Compression ratios
Old Nov 25, 2009 | 05:03 PM
Jimmy2222's Avatar
Compression ratios
I'm looking into the option of rebuilding with higher compression rotors and I remember seeing somewhere the compression ratio's for all the rotors but I can't seem to find it in search (sooo many results). Can anybody show me a link/list them off?
Also, anybody know the "danger" level for boost on N/A rotors (SX?)?
Thanks.
Old Nov 25, 2009 | 05:29 PM
lonetlan's Avatar
Too Many Questions
S5 N/A rotors have a high compression.
Old Nov 25, 2009 | 05:42 PM
Jimmy2222's Avatar
I know, but I'm looking for numbers.
Old Nov 25, 2009 | 06:00 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
The FAQ...
But I can tell you here, 9.7:1 on S5
Old Nov 25, 2009 | 06:06 PM
KhanArtisT's Avatar
Former FC enthusiast
S4 na: 9.4:1
s5 na: 9.7:1
s4 tii: 8.5:1
s5 tii: 9.0:1
FD3S: 9.0:1
I don't know first gens though.
Old Nov 25, 2009 | 06:46 PM
bumpstart's Avatar
talking head
74-78 13b = 9.2 : 1
74- 12a= 9.4 : 1
84-85 13b GSL-SE RESI engine = 9.4 : 1
personally,, having done this more than just a couple of times
the 9.7 will have practical limits in boost ,, with boosts over 10 psi needing quite significant retard ( fuel= aussie 98 RON, equiv to your 92 MON )
9.7 rotors are the lightest,, but also the thinnest and weakest in combustion face
- unless careful will be prone to detonation ,, and denting of rotor flanks
9.4 rotors however ( s4 NA ) are nearly as light ,, but without the compromise in rotor face strength,, and without the drastic retard above 10 psi
-- currently am daily driving a boosted s5 NA block using NA s4 ( 9.4 ) rotors and balance weights
( albiet on propane )
( at 12 psi,, with no hint of det )
and i think out of all the combos of rotors i have used with similar plate/port
this is the best evolution/ combination without compromises
Old Nov 25, 2009 | 07:27 PM
Jimmy2222's Avatar
Alright, thanks for the help guys, much appreciated.
turbodreamz22
General Rotary Tech Support
28
Nov 10, 2023 11:08 AM
