New Turbo GT3574
Old Apr 9, 2008 | 04:36 PM
  #126
TehMonkay's Avatar
Back in the game
Looks like i'll be ordering one of these soon enough.
Old Apr 20, 2008 | 10:20 AM
  #127
shaunwil's Avatar
PMs sent, couple of issues with the kit.
Shaun
Old Jun 22, 2008 | 06:46 PM
  #128
driftbendito's Avatar
Newbie
where do i buy this turbo
Old Jun 22, 2008 | 07:10 PM
  #129
dubulup's Avatar
development
call A-Spec
Old Jun 27, 2008 | 07:20 AM
  #130
shaunwil's Avatar
After the issues I had with a worn out clutch and a over rated wastegate spring the setup finally got back on to the dyno at Pips.
The setup is an A-spec GT3574 with a 0.84A/R. I've modified it a little by routing the wastegate back into the downpipe myself (A-spec don't offer it on this setup).
Some images of the install:
Went to a 0.3bar spring from the 0.9bar spring supplied by A-spec.
Running on 550/1200cc injectors with the stock FPR the turbo was run at 0.94 bar before the controller was fighting with the spring (needs to go heavier, possibly 0.5) and about 80% injector duty.
The results where very good
At the hubs :
And pub figures at the flywheel:
Very happy with the current results. Lots more to come when the fueling is upgrade to either LPG or petrol (still considering both). Single turbos are so much smoother and will take some learning to find out how to drive. Amazing feeling to get this finally sorted
Shaun
Old Jun 28, 2008 | 04:36 AM
  #131
shaunwil's Avatar
oops, the wastegate spring was a 0.5 bar ! Looking at maybe a 0.6 or 0.7 for correct boost levels.
Cheers
Shaun
Old Jun 28, 2008 | 08:43 AM
  #132
Arcayne's Avatar
Hi Shaun
Interesting result... I was out mapping mine last night (same turbo kit, same boost), so is good to see what numbers I should be making
Old Jun 29, 2008 | 10:33 AM
  #133
shaunwil's Avatar
At that boost level pip had to stick the NGK race plugs back in that i had from my twin setup. Figures jumped up very nicely. Seemed to be ok up to 0.9bar on 9's all round and a HKS ignition amp but it got a bit jumpy past that.
I've only got 1200 secondaries or I'd be shooting for higher boost levels with the addition of WI too.
Shaun
Old Jul 1, 2008 | 06:28 PM
  #134
Arcayne's Avatar
I'm waiting on my 1600's coming in then I'll let you know what we find... already have my iridiums in
Old Aug 28, 2008 | 12:55 PM
  #135
ProjectD's Avatar
I'm on a Boat!
Anybody have any updates? I have about 1,500 miles on my new motor and I am dying to see what it will do.
MY SETUP:
1/2 bridge cut by BDC
exhaust ported, motor R/R & built by me
GT3574 .96 a/r
tial 46mm WG
3 inch exhaust
850/1600cc injectors
supra Fuel pump
PFC w/comm
Jacob's FC1000 amping FC(rx7) leading coil
UR sprung 6 pad clutch/ sr motorsports FW
That's about it for power right now. Before I tune I will be switching to EVANS coolant, installing my EGT gauge, and adding Some water/meth injection. along with other misc maint. items
Old Sep 2, 2008 | 10:07 AM
  #136
Zero R's Avatar
Just in time to die
Let me know how your tune goes, I am interested to see where you end up with that turbo on those ports.
Old Sep 2, 2008 | 12:21 PM
  #137
shaunwil's Avatar
Thats going to spool up super quick. Be great to see some dyno charts for it
Shaun
Old Sep 3, 2008 | 02:49 PM
  #138
ProjectD's Avatar
I'm on a Boat!
I'll deffinatley keep you guys updated. I'm aiming to hit 450hp with a fat usable powerband. I'm surethe car will be a blast on the streets as well as the track.
Cyan
Old Sep 30, 2008 | 12:06 AM
  #139
dradon03's Avatar
Derwin
Shaun
Hold on let me get this straight you are maxing out 1200cc injectors and only getting 325 wheel hp, something isn't right here all this @ 13 psi?
Old Sep 30, 2008 | 02:15 AM
  #140
shaunwil's Avatar
I'm maxing out the wastegate spring more than the injectors. I'll need a heavier spring. It was at 13psi and then started fluctuating. Plus its a completely stock unported block.
The plan next is to upgrade the fueling system to be 850 primaries / 1600 secondaries, stick WI on and turn the boost up.
It is on a UK dyno and we do seem to see lower figures than the US one. Either its a safer tune by the tuner or correction values.
Shaun
Old Sep 30, 2008 | 11:36 AM
  #141
dradon03's Avatar
Derwin
Unless you are tracking I would stick with the 550cc sized primary injectors, from what I have seen even 15psi on this turbo leads to like 60% fuel duty on 550/1600 setup.
Thanks for explaining.
Old Sep 30, 2008 | 12:13 PM
  #142
shaunwil's Avatar
Bit of a stop gap towards a bigger turbo later on ::
Going to upgrade to top feed on both rails with a FJO injector driver ideally !
What kind of duty would you get at 20-22psi ?
Shaun
Old Nov 12, 2008 | 08:39 AM
  #143
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
Sean, are you able to sell just the compressor wheel/housing/backplate as an upgrade? Would be very interested in pricing.
Old Nov 25, 2008 | 03:17 PM
  #144
PM'ed about same question as above.... two week bump
Old Nov 26, 2008 | 10:16 AM
  #145
A-Spec Tuning's Avatar
Registered User
PM sent.
Old Dec 5, 2008 | 11:51 PM
  #146
BC-FD3S's Avatar
Is the pricing still the same, 2499? Is that a shipped price?
Old Dec 6, 2008 | 12:05 PM
  #147
Zero R's Avatar
Just in time to die
Price is $2499 yes, shipping is usually $75-89 depending on where in the US it goes. Canda will be a touch more due to the new governement/customs rules we were just handed a short while back.
Old Dec 14, 2008 | 04:04 AM
  #148
KrisD1's Avatar
How much with shipment to Belgium?
Old Dec 14, 2008 | 12:03 PM
  #149
Red Devil's Avatar
What are included in the turbo-kits? Looked at your website but couldn`t find that.
Old Dec 15, 2008 | 12:53 PM
  #150
Zero R's Avatar
Just in time to die
Kits include manifold, DP, 44mm TiAL WG, stainless oil feed and drain lines, high temp shielded coolant lines, sheet of reflective heat barrier, necessary block off plates. Necessary hardware and gaskets.
~S~
