Richard Sohn Metering Pump Adapter Install
Old Dec 27, 2008 | 01:27 PM
Sgt Fox's Avatar
Stigulus Moderatorai
So a while back, I picked up an OMP adapter from Richard Sohn. http://www.rotaryaviation.com/oil_in...p_adaptors.htm
You will have to contact him directly at:
Richard Sohn PCV Technologies, Inc. 8029 HWY 1087, DeFuniak Springs, FL 32433. Tel/Fax(850)834-4905 email: RES12@fairpoint.net
Now for those that don't know, this device allows you to use a separate reservoir as a source of the oil for the OMP. This allows you to use 2 stroke oil instead of dirty engine oil to inject.
For a reservoir, I chose a Yamaha Razz/Riva oil tank. ( http://motors.shop.ebay.com/_Motorcy...1QQ_trksidZm38 ) It was cheap, the size I wanted, and when mounted would look somewhat stock. In addition, it was designed to hold 2 stroke oil and thus would not be dissolved like some plastic containers. The tank also had a level sensor. Its operation allowed me to wire it in parallel to the stock oil level light. This way, if either the sump or the tank runs dry, the warning buzzer and dash oil light will illuminate.
To mount the tank, I made a bracket out of sheet aluminum. It turned out nicely and is very strong. The hose I chose is polyurethane as it is oil resistant, but still clear, allowing me to inspect the line for air bubbles.
I also ordered a OMP rebuild kit from Lowe Performance ( http://www.loweperformance.com/ ) It uses Viton o-rings, and as such will last longer than the stock rings. Correspondence with the company took a while, but in the end was worth it.
Now I am just waiting on a second OMP gasket from Mazda. They have taken two months to try to get one in
Old Dec 27, 2008 | 02:15 PM
DivinDriver's Avatar
1st-Class Engine Janitor
Nice fab work there; very clean.
Old Dec 27, 2008 | 02:17 PM
t_g_farrell's Avatar
Waffles - hmmm good
Excellent mod Sgt. I was wondering about doing this sometime. Three questions.
How do the two pump pieces actually fit together? I've seen these before and assumed they bolt one on the other and one pumps from the reservoir and the other pumps up to the carb. Maybe a pict of the install would clear it all up for me.
Do the pumps utilize the existing OMP linkage to control the output of these or are they constant?
Last question where did you get the clear poly hose?
Thanks for posting this up.
Old Dec 27, 2008 | 02:36 PM
Sgt Fox's Avatar
In my first picture there is both a 12A and a 13B adapter. The adapter goes in between the front cover and the OMP.
The stock linkage is maintained.
I got the clear hose at a local industrial supply shop.
Old Dec 27, 2008 | 03:29 PM
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
Nice work, please let us know how this works ourt because I am thinking about invesrting in this kit for my eventual rebuild of my own seven.
Old Dec 27, 2008 | 09:21 PM
Ah, so the adapter utilizes the stock OMP!
NOW I get it... It's a blocking plate and a shaft pass-thru. It's not actually a pump, right? It just feeds the stock OMP with oil from the tank?
That'd be why you need two gaskets and the rebuild kit.
Old Dec 27, 2008 | 10:57 PM
PercentSevenC's Avatar
I need a new user title
I wanted to do that in my FB, but now I'm premixing anyway. I still might do it in my REPU.
Old Dec 28, 2008 | 04:15 AM
Sgt Fox's Avatar
Correct.
Old Dec 28, 2008 | 08:09 AM
wrxracer55's Avatar
That looks great. Very similar to what I plan on doing to mine.
Jason
Old Dec 28, 2008 | 08:25 AM
wrxracer55's Avatar
Just tried emailing him, and the email failed. Wondering if he quit.
Jason
Old Dec 28, 2008 | 01:19 PM
Sgt Fox's Avatar
Jason
Give him a call. He seems to change emails... he had listed unicorn@gdsys.net at one time as well
Old Dec 28, 2008 | 06:03 PM
Waffles - hmmm good
Thanks for the info. Might give it a try. How much for the 12a Sohn adapter?
Old Dec 29, 2008 | 03:24 AM
trochoid's Avatar
Old Fart Young at Heart
Excellent. A few more pics and details and it's worthy of archiving.
Old Dec 29, 2008 | 06:09 AM
vipernicus42's Avatar
Rotoholic Moderookie
Awesome thread.
Good to see Lowe's site is back up after all these years. I still prefer calling them though, it seems to be the best way to get them moving.
I've been wanting to do this for a while, it's still on my to-do list. Thanks for the great post. It would be cool if you could snap a pic or two of the adapter installed
Archived.
Jon
Old Dec 29, 2008 | 10:00 AM
dbragg's Avatar
Say hello to Mr.Wankel
I have this same kit. I need to get off my *** and install it. Ive got a stainless oil can with a level tube. Its nice, but I actually think I like your tank better. Looks more stock and clean.
Nice work.
What premix are you using? I bought a case of Idemitsu from Mazdatrix.
Also, when I ordered my OMP rebuild kit from Lowes I just told them i needed another OMP gasket and they added it to the order. For like $2 or something.
I need to get another rebuild kit from them and then I am ready to go. The OMP I rebuilt I accidently sold with my old engine and the seller is taking their ever loving time getting it back to me, over a year.
Old Dec 29, 2008 | 12:39 PM
82transam's Avatar
Never Follow
Very nice install fox, I'm interested to see how it all works out (I'm sure just fine) as I was planning on doing this on my cars as well.
Edit: just looked at the site again and it looks like the 12a adapter isnt listed anymore, bummer...
Old Dec 29, 2008 | 12:46 PM
Sgt Fox's Avatar
Its still available. I had to ask for it.
Old Dec 29, 2008 | 12:57 PM
82transam's Avatar
Never Follow
Ah ok, thanks!
Old Dec 30, 2008 | 04:11 PM
wrxracer55's Avatar
I left a message at the number. I'll let you know if I hear anything.
Jason
Old Dec 31, 2008 | 07:44 PM
Sgt Fox's Avatar
Gasket finally came in.
Pump on the car and leaking....
Pump removed:
Pump back together with adapter fitted:
Adapter and pump installed on car:
Old Dec 31, 2008 | 10:50 PM
MattG's Avatar
MattG FTW!!!!!
That is one clean install!
I have always wondered why more people have not done this mod, I think it is the finding/placement of the 2 cycle oil bottle that scares them away.
I think jon hould archive this.
Old Jan 4, 2009 | 07:28 AM
wrxracer55's Avatar
Heard back from Richard, and placed my order.
Jason
Old Jan 4, 2009 | 04:36 PM
IanS's Avatar
Ricer
Didnt I buy my RA OMP adapter from you wrxracer55? I swear I did. Its funny you bought another one. Mine's been working like a champ for a long time. Much easier than dealing with letting the fuel run real low and then putting a certain amount of premix in. This way you just check the 2 stroke reservoir and fill up the tank, or simply put 10 bucks in. Whatever you want to do - no need for doing the math and worrying about overfilling the premix in the gas tank.
Old Jan 4, 2009 | 06:58 PM
wrxracer55's Avatar
Yeah, you did. I had bought one for a previous RX7 that I owned, and then sold. I just picked up another 85 a month ago, so I am going through this all again.
Jason
Old Jan 16, 2009 | 01:25 AM
So What's the status on this? I would like to see how well its working out ect...
