Upgrading 100% 93 Stock FD. Suggestions...
Old Dec 21, 2017 | 09:47 AM
  #151
adam c's Avatar
Cheap Bastard
Originally Posted by cloead
Little butt hurt are we? If you are trying to argue that it's just as easy to look down below your stereo to read a gauge vs. an a-pillar pod, center speaker pod, hell ANY pod that's in your line of sight then it is more than obvious who the dipshit is.
The butt hurt statement sounds like the voice of experience. Maybe you should carry a cushion around with you.
I have had DIN mount gauges in my car for nearly 15 years. I never had any problem taking a quick glance at my boost gauge to see what its doing. Some tasks are too difficult for impaired people. You should probably stick to something easier.... Dipshit!!!
Old Dec 21, 2017 | 10:00 AM
  #152
rowdog_14's Avatar
Man you all seriously know how to derail a thread. This thread would not be 7 pages long if not for the derails...
Old Dec 21, 2017 | 10:44 AM
  #153
RA8225's Avatar
Banned
I'm a fan of the center speaker pod myself. In my opinion it looks better than the A-pillar or where the stereo used to be. To each his own however
Old Dec 21, 2017 | 10:54 AM
  #154
cloead's Avatar
sold--no longer in debt
Still melting down? That's cute.
Old Dec 21, 2017 | 02:03 PM
  #155
rowdog_14's Avatar
@cloead and adam c can you all direct message each other directly and hash it out there. Thanks
Old Dec 22, 2017 | 07:12 PM
  #156
rowdog_14's Avatar
efini Y-pipe came in.
Old Dec 22, 2017 | 07:13 PM
  #157
rowdog_14's Avatar
Old Dec 27, 2017 | 06:35 PM
  #158
rowdog_14's Avatar
Well started taking off the y-pipe and downpipe. Will be ordering some new rubber lines too.
Old Dec 28, 2017 | 08:24 AM
  #159
rowdog_14's Avatar
You can see the swollen coolant hose in this picture!!!!
​​​​​​​Factory Y-Pipe out and easy access to downpipe. Letting the bolts soak for a day the hitting them again and letting them soak. Probably take the downpipe off Saturday.
Happy I changed out the y-pipe because I had a coolant hose ready to blow. You can see in the picture that has the end of the socket wrench touching it.
Old Dec 28, 2017 | 01:58 PM
  #160
alexdimen's Avatar
TANSTAFL
If it hasn't been mentioned there is an updated version of the coolant hoses with a more heat resistant reinforcement braid (probably Nomex or similar vs standard Nylon). I bought the coolant hose kit from Malloy Mazda when I did my rebuild. They probably still offer it.
​​​​​​​Definitely wouldn't use off-the-shelf hose unless it is high temp especially that close to the turbo.
Old Dec 28, 2017 | 02:50 PM
  #161
rowdog_14's Avatar
Thanks will look into that.
Old Dec 28, 2017 | 04:54 PM
  #162
rowdog_14's Avatar
​​​​​​​I could not wait . All nuts came off clean except one. Stud came out on the first one but it was clean. With all the so called horror stories about these nuts and downpipe....seems like an easy upgrade for me that just takes a little time.
Old Dec 28, 2017 | 07:39 PM
  #163
rowdog_14's Avatar
Well dang nut on the stud on the main cat will not break!!!!! I have soaked and soaked and soaked...heated and heated and heated. Last resort is a nut cracker.
Old Dec 29, 2017 | 03:53 AM
  #164
Sgtblue's Avatar
Urban Combat Vet
Edit
Old Dec 29, 2017 | 07:46 AM
  #165
rowdog_14's Avatar
I am officially beat!!!!! Started cutting it and that did not work, and I bet a nut splitter would not have either. Guessing I am going to have to curt the whole stud off. Any suggestion prior to me doing this? Will wait an hour for a reply
Old Dec 29, 2017 | 07:49 AM
  #166
rowdog_14's Avatar
Old Dec 29, 2017 | 08:33 AM
  #167
silverTRD's Avatar
Time or Money, Pick one
What did you use to heat it? You need to get that thing super hot when it’s good and stuck. I’ve used a map gas torch before which is hotter than propane and it didn’t work. Then I got the oxy/acetylene rig out and that was able to loosen it. Of course it would have cut it off had I chose to go that route. Good luck
Old Dec 29, 2017 | 08:43 AM
  #168
rowdog_14's Avatar
Yeah propane torch. I am going to cut it off. Too much oil residue and liquid wrench all over the place.
Old Dec 29, 2017 | 08:56 AM
  #169
adam c's Avatar
Cheap Bastard
Just unbolt the other end of the cat, and remove both at the same time.
Old Dec 29, 2017 | 09:17 AM
  #170
rowdog_14's Avatar
Damn I did not think of that. It is 3/4 cut off now.
Old Dec 29, 2017 | 10:34 AM
  #171
rowdog_14's Avatar
Thanks!!!! I just did that. Took like 5 minutes. My butt was trying to only take off the downpipe and should have just did what you mentioned. Wish I would have posted this last night . Thanks again!
Old Dec 29, 2017 | 10:35 AM
  #172
rowdog_14's Avatar
Old Dec 29, 2017 | 10:44 AM
  #173
rowdog_14's Avatar
I know I do not need a mid pipe but with this all off I probably will just do a high flow cat and watch the boost while driving until I get a boost controller. Not 100%...so do not go crazy guys because I am probably going to put the stock cat back on.
I know I put the cart before the horse on this one . Will send the downpipe out to get coated, get coolant hose, get lines for new y-pipe that broke, get gaskets, and debate on new cat. Mainly did this first so that I would not keep driving it over the winter
Old Dec 29, 2017 | 04:58 PM
  #174
adam c's Avatar
Cheap Bastard
Glad that worked for you. Now likely easier to separate them without the car in the way.
Old Dec 29, 2017 | 11:49 PM
  #175
zaque's Avatar
I have that Racing Beat exhaust on mine. It's really nice and I'll probably never change it. It's the best sounding exhaust and looks pretty much stock. Also less worry about it scraping like big fart cans can.
Originally Posted by Montego
Yep... and yet you can't explain how a MP affects AFR's and also believes that the stock fuel system cannot sustain all boltons at 10psi.
I don't know if it really changes the AFR (aren't there sensors for that?), but reducing exhaust backpressure does change the point (as in, how high RPMs get) at which delta engine pressure goes from negative to positive which does change overlap, and rotaries like having a little overlap.
Afaik, the "liking overlap" comes down to helping cool the engine and reducing knock, and I'm not sure about any effect on AFR.
Ideally, you'd have a restrictor that closes up at lower RPMs in these cars to increase exhaust pressure, and thus exhaust manifold pressure, and thus keep engine pressure delta positive at lower RPMs while opening up at higher RPMs. I think those improve spool times as well.
So yeah. I'd agree on not getting too high flowing of an exhaust, and not removing precat with the stock ECU.
