Tranny
Old Feb 22, 2007 | 11:47 PM
  #51
GT1-20b's Avatar
Supra 6 speed to 20b
Originally Posted by mirabile
Ramy, just make something already damn it. Stop killing dreams.
Announcement:
Getrag W-160 6 speed ...OEM for Supra TT 2Jz adapted to Mazda 20b/ 13b
" TOTALY BOLT ON KIT "
No fab work, no welding, completly BOLT ON. and w/ off the shelf related components.
All CAD, CNC'd & Water Jet.
Adaptor plate, Dedicated Starter, Hardware, Trans Mount, Anular Release TO bearing,
Shifter Tripod, Instructions, Everything !
You supply gearbox
- Pictures and website coming soon !!
GT1-20b
Old Feb 22, 2007 | 11:51 PM
  #52
FDNewbie's Avatar
Sponsor
GT1-20b, that sounds badass. I know those boxes have been run on 1,000 hp Supras, correct? My biggest immediate concern is, the Getrag tranny is *considerably* longer than the stock FD tranny. Wouldn't that mean everyone will have to modify the PPF and possibly the driveshaft? And if you're moving the 20B back at all, I'd think the tranny would interfere w/ - if not completely block - the exhaust path, would it not? At least those were my impressions/concerns, which is why I looked elsewhere. Other than that, the tranny is a MONSTER...
One last thing: I'm not too familiar w/ the Getrag; are there upgraded internals and different gear ratios available on that tranny? W/ the huge Supra market, I'd think there would be...
Thanks!
~Ramy
Old Feb 23, 2007 | 12:16 AM
  #53
GT1-20b's Avatar
Thanks!
~Ramy
a) On the contrary, the W-160 is substantially shorter than the FD's
b) It will require a custome made drive shaft.
c) Every custom part required for convertion, I have made up except drive shaft.
d) There is only one set of ratios available for this box, as it was Type Specific
for the TT Supra, but the grear drops are closer that the FD's and very
favoravble for rotaries specially w/ an Auto's 3.90
e) You will have to buy some components, ie: clutch, Flywheel, but all
" off the shelf "
GT1-20b
Old Feb 23, 2007 | 01:12 AM
  #54
crispeed's Avatar
'Tuna'
Easy there Ernie. That's a lot of talk for someone w/ absolutely NO first-hand experience w/ the tranny, don't ya think? You just freakin got the thing! lol
And the "experience" you're speaking is exactly what I speak of. You go to the track how often a year? How many passes do you run? I'm talking about full-flegged professional race teams. Ppl who have been in the rotary before most of us even knew what they were. There's no heresay here. Ask ANY professional racer downunder, as well as several here in the US. They ALL agree that no matter HOW strong the internals are, the case itself WILL flex - because it HAS flexed on people in the past.
Moreover, PPG reuses several original Mazda parts, vs. say the Guru box that is 100% completely new/different parts. I know cuz I've done the research
But I mean hey, it's cool, I'm not gonna get into a fight about it. I just think it's ironic that you take the word of one-sided salesmen pitching their product - on something they've NEVER tested mind you, because they JUST made the new output shaft for the FIRST TIME EVER - over the tried and true experience of professional racers who are out to sell NOTHING. Plus, I've been warned about the case flex MULTIPLE times from VARIOUS sources. Makes me wonder...
Nothing new there. It was discussed and linked to in the threads I linked ya to earlier
And that the shift pattern is screwy IMO (doesn't follow stock shift pattern). Some ppl may not have a prob w/ that, but I'm POSITIVE that once - at least just once - I'd end up forgetting, and downshifting & rev-matching into the wrong gear, b/c I forgot the awkward shift pattern...prob is, that's all it takes - just once.
~Ramy
I see you've been doing your homework.
The first thing I always ask all these tranny companies as to what they do about case flex and they always come up with the same answer which is notting. If you're seriously making power and you're putting that power to the ground then I don't care what gear set you have in that box it's going to send the cluster gears/counter shaft south right out the bottom.
Ever wonder why all the tranny companies here stress the fact about upgrading the case and strapping the two shafts together. Gear separation is the major killer. I have so many cracked factory cases that were about to send the counter shaft out the bottom. I remember back in the early 90's I saw a pic from one of the Aussie racers showing a counter shaft that came out the bottom of the tranny. The guy went to great lengths even making a girdle to fit around the main case to help with the problem.
Old Feb 23, 2007 | 01:18 AM
  #55
crispeed's Avatar
'Tuna'
Originally Posted by ErnieT
If you want a tranny to handle all the torque you can handle, get this...
http://www.ppgearbox.com.au/
I got one and it can handle all you can throw at it. As for the stock casing flexing and breaking, thats plain horse ****. 90% of every casing on the market is made the same. Im not going on what other people "say". Im going on experience. Anyone can go on hearsay and rumor. We all know what that adds upto. PPG also offers an output shaft for this same tranny but its not needed unless your drag racing.
You're 100% sure of that Ernie?
Why don't you lend me your tranny for a weekend of racing.
Hope the tranny works out for you and it should. The second major draw back also with the stock tranny was the output shaft size. PPG has addrees that problem. Only time will tell if it can handle the abuse.
I really hope it works out for you Ernie.
Old Feb 23, 2007 | 01:44 AM
  #56
FDNewbie's Avatar
Sponsor
Hmmm Dunno where I got from then lol.
Easily done.
Nice!
d) There is only one set of ratios available for this box, as it was Type Specific for the TT Supra, but the grear drops are closer that the FD's and very
It's a 6 gear tranny rite? You know what the theoretical top speed is in 6th?
" off the shelf "
GT1-20b
Sounds very nice The two questions I have are:
1) What bellhousing are you using? And how deep is it?
2) Can the shifter location be modified? Specifically, can it be moved forward some? I don't recall whether or not the Getrag has a forward mounted access plate or not...
FINALLY! lol. Thanks for your $0.02
You don't have a copy of that pic by any chance, do you? Because there have been quite a few unbelievers of what is essentially "common knowledge" in other rotary circles...
~Ramy
Old Feb 23, 2007 | 03:27 PM
  #57
calculon's Avatar
On flats
The 6th gear in the getrag is actually shorter than the 5th in the FD. I don't remember exactly, it's not much. THe source is a thread where Jimlab posted up a few different tanny specs and pointed this out. . . if i remember right, this tranny makes 1st gear basically useless unless you get a much taller diff gear.
sorry for the lack of specificity, just too lazy to dig it up.
ryan
Old Feb 23, 2007 | 03:39 PM
  #58
RX-Heven's Avatar
I'll blow it up real good
Announcement:
You supply gearbox
Are there dog-ring conversions available for this tranny?
I found one for the Gertrag V-160 6-speed offered by PPG. What is the differecne in case/internals design betweent the V and W versions?
http://www.powerhouseracing.com/file...ine%20Upgrades
Old Feb 23, 2007 | 05:28 PM
  #59
FDNewbie's Avatar
Sponsor
That PPG gearset sounds sweet, esp w/ custom gear ratios With this new news, I really think we need a side-by-side comparison of the T56 vs. Getrag trannies. The obvious one here is that GT1-20b's kit is bolt-on, but I'm still waiting to hear back re: shifter (re)location info.
~Ramy
Old Feb 23, 2007 | 05:44 PM
  #60
mirabile's Avatar
and price of the GT1-20B set up?
Old Feb 23, 2007 | 05:46 PM
  #61
FDNewbie's Avatar
Sponsor
Oh yea...and that too
Old Feb 23, 2007 | 05:55 PM
  #62
patman's Avatar
Resident Know-it-All
i was under the impression that the supra getrag trannies were pretty rare and hard to find? Gt1-20B do you have a source for them that they would come with the kit, or would the buyer have to find one?
Old Feb 23, 2007 | 05:58 PM
  #63
FDNewbie's Avatar
Sponsor
Last I checked, they're still available new. And for those who would be getting the PPG gearset, there's no prob in buying a used blown one off of Supraforums
Old Feb 23, 2007 | 09:11 PM
  #64
Howard Coleman's Avatar
Racing Rotary Since 1983
93 supra TT ratios
1st---3.83--- really low unusable... supra had a 3.4 rear end
2nd---2.36--38% drop. from 7000 to 4319 rpm too much spacing
3rd--1.69---28% drop from 7000 to 5012. o k
4th--1.3----22% drop from 7000 to 5426 nice
5th--1----24% drop from 7000 to 5343 nice
6th--.79---21% drop from 7000 to 5530 nice but limits top speed to around 150 w 4.1 rear and there is no real low cruising mileage 6th.
how does the box shift at 7500+ rpm?
what is the weight of the box?
hc
Old Feb 23, 2007 | 10:25 PM
  #65
RX-Heven's Avatar
For an easy comparison....
Standard TII ratios:
3.483 / 2.015 / 1.391 / 1.1 / 0.719
PPG offerings for the Supra 6-speed gearbox:
3.20 / 2.19 / 1.56 / 1.20 / 1.00 / 0.83
Borg Warner 6sp T-56 Gear Ratios:
2.66 / 1.78 / 1.30 / 1.00 / 0.74 / 0.50
PPG ratios for the dog box conversion in a stock RX7 case:
2.527 / 1.805 / 1.381 / 1.155 / 1.000
And Gurus offerings for a dog box conversion in a stock RX-7 case...
Guru Circuit gear ratios:
2.387 / 1.705 / 1.339 / 1.444 / 1.0
Guru Targa gear ratios:
2.648 / 1.804 / 1.406 / 1.162 / 1.0
Old Feb 23, 2007 | 10:39 PM
  #66
RX-Heven's Avatar
If GT1-20b could answer this:
I found one for the Gertrag V-160 6-speed offered by PPG. What is the differecne in case/internals design betweent the V-160 and W-160 versions or are there any?
I will be all over this if I can fit the PPG dog gears in the tranny he is doing the conversion for. Hell, I'll be first in line for that matter by placing a pre-order as this is EXACTLY what I have wanted and been hoping for all along.
Old Feb 23, 2007 | 11:09 PM
  #67
GT1-20b's Avatar
Stand corrected.
The correct Getrag designation IS V-160
Apologies for the Typo error.
Thank You.
Now, I'll try to answer some questions ...
This gearbox is Type Specific to the Toyota Supra TT. meaning it was specifically designed for that car, that engine.
The 2Jz. Therefore the bellhousing is NOT detachable or removable.
The bellhousing is part of the main case. So you must convert the engine to gearbox bolt patern to that which the boxe's bellhousing will accept.
The "Kit's" adaptor plate, adopts and places the bolt pattern of the 2Jz onto the Mazda, so the Supra's TT gearbox just " SLIPS ON ".
A dedicated Tilton style Reverse Rotation Super Starter is then installed in the hole were originaly the Supra's clutch release slave cylinder would normally go.
The box is crossectionally bulkier, but substantially shorter than the FD's.
This will be illustraded in a side-by-side comparison when the pics. are uploaded.
Stock, this gearbox is capable of handling well over 1000 HP, corresponding monster torque, with sure & lightning fast shifts.
The shifter sits in a tripod base separate from the main case.
Theoretically, one could place the shifter as close or as far away as nesesarry.
No forward access cover provided or nesesarry.
The box is stronger, lighter, and physicaly smaller (more compact) than a T-56.
The Kit's ancillary components, ie: Clutch, Flywheel, Release bearing, ect. are all
"off the shelf " components.
The phylosophy of design was based around the use of readily available proven name brand pieces and components.
Street: Tilton 8.5 Dual Disc OT series on either Aluminum or Steel Flywheels, w/ 750 Lbs/Ft. torque holding capasity.
Race: compatible with any 7.25 or 5" inch 2, 3, 4, disc, or Carbon/Carbon clutch pacage.
Racing: several vendors offer Dog ring engagement close ratio gear sets for this box. ie: the PPG as previously mentioned.
Ryan mentiones: the " USELESS " 1st. gear, and shorter top gear than FD's
This is partly true but NOT correct. Depends on use and intended purpose
This box as used in the Supra, was combined w/ a 3.13 Ring & Pinion final drive.
As oposed to the FD's Standard 4.10 or 3.90 for the Auto's.
As a Street racer and weekend Drag warrior, the gears are perfect for hard launches, best acceleration, and great ET. 6th. gear, not 1st. then becones useless as it will never be used in that senario.
As a Track day car, again the very close grear drops combine w/ the FD's final drive provide for excelent ratios for ANY track.
In this senareo 1st gear would not be used except for pit row.
Even with this low 4.10 final drive, asuning a 26.5" diameter of an average 17" wheel & tire, at 8200 Rpm in top gear if ther is enough power to get to that RPM, it equates to 198.99 MPH.
With the Auto's 3.90 now we're talking 209.30 MPH.
I wonder how many of us have the COJONES to drive our "street cars" that fast ?
I know I don't !, ...and as most of you know, I drive and have driven some pretty fast racecars.
Now, If Non-Real world Hypothetical numbers game turns on your fancy, and Theoretical MPH #'s is what you'r after, do as the V-8 guys do, install a Cobra 8.8 IRS Diff, pick the terminal speed you want from a wish list, do the math and
install the gear that will get you there. ...v For example:
A common Ford final gear like a 3.08 X a top gear of .793 as in the Supra box's top 6th gear at say 8000 Rpm. with the same 26.5" rear tire diameter.
That will yield a top speed of 258.59 MPH. WOW,
This is absolutly unreal and imposible but in theoretical terms ?? what the heck !.
As for a price, I don't have one figured out as yet.
But I know it will be substantially cheaper that a complete T-56 convertion.
For now it will be on a per order basis.
I have built enough parts for 3 Kits besides my own.
Who knows, if enough interest is generetad, maybe a GP can be arranged.
If interested or have specific questions, PM me.
Thanks
GT1-20b
Old Feb 23, 2007 | 11:24 PM
  #68
RX-Heven's Avatar
I got first dibs on one of them you have available.
pm me any deposit info
Old Feb 23, 2007 | 11:28 PM
  #69
FDNewbie's Avatar
Sponsor
If everything works out as previously described, I'm 2nd in line.
Old Feb 23, 2007 | 11:32 PM
  #70
Doc Holiday's Avatar
Needs more cow bell
Why not just throw a Richmond box behind it? Seems like it would cost a lot less.
Old Feb 23, 2007 | 11:39 PM
  #71
mirabile's Avatar
Group Buy Group Buy Group Buy
Old Feb 23, 2007 | 11:43 PM
  #72
GT1-20b's Avatar
True, would cost less.
But not as elegant or presice
Plus the external shift rods to constantly deal with.
Old Feb 23, 2007 | 11:52 PM
  #73
FDNewbie's Avatar
Sponsor
https://www.rx7club.com/showpost.php...5&postcount=12 They have a very low torque rating. Useless IMO.
Old Feb 24, 2007 | 08:22 AM
  #74
IronMdnX's Avatar
Glutton for Punishment
Just saw this update.
Very interested, Looking forward for pictures and more info.
Old Feb 24, 2007 | 09:36 AM
  #75
re the supra trans.
since the bellhousing must be supra it will be important that it is not too bulky for some.
i run two 3 inch downpipes and the FD bellhousing works just right in relation to the tunnel. should the supra bellhousing be larger i would have a problem and would not hack up the tunnel to fix it.
i understand that others might not have the problem and of course you would have lots more latitude if you are running a dedicated racecar or if you run a 20b and have it moved back a bit.
i do agree w Carlos that if you ran the cobra rear and had a wide array of rear axle ratios that the overall gearing w regard to trans ratios could be worked out... and we each could pick what would work according to our needs.
i am planning on running the Silver State Classic so i need a bit of legs to my final drive ratio and it could be done w, say, a 3.12 and turn 4th into a 1 to 1.
howard coleman
