New product: Banzai Racing Starter Relay Kit
Old Jan 12, 2018 | 07:17 AM
Banzai-Racing's Avatar
Rotary Specialists
Starter Relay Kit for all Mazda RX-7's
The "click, click, start" issue is a very common problem with the RX7, as the electrical components age the problem gets worse. Our easy to install Starter Relay Kit mounts next to the starter to insure that the solenoid gets full voltage when you turn the key. We have developed this kit utilizing a completely waterproof 40amp relay with a built in resistor for voltage spikes, all terminals have heat shrink insulation for durability and protection.
Works with all starters.
High Torque 2KW Starter & Starter Relay Kit (93+ RX-7)
Old Jan 12, 2018 | 09:04 AM
Johnny Kommavongsa's Avatar
Nice,just had this issue this morning.
Just ordered one.
Old Jan 12, 2018 | 12:43 PM
neit_jnf's Avatar
I had the Pettit version and I had to take it out to resolve a click no-start issue. Is this one different?
Old Jan 12, 2018 | 12:54 PM
Rotary Specialists
Actually if I remember correctly, you had a no start issue from installing an high torque starter that pulled too much amperage for the 30amp relay that they provide. Basically it fried the relay.
Ours is a 40amp relay with an internal resistor for maximum voltage spike protection. Additionally our is water proof with sealed terminals.
Old Jan 12, 2018 | 01:27 PM
insightful's Avatar
rotorhole
the bosch sealed units are still typically rated 30/40a, so the switched end is the same as the standard 30a relays, haven't seen any rated 40a off the switched side yet unless these are special.
Old Jan 12, 2018 | 01:31 PM
Rotary Specialists
Not a Bosch relay
Old Jan 12, 2018 | 06:41 PM
neit_jnf's Avatar
Yes I had it with a high torque starter, didn't think it would fry the relay. I may give yours a try. Thanks!
Old Jan 13, 2018 | 08:22 AM
Rotary Specialists
More pics & installation instructions Starter Relay Kit Installation Instaructions
Old Jan 13, 2018 | 11:52 AM
Project88Turbo's Avatar
Stock boost FTW!
Nice product! I'm glad you continue to make things for our cars.
Vince
Old Jan 18, 2018 | 12:02 PM
Montego's Avatar
Don't worry be happy...
Nice! mine does that from time to time. Looks like I'm shopping
P.S. Thanks Goodfella for leading me here through your thread
Old Jan 18, 2018 | 04:15 PM
insightful's Avatar
rotorhole
Not a Bosch relay
the Hella relays are still rated at 30/40A respectively(i put bosch when meant hella), only real difference is the sealing of the unit if it is mounted in a way that water can get in.
Old Jan 18, 2018 | 04:31 PM
Rotary Specialists
Not Hella, Ben.
Old Jan 25, 2018 | 07:29 PM
rowdog_14's Avatar
Yep I saw this a few days ago prior to even seeing this thread. You will probably see an order come through monday for one and some vacuum lines
Old Jan 31, 2018 | 09:45 AM
Rotary Specialists
Actually nearly all of my product development is derived from necessity (the mother of invention). Both of my FD's have been "click, click, starting" , even after bypassing the security relay, replacing the starter, ignition switch, clutch switch, running the battery directly to the starter and running new grounds. I came up with this Heavy Duty Relay after seeing others for sale that consisted of a standard plastic tab mount $6 relay that was not waterproof and had non-heat shrinkable crimp connectors trying to sell for $30-$50. I have been working on this for several months off and on, to come up with a superior product that can handle the draw of our High Torque starters and provide protection from the elements under a car. I decided our product needed to have a metal mounting bracket and that all connections would be sealed, even the crimp terminals can't be pulled off. It is pretty easy to pull the wire out of a standard parts store terminal, ours are all Molex heat sealable crimp terminals.
Old Jan 31, 2018 | 11:42 AM
Rotary Specialists
Standard Relay vs. Sealed Relay
Old Feb 1, 2018 | 08:31 PM
rowdog_14's Avatar
Starter relay installed...Banzai did a really good job on this. Only other relays I have seen with this quality is EasternBeaver for my motorbike headlights.
Old Feb 2, 2018 | 09:46 AM
Rotary Specialists
Our relay can be swapped for any OTS relay as it has a standard pinout. Or even just connect the starter wire back to the solenoid.
Rreally? Hmm, I have seen the $6 unsealed relay you try to sell on ebay. Time to go crap in someone else's thread. Probably time to have the admins clean up your garbage posts.
Old Feb 2, 2018 | 09:47 AM
rowdog_14's Avatar
insightful, going to send you a PM. I just do not want to muddy up a post like most people do here. Thanks
Old Feb 12, 2018 | 02:04 PM
Rotary Specialists
Pleased to announce that starting 2/13/2018 we will be shipping our Version 2 that features a 50 amp weatherproof relay. It is compatible with a Version 1 harness.
Old Apr 20, 2018 | 11:46 PM
94 R2's Avatar
Is there a benefit to this if we do not experience the "click, click, start" issue?
Thanks!
Old Sep 18, 2018 | 02:50 PM
Rotary Specialists
Thanks!
It would potential prevent it from happening in the future, otherwise No.
Old Jan 27, 2020 | 02:20 AM
Carpe_Diem_7's Avatar
May I ask what was the need for a version 2 (50A) relay over version 1 (40A)? Is it for FDs with high torque starters?
Old Jan 29, 2020 | 06:01 AM
Rotary Specialists
Just an even better relay
Old Jan 16, 2021 | 12:30 AM
firecaddie's Avatar
Help Troubleshooting
So I had a 1 click no start issue, and ended up purchasing the 2kw starter from banzai due to the weak startup on original. After installed same issue 1 click. I’ve replaced the clutch start switch, ignition switch and added the Bonzai starter bypass relay. I think this bypass the security relay ? So after all that same issue. 1 click no start. The 95 FD has a remote fob lock system and had a Lo Jack system that was never removed. I have done hours of research and I’m out of ideas. Everything works full power no start 1 click. I’m down to relays or the main ground system off battery. Bonzai customer service said it sounded like I need a new security relay. I thought the bypass relay took care of that. Anyone that has insight or can explain what else I can do. ? I’m desperate.
Old Jan 19, 2021 | 02:00 PM
Rotary Specialists
The bypass does eliminate the security relay.
