. Forces being applied to suspension points I'm sure are different. Were exactly are the Miata guys placing these concentric bolts at? Mine are made by Eibach and never moved on me from my "drive like an A__hole" on the street, to even r1 tired autocrosses in 3 hard years of driving.
the front suspension sees a lot of load in a racing situation, as you know
on
new wheels look great btw! thats a lot of meat under stock fenders
Blue You think you got get a 17x9 with a 275 up on the front with just a 30mm fender?
If the +30 fenders give you 22mm more on the outside when trimmed right that may be enough to clear a skinny 275/40-17 (like RT615, RA1 or NT01) with perfect offset.
If it almost worked, you could mod the camber plates for more negative camber and then push the wheel tire away from the strut w/ eccentric bolts (back to more positive camber) to free up some room on the inside.
The downside is, if they don't clear you can't exactly pull the fiberglass widefender out to clear it like a stock steel fender.
Probably 3 1/2 deg negative up front.
On the 245 tires I measured 3 1/4 deg and it was a good compromise for even wear with racing and daily driving.
I went a little further and maxed the camber plates out for the 255 tires since I have another daily driver now and front shoulder wear has always been an issue racing.
I might end up taking some negative camber out up front as the NT01 have very large shoulder blocks to help mitigate wear unlike the RA1 I had been running.
I think you can get a little more negative camber with the JIC FLTA2 coilovers than most since the hub carrier mounting points are further out from the strut (also providing for more room inboard for rim/tire).
Mac Attack
I compared my inner rim clearance with yours, and assuming you're not using spacers, the difference in clearance between our front wheels is 0.35mm from the coilover. I had thought my stances would be a problem in the fitment, but turns out I have enough clearance to run it.
You seem to tuck pretty well, so with a fender roll (although you're against it), I should be able to tuck my tires under. My front wheels stick out 12.35mm more than yours, fwiw.
on
for any of you guys thinking of a 275 up front on a 17" wheel just remember that is a TALL TIRE wow like whoa!
the 285/30R18 is super short in comparison (if you can afford it pal, lol) and will fit nicely on a 18x9.5 wheel up front with the proper offset and a 20mm or panspeed type of fender.
255/40r17 can be pretty damn tall too, NyToy / soloracer had them up front on a 17x9 +15 with tein flex and mariah 30mm fenders and while driven hard there was a lot of rubbing to take care of with trimming here and there and the car couldnt be lowered too much either.
