ZG Fender Flares on a FB!
Old Feb 19, 2008 | 09:35 AM
  #76
Dysfnctnl85's Avatar
Acquiring money pits
It shipped FedEx for $28.79. Not too bad IMHO because it's a quite large box.
Old Feb 19, 2008 | 09:59 AM
  #77
aussiesmg's Avatar
Thunder from downunder
TAS can you take a measurement on both the front and rear from the body fold down to establish a baseline as to where to locate the flares?
Old Feb 19, 2008 | 12:08 PM
  #78
teddyrx2's Avatar
One Luv "Till The End"
you going to lower the car
Old Feb 19, 2008 | 04:19 PM
  #79
dbragg's Avatar
Say hello to Mr.Wankel
i need to buy these, but i dont have the money to widen my wheels now. i plan on putting on 16x8 on the front and then ill buysome more lips and probably make the rears 9 or 10.
Old Feb 19, 2008 | 04:48 PM
  #80
Yeah I'm really trying to go 9" wide in the back. I'm going to wait to measure though once the flares are on...but I still am not quite sure how much of the existing fender I need to cut. I'm not a bodywork guy, but I'd imagine cutting where the fender "bubble" begins...I wouldn't think that bolting the flare to the beginning of the bubble would be good for anything...::headscratch::
Old Feb 20, 2008 | 12:12 AM
  #81
luckyfd's Avatar
is that normal?
i want these for the fc. will there be any chance of that happening?
Old Feb 20, 2008 | 10:23 AM
  #82
Call me crazy, but I'm sure there's a better solution for FCs. I highly doubt these ZGs would even come close to fitting an FC, but like I said, I could be crazy.
Old Feb 20, 2008 | 10:31 AM
  #83
Glazedham42's Avatar
Resurrecting Gus
http://www.jdmuniverse.com/forums/sh...ad.php?t=38098
Check that out and try to follow up with it. You may or may not get somewhere. They do look somewhat similar to the ZG flares though.
Old Feb 20, 2008 | 01:07 PM
  #84
82transam's Avatar
Never Follow
Is TAS still around? I want to see pics of the car with the wider wheels all around...
Old Feb 20, 2008 | 01:11 PM
  #85
Resurrecting Gus
Last activity was yesterday. He should still be around here somewhere. I too would like to see better pictures of the finished product. All the others seem kinda dark, and it's hard to make out the details of how the flares actually look. Some daylight pictures would be awesome...
Old Feb 20, 2008 | 01:38 PM
  #86
82transam's Avatar
Never Follow
Yea definatly. I would love to put them on one or both of my FB's, but need to see some better pics first...
Old Feb 21, 2008 | 09:27 AM
  #87
Daily check-in!
I might just ask a painter I know -- he does a lot of body work (used to work for Ford) and he might just know exactly what I need to do. If so, I will post everything I find out.
Old Feb 21, 2008 | 09:28 PM
  #88
ForsakenRX7's Avatar
zoom zoom go boom
Even though there's the slight fitment issue, for the price you really can't beat the deal your getting. I think I'm gonna order mine within the next couple weeks.
Old Feb 22, 2008 | 01:35 AM
  #89
Hyper4mance2k's Avatar
The Shadetree Project
Looks fuggin awesome. Old news though...
Old Feb 26, 2008 | 01:46 PM
  #90
It's not old news -- unless you have a comprehensive installation tutorial.
I spoke with the aforementioned body-guy and he said I should NOT cut the fenders at all but pull out the existing fender material and make a new 90 degree lip (the fenders already have one, obviously to bolt the new flares on. I'm going to try that this weekend. It's not easy to describe without pictures, I know, but I'll hopefully have something for you guys this weekend. I'm borrowing his tools for the "procedure."
In the worst case, he'll do them for me, but I'd like to do it myself.
Old Feb 26, 2008 | 01:48 PM
  #91
Resurrecting Gus
Please take lots of pictures!!
Old Feb 26, 2008 | 02:28 PM
  #92
z-beater's Avatar
REW'd FB
It would make sense to provide a seal between the fender and the flare. That way no dirt or rocks could get in and deteriorate the body.
Old Feb 26, 2008 | 03:34 PM
  #93
Yes he suggested this and I mentioned that the quality job posted up here had a fender liner. Nothing like collecting extra wet in the form of rocks and dirt in the fenders! We differed on taste -- he wants me to fiberglass (mold) them on while I like the exposed look.
Old May 5, 2008 | 09:55 PM
  #94
I know you all have probably forgotten me as another one of those guys that doesn't follow-through...well, school became more demanding and whatever, you have heard all that before I'm sure.
This weekend I finally got time to tackle the flares. I had imagined a science for approaching putting them on the car but I really think it's completely up to the imagination as to how to mount them and what looks acceptable to you.
I worked the fenders flat, pulling the existing fender lip straight. I'm going to cut all of this off but since you can easily take metal away but it's very difficult to add it back, I thought this would be the best approach. I took one of the ZG flares and tried to match it up as best I could and taping it into place. If you are worried about your paint, invest in some 3M tape that's designed NOT to take paint off. Be smart. Here's the mock-up:
After I was satisfied with how the flare looked, I drilled through the flare and body and then secured the flare using some temporary screws. I'm going to find some better hardware for the final fit, but in all honestly, looks are not what my car is designed for...I'd rather look inconspicuous (I know, why get flares, right? Well I have to put the power to the ground somehow...). At any rate, here's what it looked like after securing the flare with those screws:
Now the rear became a bit more complicated. My car is a GS and has trim all around the exterior. This became a problem as the ZG rears would not fit (conform to the body) and also fit between the pieces of trim around the fender. I used a flathead and pulled back both trim pieces which are secured by glue. I'm not sure what I'm going to do with the trim, but I ended up taking off the piece in front of the fender and just letting the rear trim hang loose because it's REALLY attached to the car:
Any suggestions as to what I should do are welcome. I mocked up the rear much like the front:
After I was satisfied, I drilled some holes and secured it with screws:
The most difficult part has been making the left and right sides match with respect to distances. I originally used the pinstripe as a guide...that's a BAD idea. The pinstripes are hardly identical. Make your best guess for a "good" measurement and eyeball the height using a rolling stool or get on your knees a good distance from the front of the car. I know, an incredible amount of science, but as I've state it's not really a matter of science!
Old May 5, 2008 | 09:57 PM
  #95
I think they look pretty good but I still have some work to do. The plan is to cut away the existing fender as much as possible and also put a layer of 3M automotive acrylic tape between the flares and the body. Here are some additional shots (don't mind the dust!):
The gap will be taken care of when I use rivets -- the fenders are loosely screwed in -- and the tape will help out a lot.
To give you an idea of how much clearance you'll gain, here's a shot of the inside front fender. The spacing in the back is at least as wide as the front:
More to come next weekend!
Old May 6, 2008 | 11:31 AM
  #96
dbragg's Avatar
nice. ill be watching you closely. i need flares and thie may be the route i go.
how flush are they with the body? are you going to use double sided tape between the fenders and body? ive never heard of acrylic tape.
you gained about what, 2"? did you try heating the tips to try to get them to conform to the body better?
the rears look great. the fronts look...odd or something. maybe its just the pics.
Old May 6, 2008 | 01:09 PM
  #97
john smack's Avatar
I agree on how the front looks weird with the front of the flare extending down past where the rear of the flare ends.
If you could get some skirts for the side with a little bit that comes up to meet the flares then massaged the flares and the skirt together it would look real complete
Old May 6, 2008 | 01:18 PM
  #98
Could it be that I have the fronts backwards? There's a distinct bubble in the flares and I tried to put that towards the rear on all of them...if that makes sense. There's really no way to tell which way is forward. I will take some more pictures when I get a chance. The rears are the ones that are the most difficult to match up to the body hence me removing the trim pieces. If you wanted the flare to fit in between those pieces it would bubble out from the body a good bit. I didn't try heat.
I'd say it's about 2". I'll put a tape measure up there for the pics.
The tape I have is 3M acrylic double-sided tape and it was recommended to me by a painter/body work individual that offered to do these for me. I decided to try it myself.
Old May 6, 2008 | 01:21 PM
  #99
If I was going to paint the car I would probably do a little bit more work to make them flow. But right now I just need the flares for functionality.
Old Jul 7, 2008 | 09:03 PM
  #100
StricklyOldskool's Avatar
Whats the update on these projects?
