clunk when comming to a stop
Old Mar 4, 2002 | 12:35 AM
skunks's Avatar
I'm a CF and poop smith
hi has anyone run in to a problem where when you car coming to a stop, there is a clunk or two that comes from your tire area, mines does this every once an a while. i know that the brake rotors are a little out of round/warped but it never clunked before, what do you guys think it is? just started today by the way.
Old Mar 4, 2002 | 01:21 AM
Ninjak's Avatar
is it comming from your rear? if so, your bushing for either the trailing arm or the toe links are going bad, try jacking up the rear of the car and then shaking the wheel as much as you can, and see if you can pinpoint where the clunk is coming from... tell us your year and make and it would help. But these things DO get old on our cars FAST. you can buy replacements from pettit or from M2 Performance.HTH
Huy
Old Mar 4, 2002 | 01:48 AM
Qball's Avatar
Comp Yellow Mica
clunk
i have a 94 with 90k.. it clunks when i hit the brakes backing out.. its annoying but i only hear it when going backwards..
i think i'll just change the all the bushings back there.. is there a kit? how many bushings and is it a bitch to do.. or get some pros to do it.. okay.. laters
Old Mar 4, 2002 | 02:13 AM
DK's Avatar
DK
40k worth of fail
Bushings ... but also if you had anything recently done springs/shocks wise make sure that everything got put back on.
Old Mar 4, 2002 | 10:38 AM
mr_jonboy's Avatar
Mine did this as well even though I haven't heard it in awhile. But it would always do it right when I hit the brakes. I always thought it was coming from the front but it could be from the rear. If I get under the car, where am I looking for the bad bushings. Where are the ones that are usually the problem. Also getting a replacement for these will eliminate or minimize wheel hop, correct?
Old Mar 4, 2002 | 10:56 AM
ZoomZoom's Avatar
SEMI-PRO
Re: clunk
Well it may be coming from the rear. I suggest checking your front control arms for grooves from an end link rubbing. Mine used to do that before I replaced the sway bar mounts. Those mounts bend easy and cause misalignment of the sway bar and the end links rub grooves into the control arms. Check it out. I only used to do it when going in reverse.
Old Mar 4, 2002 | 11:08 AM
ttpowerd's Avatar
HARRRRRRRRR
Mine comes from the rear only when I start breaking, every now and then. I replaced the trailing arms which eliminated the knocking noise that came from the rear right but now I have this problem.....will toe links help out here?
Old Mar 4, 2002 | 02:43 PM
Lightbulb Yea mine to
yea thats exactly what mine was doing as well.. It was only doing it in reverse but now it just started doing it while i was driving( between shifts) I was like come on, whats the deal. So this wkend iam going to do a lil teardown to find out wassup with it..1 of the guys at this forum gave me this link :
the pillow *****
Old Mar 4, 2002 | 02:59 PM
Toadman's Avatar
Nomad Mod
pray it's not your powerplant frame. :/
Old Mar 4, 2002 | 06:34 PM
thatoneguy's Avatar
Actually, the Powerplant frame is cheaper and easier to replace than the bushings.
trickster
Jul 1, 2023 04:40 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Michael Mansour
Aug 18, 2015 03:13 AM
