Fuhnortoner's 88 FC "Quest for 400 Horsepower!"
Old Apr 23, 2017 | 12:36 PM
  #126
roTAR needz fundZ
ahh ok
well whats the quest for now? LS' are in the 300 hp range are they not? Getting another 100 out've it should be easy, with minor things like the cam you mentioned, headers, and tune.
I am no help on a cam, there are so many cam options for all v8s its mind boggling, and headache worthy
Old Apr 23, 2017 | 09:55 PM
  #127
FührerTüner's Avatar
Penis Healthy
Old Apr 24, 2017 | 01:05 AM
  #128
LargeOrangeFont's Avatar
Fistful of steel
Originally Posted by Fuhnortoner
Why is the ronin kit bette? Whats the difference? Do they offer a drive shaft?
Just gonna nos it and go, maybe a cam. Any recommendations for a cam?
Ronin kit is lighter, engine is easier to insert and remove, more exhaust and engine bay space and exhaust can be routed straight.
With Granny's your exhaust needs to go over the trans cross member.
C4 Corvette aluminium driveshafts work with the correct rear flange swapped on. Or Granny's driveshaft.
Orders Granny's swaybar relocation brackets, and Stu Kelly Motorsports clutch master cylinder bracket.
As far as a cam, yea there are many that will get you to around 400 WHP with what you have. You'll need to upgrade the valvesprings at a minimum for any cam. You'll need bigger injectors to make the 400 WHP.
As far as a recommendation, do you value nicer street and low RPM manners? I'm a big fan of the ASA cam, I have one in my car and it made 401/401 to the tire. It has got a lot of overlap so it sounds pretty mean. Low RPM manners are not the best but it is pretty street able. It has relatively low lift ,which is easy on the valve train, and it has a wide powerband.
My car makes over 350 ft.lbs. of torque form 3500 RPM to 6700 RPM.
There are many other cams that will get you there, some with a slightly narrower powerband, that have better street manners, some with more aggressive lift, lots of options. With an otherwise stock motor you don't want to get too aggressive, but 400 WHP or close is doable with a good exhaust and intake.
Old Apr 24, 2017 | 08:11 AM
  #129
Penis Healthy
Hmmm. Maybe ill just leave her stock and run the nitrous kit for now. Have some pondering to do.
BTW im running the 4l60e for now, so i think theres no need for the clutch master cylinder kit as of yet.
Old Apr 24, 2017 | 09:24 AM
  #130
Lavitzlegend's Avatar
Spin 2 Win
What is the ECU/Engine out of? Is it not a candidate for using HP Tuners?
Old Apr 24, 2017 | 09:42 AM
  #131
Fistful of steel
It's a Camaro/Firebird engine, harness and ECU. HP tuners will work on it it's going to need a reflash anyway to turn off VATS so it can run at a minimum.
Old Apr 25, 2017 | 12:00 AM
  #132
Penis Healthy
OK so i think i have some things figured out.
1. Cam: 224 112 +4 good streetable cam with flat torque curve, and a lil lopey. +50rwhp???
2. I know i need valve springs. Not sure which ones to get or what the differences are. I'm thinking comp 918s, but thats just from what i read on other people's setups.
3. Short header with catless X straight pipe. Cold air intake. Port TB. +20rwhp
4. NX Plate wet kit, 100 shot.
So that puts me close to 390-400whp without the squeeze. Should i be fine with the stock injectors? Because i really dont wanna spend more money.
Old Apr 25, 2017 | 12:14 AM
  #133
Penis Healthy
Oh yeah and this came. My birthday was 2 months ago.
Old Apr 25, 2017 | 12:30 PM
  #134
Narfle's Avatar
Rx7 Wagon
Plan:
eBay turbo build on a 30yr old jdm t2 block with no rebuild
strap NOS to an LS pullout
Godspeed, sir.
Old Apr 25, 2017 | 12:55 PM
  #135
Penis Healthy
Originally Posted by Narfle
Plan:
Godspeed, sir.
Right? For half the price too! What was I thinking?!?!
Old Apr 25, 2017 | 01:36 PM
  #136
Narfle's Avatar
Rx7 Wagon
A couple guesses:
"Hey! Watch this!"
"What could possibly go wrong?"
"I got this."
In for rod knock.
Old Apr 25, 2017 | 01:59 PM
  #137
Penis Healthy
Haters gonna hate. Keep workin on that interior bud!
Old Apr 28, 2017 | 01:18 PM
  #138
Penis Healthy
Well engine made it in one piece!
On top of the Nitrous kit I purchased a Comp cam, 223/230 .585/.600 111+1, should give me a nice lopey idle to make all the girls panties wet. But really, has a supposed flat torque curve, super easy to drive even with the lopey idle. Springs on the way as well. Expecting 350whp
Purchased an engine install plate that bolts to the intake manifold area. this thing was a bitch to get off the trailer using the tranny bolts.
Picked up a new soldering tip for my Weller, some shrink tube, and 200 feet of 18ga wire to start the harness rebuild/reroute.
Still waiting on my granny kit. Those guys dont like to answer the phone after they have your money.
Ive been working so much lately i havent had time to do ****. Think im off this weekend. Cant wait to start working on this thing
Old May 31, 2017 | 02:19 PM
  #139
Penis Healthy
Finally found some free time over the holiday to put in some work on this bad boy.
Old Jun 14, 2017 | 11:45 AM
  #140
Penis Healthy
Slow progress. Anyone have any recommendations on where i should mount this relay and fuse block? I made a lot of slack on the harness, pretty much free to go anywhere on the passenger side of the cabin.
Old Jun 15, 2017 | 11:03 AM
  #141
Penis Healthy
Just need to finish looming and this harness is done, finally!
Old Jun 16, 2017 | 10:52 AM
  #142
Penis Healthy
Harness finally complete. Wires ended up being tighter than I originally laid it out. Wanted to run the harness in the valley between the heads and the valve covers, but I'll have to settle with the stock location.
Old Jun 19, 2017 | 12:23 PM
  #143
Penis Healthy
Old Jun 20, 2017 | 03:43 PM
  #144
Penis Healthy
Oven Cleaner oxidized the aluminum a little bit, but ill be painting the valves covers and timing cover anyways.
Old Jul 5, 2017 | 06:07 PM
  #145
Penis Healthy
Cam in. Valve springs in.
Old Jul 17, 2017 | 08:34 AM
  #146
Penis Healthy
Old Jul 18, 2017 | 12:31 PM
  #147
Penis Healthy
Brake booster, windshield wiper motor and arms, windshield grill reinstalled. Front body harness cleaned up and wrapped with nylon.
Mocking up intake manifold setup. 30lb injectors on the way.
Old Jul 31, 2017 | 07:27 AM
  #148
Penis Healthy
New melling pump shimmed and installed. Water pump housing, alternator, pulleys, belt installed. Cracked my damn oil pan near the oil filter. 250 dollar mistake. Installed short tube headers. set the manifold on to see how its going to look. Did a little shooting on sunday as well.
Old Jul 31, 2017 | 07:28 AM
  #149
Penis Healthy
Old Sep 18, 2017 | 07:42 AM
  #150
Penis Healthy
Finally found some motivation...
