wheel stud size
Old Feb 27, 2007 | 11:10 AM
franzo's Avatar
Newbie
Cool wheel stud size
I have an rx7 1991 and an enkei wheels but the studs in the car are to shorts can somebody tell me if theres any specific size and if it is where can i fin it.
thank's
franzo
Old Feb 27, 2007 | 11:43 AM
sharingan 19's Avatar
Rotary Revolutionary
I've heard that you can use studs from a ford mustang and that they're significantly longer. Not sure which year though (it might not even matter) Another choice might be shank style lug nuts that actually grab more of the tread. Only problem w/ those is that if you don't have hub centric rings, they're a major PITA!
Old Feb 27, 2007 | 11:56 AM
franzo's Avatar
Newbie
Thank's for your help im going to try the mustang ones
Old Feb 27, 2007 | 06:16 PM
Black91n/a's Avatar
STOP!!!
It's ARP studs for the late model Camaro/Corvette that you want. They're not too hard to change in the front, but in the rear you need to remove the hub. They have 2 lengths, the short ones are only a little longer in front, but a lot longer in the rear. Using the long ones in front should approximately even it out.
Old Feb 28, 2007 | 11:03 PM
NCross's Avatar
I have a rotary addiction
and why do you need longer studs?? if your planning on running spacers, dont. they are not rated for over 100 mph or hard driving.
Old Mar 1, 2007 | 06:50 PM
Black91n/a's Avatar
RIIIIIIIIIIIIIIIIIIIIIIGHT.
I've not seen a spacer so far that's rated for any speed or use.
They're perfectly acceptable, and I know a guy whose used some ~1" spacers on his GT3 race car for years and years with no problems. The fact is that lots of people use them and there's very rarely any problems. Sure having wheels with the correct offset is better, but spacers are fine too.
Old Mar 3, 2007 | 10:47 AM
franzo's Avatar
Newbie
My problem is that the wheels that i have (Enkei) the studs are to short for that rims and theres no mag lug nuts that fit in the rims
thanks
Old Mar 3, 2007 | 07:13 PM
Fault Bucket's Avatar
77333
These are the ones you want. I just put a full set on my '89. If you're not using spacers in the back you may need open-ended nuts.
-chris
Old Mar 3, 2007 | 08:46 PM
NCross's Avatar
duh moment... just reread the post....
does mazda speed or mazdatrix not carry longer studs?
Old Mar 4, 2007 | 01:00 PM
Black91n/a's Avatar
Not to my knowledge, because I don't think there's any that have been specifically designed for our cars, but lots of auto parts stores sell ARP stuff, so they can bring it in, or there's places like Summit Racing and Jegs.
Old Mar 4, 2007 | 01:18 PM
TehMonkay's Avatar
Back in the game
Are you sure you don't need tuner lug nuts? I wouldn't imagine a plain wheel without a spacer would have fitting issues.
Old Mar 5, 2007 | 03:48 PM
franzo's Avatar
Newbie
thank's alot guys
yes the problem is that the rims are to thick and the holes are like 7/8 so i think im going to get the arp ones for the front and the regular front ones for the back.
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
