Fuhnortoner's 88 FC "Quest for 400 Horsepower!"
Old Mar 14, 2017 | 08:37 PM
  #101
FührerTüner's Avatar
Penis Healthy
Changed the fuel pump from a walbro 255 to an aeromotive stealth 340. Also added new oem fuel sending unit.
Old Mar 14, 2017 | 09:27 PM
  #102
LargeOrangeFont's Avatar
Fistful of steel
If you ever go with coilovers up front you will gain some tire space up front.
I made 17x9+24 wheels fit with 235/40/17 NT05s with stock style shocks (Tokico blues and RB springs) and got no rubbing. NT01s run wider though. My 255 NT01s were within 1/4 in of my friend's 275 NT05s.
How do you like that Stu Kelly motor sports fuel hat? I'm still running the stock unit with my Walbro 255.
Old Mar 14, 2017 | 10:53 PM
  #103
Penis Healthy
Love the stu Kelly pump hanger. Seals really good.
On thing I could say that is wrong with it is the screws that come with it. They're painted black. This causes a problem with the fuel level sender. The sender uses the ground from these screws into the gas tank. I had no fuel gauge operation until I added a ground wire to the top of the hanger, and attached it to a clean spot near the spare tire well. That restored full fuel gauge operation.
Old Mar 15, 2017 | 09:18 AM
  #104
Lavitzlegend's Avatar
Spin 2 Win
I guess I would still highly suggest at least running water injection. It doesn't cost all that much for a kit and it provides peace of mind, steam cleaning of carbon deposits, and cooling the air charge for more power. I certainly get a bit weary of average fuel quality here in the midwest. All it takes is 1 bad detonation moment to ruin your fun... It's pretty much universally suggested in the single turbo forum even if you aren't running crazy high boost levels.
LOF, are you running the Cobra R reps as well? Seems odd that we would have the exact same wheel specs otherwise haha
Old Mar 15, 2017 | 12:02 PM
  #105
Penis Healthy
Z32 wheels
Old Mar 15, 2017 | 08:57 PM
  #106
Penis Healthy
Z32 wheels installed.
Old Mar 16, 2017 | 11:07 PM
  #107
Penis Healthy
Old Mar 17, 2017 | 07:10 AM
  #108
roTAR needz fundZ
hopefully you were on you way to the gas station
Old Mar 17, 2017 | 07:59 AM
  #109
Penis Healthy
Just goin around the block to test the plugs and check oil when i got back. But yeah, I need gas.
*Replaces fuel level sender with new OEM. Still runs out of gas*
Old Mar 17, 2017 | 01:11 PM
  #110
roTAR needz fundZ
My thought exactly, would be kind've an oxymoron
Old Mar 17, 2017 | 04:50 PM
  #111
Fistful of steel
Yea I used to have Cobra R wheels. Now I have 17X10.5s all around.
Old Mar 18, 2017 | 05:44 PM
  #112
Penis Healthy
Old Mar 19, 2017 | 06:58 PM
  #113
Penis Healthy
Old Mar 20, 2017 | 08:19 PM
  #114
Penis Healthy
Old Apr 10, 2017 | 09:29 PM
  #115
Penis Healthy
A new chapter begins.
Old Apr 11, 2017 | 09:03 AM
  #116
Spin 2 Win
We lose another one to the dark side... ha. What engine management are you switching to? EFI Source has some nice MS3 kits already wired for LS setups
Old Apr 11, 2017 | 09:20 AM
  #117
Penis Healthy
Most likely gonna use the GM ecu.
Old Apr 22, 2017 | 01:21 PM
  #118
Penis Healthy
90k Drop out in the mail. Grannys LS kit in the mail.
Also bought a little something to get me to that 400 mark.
Old Apr 22, 2017 | 08:11 PM
  #119
DC5Daniel's Avatar
There's a problem here...
8 too many cylinders and at least 2 too few rotors!
Old Apr 22, 2017 | 09:24 PM
  #120
Fistful of steel
It may be too late, but the Ronin kit is the better mount kit.
Nice pickup on the engine. Gonna run the auto trans or switch to manual?
Just going to NOS it and go, or are you going to mod the engine at all?
Old Apr 22, 2017 | 11:44 PM
  #121
misterstyx69's Avatar
Retired Moderator, RIP
I wanna meet the guy that has to put this stuff into a shipping Envelope!..lol!
Personally I am done with the argument of what is better for the car.
Doing whatever to the car to make power is the goal..and the car still is the OWNER's to do whatever he wants to it..so You Go man!
Heh..I'm behind you 100%....Really..I'm behind you,look in your rear view..hahah!
Old Apr 23, 2017 | 08:56 AM
  #122
roTAR needz fundZ
only cause you followed the same road
least you did it right and went with a ford engine
Old Apr 23, 2017 | 10:18 AM
  #123
Penis Healthy
Why is the ronin kit bette? Whats the difference? Do they offer a drive shaft?
Just gonna nos it and go, maybe a cam. Any recommendations for a cam?
Old Apr 23, 2017 | 10:52 AM
  #124
roTAR needz fundZ
If your gonna run the stock ecu your options are gonna slim cam wise
Even the NOS may lean it out
Old Apr 23, 2017 | 11:52 AM
  #125
Penis Healthy
Planning on getting the ecu flashed, so if i can get any recommendations on a cam before hand they can tune me up for that.
