Timing on S4 swap?
Old May 17, 2005 | 05:40 PM
13BTOY's Avatar
Boosted Fb
Timing on S4 swap?
S4 13B using a 12a front cover and 13B GSL-SE main pulley. Does this mix matching of parts throw off your timing marks? I tried setting my timing today and it was way off. When I zero it out(my timing light and L mark) it stalls. When my assistant revs the motor so I can set it, the timing retards even more? I'm not using my vac advance. Any suggestions?
Thanks, Ed
Old May 17, 2005 | 10:25 PM
Siraniko's Avatar
RX for fun
IIRC, the S4 is L5/T20 while GSL-SE is L10/T20. If Im wrong, Im sure someone will chime in.
Old May 18, 2005 | 06:48 AM
13BTOY's Avatar
Boosted Fb
Should I put the stock S4 pulley back on?
Thanks, Ed
Old May 18, 2005 | 07:15 AM
Kentetsu's Avatar
Take a look at this....http://members.optusnet.com.au/~onec...-%20part%20one
Read through all of the pages and it might help you understand the situation enough to get things straightened out....
Old May 18, 2005 | 11:42 AM
13BTOY's Avatar
Boosted Fb
Thanks man! Will do! By the way I put the S4 pulley on and no change? Also did the 2nd gen coil directfire while I was in there. I need to set the timing on this thing!
Thanks, Ed
Azevedo
26
Mar 1, 2019 09:19 PM
JIMMY54
Aug 12, 2015 05:40 PM
