1st gear whistle?
Old Jul 13, 2007 | 01:22 PM
a-cups847's Avatar
silver rx baby
1st gear whistle?
is there anything that i can do to make the 1st gear whistle louder?
Old Jul 13, 2007 | 01:30 PM
K-Tune's Avatar
FD Daily
wtf?
Old Jul 13, 2007 | 01:33 PM
jfachner72's Avatar
"1ST GENS" THE REAL RX-7!
get a gilmer drive .....
Old Jul 13, 2007 | 01:39 PM
1badFB's Avatar
GSSL-SE
Drain your transmission fluid!
Old Jul 13, 2007 | 11:21 PM
woodonastick's Avatar
my fb is older than me
install a whistle tip. WOO WOO!
Old Jul 13, 2007 | 11:36 PM
-=DanK=-'s Avatar
To hell with that, Drain ALL fluids!
Old Jul 14, 2007 | 12:23 AM
kgray's Avatar
GOT WANKEL?
HAHA!!!
Old Jul 14, 2007 | 01:15 PM
Jeff20B's Avatar
Lapping = Fapping
a-cups, are you sure you're not a girl?
Old Jul 14, 2007 | 01:22 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
yank yer diffy, take it apart, drink a **** load of beer, slap it back together, and reinstall it. It'll whine more than Jeff20B after he kills an ignitor.
Old Jul 14, 2007 | 01:23 PM
Kentetsu's Avatar
Crud gets built up in the synchros, and keeps them from working properly. Other bearings, etc. can also suffer from this. An old trick from the Datsun race crowd was to use a 50/50 mix of ATF/Gear lube in the manual trannys. The ATF provides plenty of lubrication, but also has lots of detergents that will clean the crud out and keep it from building up again.
The results are faster shifting, less noise, less wear, and a longer lasting tranny. I've used this method in several cars and was always impressed with the results. I will typically drain the solution after a few hundred miles (because it will be VERY dirty), and then refill with the same mix, which is run permanently. Hopefully this info will help...
Old Jul 14, 2007 | 08:10 PM
PercentSevenC's Avatar
I need a new user title
^ That's a cool trick, I might have to try that.
Old Jul 14, 2007 | 10:55 PM
orion84gsl's Avatar
My 7 is my girlfriend.
I definitly HAVE to try that. I think second is bound and determined to destroy its synchro on me and I don't need that.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
