Mazda MPV Power Window Switch DIY
Old Jan 29, 2008 | 09:18 PM
Acesanugal's Avatar
Winter Rotary
As most of us already know, the power window switches in the FC aren't that grand. Most, if not all, require fairly consistent 'cleaning'. This 'cleaning' entails pulling the switches out of the door panel, taking them apart and then sanding the contacts very gently to remove the corrosion that causes them to stop working properly/efficiently. The reason that the switches fail temporarily are because every time you depress the switch and the contact surfaces mate, a slight arc occurs. Over time, this arcing corrodes the contact surfaces, causing the current flow to deteriorate. While easily solved...it's a pain in the backside!
I will admit, this idea did not originate from my own mind. Another forum member has written about this swap some time ago, but it lacks detail (as I found out tonight).
The switches you want come from the first generation Mazda MPV of which spans from 1989 to 1998. They will drop into the door panel seamlessly and look pretty good in comparison to the factory switch sets.
The passenger side window switch is a DIRECT drop in replacement, while the driver side master switch requires cutting the wiring harness off and swapping over the harness from your old factory switch. It's easy, but confusing, and it took me a while to get it right. So here's the key...
Cut the harness off at the base, to give you plenty of wire to work with in case you accidentally snip a little too hard and cut the wires off entirely while attempting to strip them later.
You will notice that the color coding of the insulation is identical looking at the factory and the MPV switches. This is what will throw you off. The thick black wire with blue striping is plug and play, as are the solid black and black with red striping wires.
However, to make the switch work properly, you will need to switch the other color wires with their counterparts. For example: The green wire with black striping will need to be mated with the green wire with white striping on the MPV switch. You get the idea?
If you've done it right, when you test the switch both windows will work properly. I went through several different combinations before I got it right. It can get confusing.
So to sum it up in an easy to look at sort of get up:
Colors that directly swap over:
Thick black with blue stripe.
Thick solid black.
Thick black with red stripe.
Colors that need to be opposed:
Green with white stripe > Green with black stripe.
Green with black stripe > Green with white stripe.
Red with black stripe > Red (It will be red with white stripe on the old harness)
Red (Red with white stripe) > Red with black stripe.
I hope this helps someone who is wanting to do this swap. The switch works great and feels more solid than the standard FC switch set!
Old Jan 29, 2008 | 09:39 PM
BrettLinton7's Avatar
Lots of rotors
Nice little thread... Archives say what?
Old Jan 29, 2008 | 09:42 PM
Fumi's Avatar
Addicted to the PNW
i would say add pictures and itd be more archive worthy
Old Jan 29, 2008 | 09:49 PM
Dltreezan's Avatar
My Bick is Digger
dude. Awesome man. I will definitely be looking for MPV's at the junk yard next time.
Old Jan 29, 2008 | 09:54 PM
Acesanugal's Avatar
Winter Rotary
I'll take some pictures tomorrow and add them to my original post.
Old Jan 30, 2008 | 03:42 AM
RETed's Avatar
So what advantage does the MPV window switches have?
-Ted
Old Jan 30, 2008 | 04:43 AM
eriksseven's Avatar
Make Money.
-Ted
Newer, easier to find (?), maybe less fail-worthy? I've never heard of the mod, but it's nice to have options I suppose.
Pics!
Old Jan 30, 2008 | 05:19 AM
WadeMCarter's Avatar
If you aren't getting the switches from the junkyard, they are pricey! ~$125 for the driver side.. I am happy with mine.
Old Jan 30, 2008 | 12:03 PM
DREYKO's Avatar
I "lost" my emissions....
the mpv switches are more rounded, im not seeing them pop in like stock...
pics?
Old Jan 30, 2008 | 12:39 PM
Acesanugal's Avatar
Winter Rotary
The switches out of the MPV feel more solid. I realize that some people have broken the button plastics off of the stock switches and these do not feel like they'd do that unless you really tried.
Here are some pictures of the switches installed...
And a comparison shot..
Any more questions?
Edit: Yeah, I know they're kind of dirty and the passenger switch doesn't look like it quite fits. It *does*. The slight bulging is because of my warped door panels.
Old Jan 30, 2008 | 01:44 PM
Fumi's Avatar
Addicted to the PNW
oh nice!
and good call, thats a good replacement
Old Jan 30, 2008 | 02:03 PM
Acesanugal's Avatar
Winter Rotary
I think it'd be a worthy archive, myself. MPVs are ALL over the junkyards and these switches can be had for just a few bucks. They look good, they feel good and they work great.
Old Jan 30, 2008 | 02:23 PM
staticguitar313's Avatar
R.I.P. Icemark
blah
it just doesn't look right to me . . .
Old Jan 30, 2008 | 03:33 PM
VashDaStampede's Avatar
Cool, i definately need to go junkyard and grab a few switches, mine have burned out like 4 different times already...
Old Jan 30, 2008 | 05:50 PM
It is cool that there is another option to replace the window switches with, but I just don't see how it is better, unless its cheaper and you need a replacement.
Old Jan 30, 2008 | 06:32 PM
Acesanugal's Avatar
Winter Rotary
I just pulled apart one of the other master switches I've got.
Honestly, I don't see much difference between the FC's switch and the MPV's switch. However, the rocker contacts feel more sturdy and it seems to be sealed a little bit more tightly. The plastics that make up the switches themselves also feel more solid and less prone to breakage.
The bottom line is this: They swap right in. They're cheaper. They're everywhere. What more are you wanting?
Old Jan 30, 2008 | 06:58 PM
sub9lulu's Avatar
sounds good to me
Old Jan 30, 2008 | 07:46 PM
slo's Avatar
slo
registered user
10 bucks says this can be done without cutting the harness. Mazda likes to use the same type of contacts and same gender across car lines in most of its cars of the same general era, and same area of the car.
The pins pull out from the plugs with a dental pic and some finess. Sometimes you end up with extra pins, that would need to be taped over to keep them from shorting.
You could probably get the door side harness plastic plug along with the switch and just put that with the correct pin out onto the wiring for your factory doors.
Old Jan 30, 2008 | 08:12 PM
Acesanugal's Avatar
Winter Rotary
Yes, you could just pull the pins out and insert them into the correct slots on the factory harness. My method was simply to cut them. Both ways will work.
Old Jan 30, 2008 | 08:25 PM
Lots of rotors
Wow, those look a hell of a lot better than I thought they would when we were getting them at the yard. And for everyone else, the MPV switches are a dime a dozen, unlike good FC switches. And IMO they look just about OEM, besides the color. But if he had a blue interior, I'd never know the difference...
Anyways, now maybe I can roll up and down my window in your car without hurrying it on
Old Jan 31, 2008 | 02:46 AM
slo's Avatar
slo
registered user
Your method works and I don't fault you for it, but its faster, better and more professional to pull the pins.
Old Jan 31, 2008 | 03:03 AM
texFCturboII's Avatar
version 2.0
I'm sure they made MPV's with black interiors too yea? If they did, then junkyrad a go go tomorrow!
Old Jan 31, 2008 | 03:19 AM
JustJeff's Avatar
Apex Seal Treachery!!!!!!
I wonder how much work goes into putting the FC top on on the MPV mechanism? I'm pathetic when it comes to keeping the interior stock/uniform. Though there is a divider on the FC that's different than the MPV..maybe it's not possible at all.
Either way, this is an awesome tip. Something I'll be keeping an eye out for.
Old Jan 31, 2008 | 03:30 AM
version 2.0
^^^^Much better Idea!!! I'm sure it couldnt be that difficult, I mean somebody did invent the DVD rewinder!
Old Jan 31, 2008 | 03:59 AM
JustJeff's Avatar
LOL!!!
It looks like you might simply swap the tops off and with the non-lettering on the actual switches...none would be the wiser. I've got an old driver's side switch that I took apart when it broke. I'll have to dig that out and take a trip to the junkyard, do some comparisons.
